Archives de la liste
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: Xavier Lacoste <xl64100@gmail.com>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Failed assert in copy_driver.c
- Date: Tue, 21 Oct 2014 16:53:20 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Xavier Lacoste, le Tue 21 Oct 2014 15:06:40 +0200, a écrit :
> oops in copy_data_1_to_1_generic (datawizard/copy_driver.c:211)... 4:
> unspecified launch failure
Ok. So since changing the number of requests doesn't fix things, CUDA is
probably not overwhelmed with too many requests. Is your application
filling GPU memory a lot? Perhaps there is a race between a data
transfer and a buffer deallocation, is there a way I could run the
program myself to debug things with gdb at ease?
> Moreover, 1.2 gives more FLOPS than 1.1 on my application (which is a good
> evolution :D).
How much more? Are you using the STARPU_CUDA_ASYNC flag BTW?
Samuel
- [Starpu-devel] Failed assert in copy_driver.c, Xavier Lacoste, 20/10/2014
- Re: [Starpu-devel] Failed assert in copy_driver.c, Samuel Thibault, 20/10/2014
- Re: [Starpu-devel] Failed assert in copy_driver.c, Xavier Lacoste, 20/10/2014
- Re: [Starpu-devel] Failed assert in copy_driver.c, Xavier Lacoste, 21/10/2014
- Re: [Starpu-devel] Failed assert in copy_driver.c, Samuel Thibault, 21/10/2014
- Re: [Starpu-devel] Failed assert in copy_driver.c, Xavier Lacoste, 24/10/2014
- Re: [Starpu-devel] Failed assert in copy_driver.c, Samuel Thibault, 27/10/2014
- Re: [Starpu-devel] Failed assert in copy_driver.c, Xavier Lacoste, 27/10/2014
