Archives de la liste
- To: Xavier Lacoste <xl64100@gmail.com>
- Cc: Samuel Thibault <samuel.thibault@ens-lyon.org>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Failed assert in copy_driver.c
- Date: Tue, 21 Oct 2014 15:06:40 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello again,
I went to 1.1 and got similar errors on some runs.
oops in copy_data_1_to_1_generic (datawizard/copy_driver.c:211)... 4:
unspecified launch failure
Moreover, 1.2 gives more FLOPS than 1.1 on my application (which is a good
evolution :D).
So I'll stay to 1.2 and rerun the failing runs which with some luck will not
fail again.
For this experiment its not a problem rerunning the experiment until it does
not fail, but when I'll have to use PaStiX with StarPU with GPUs in a "real
world" application it will be more problematic...
Regards,
XL.
Le 20 oct. 2014 à 15:26, Xavier Lacoste <xl64100@gmail.com> a écrit :
> Hello,
> With changing MAX_PENDING_REQUESTS_PER_NODE and
> MAX_PENDING_PREFETCH_REQUESTS_PER_NODE. I got:
> oops in copy_data_1_to_1_generic (datawizard/copy_driver.c:200)... 4:
> With revision 13658 I got:
> oops in _starpu_driver_test_request_completion
> (datawizard/copy_driver.c:729)... 4: unspecified launch failure
> I'll go to 1.1 and see.
> Thanks,
> XL.
> Le 20 oct. 2014 à 14:11, Samuel Thibault <samuel.thibault@ens-lyon.org> a
> écrit :
>> Xavier Lacoste, le Mon 20 Oct 2014 13:56:08 +0200, a écrit :
>>> I could use 1.1, the only thing I use from 1.2 are the commutable tasks
>>> but in my code. The use of this feature does not change much the timing
>>> of the execution, so I can go 1.1...
>>> it's just because I used 1.2 on an other machine (when I tested the
>>> removal of sequential consistency flag on often used buffers) and wanted
>>> the same configuration.
>> OK :)
>> Samuel
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
signature.asc
Description: Message signed with OpenPGP using GPGMail
- [Starpu-devel] Failed assert in copy_driver.c, Xavier Lacoste, 20/10/2014
- Re: [Starpu-devel] Failed assert in copy_driver.c, Samuel Thibault, 20/10/2014
- Re: [Starpu-devel] Failed assert in copy_driver.c, Xavier Lacoste, 20/10/2014
- Re: [Starpu-devel] Failed assert in copy_driver.c, Xavier Lacoste, 21/10/2014
- Re: [Starpu-devel] Failed assert in copy_driver.c, Samuel Thibault, 21/10/2014
- Re: [Starpu-devel] Failed assert in copy_driver.c, Xavier Lacoste, 24/10/2014
- Re: [Starpu-devel] Failed assert in copy_driver.c, Samuel Thibault, 27/10/2014
- Re: [Starpu-devel] Failed assert in copy_driver.c, Xavier Lacoste, 27/10/2014
