Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] [LU factorisation: gdb debug output]
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] [LU factorisation: gdb debug output]
  • Date: Wed, 20 Dec 2017 14:06:41 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=maxim.abalenkov@gmail.com; spf=Pass smtp.mailfrom=maxim.abalenkov@gmail.com; spf=None smtp.helo=postmaster@mail-wm0-f41.google.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Dear all,
I’m on a mission to implement a custom task-based LU factorisation by means of StarPU. I’m encountering the following error:
  test: datawizard/data_request.c:150: _starpu_create_data_request: Assertion `handling_node == 0 || _starpu_memory_node_get_nworkers(handling_node)’ failed
Please find the output of the gdb `thread apply all bt` command attached. I will continue debugging. But any hints will be highly appreciated. Thank you and have a good day!
Best wishes,
Maxim
(gdb) thread apply all bt
Thread 5 (Thread 0x7fffedcdc700 (LWP 11308)):
#0 0x00007ffff73ce519 in starpu_memory_get_total (node=4127119393) at
datawizard/memory_manager.c:151
#1 0x00007ffff73d3627 in starpu_memchunk_tidy (node=0) at
datawizard/memalloc.c:966
#2 0x00007ffff73c343f in __starpu_datawizard_progress (memory_node=0,
may_alloc=1, push_requests=1) at datawizard/datawizard.c:42
#3 0x00007ffff73c3501 in _starpu_datawizard_progress (memory_node=0,
may_alloc=1) at datawizard/datawizard.c:69
#4 0x00007ffff7442345 in _starpu_cpu_driver_run_once
(cpu_worker=0x7ffff76d0df8 <_starpu_config+4440>) at
drivers/cpu/driver_cpu.c:235
#5 0x00007ffff74429ef in _starpu_cpu_worker (arg=0x7ffff76d0df8
<_starpu_config+4440>) at drivers/cpu/driver_cpu.c:361
#6 0x00007ffff355508a in start_thread () from /usr/lib/libpthread.so.0
#7 0x00007ffff328c42f in clone () from /usr/lib/libc.so.6
Thread 4 (Thread 0x7fffee4dd700 (LWP 11307)):
#0 0x00007ffff73b6213 in _starpu_exponential_backoff (worker=0x7ffff76d09d0
<_starpu_config+3376>) at drivers/driver_common/driver_common.c:328
#1 0x00007ffff73b7632 in _starpu_get_worker_task (worker=0x7ffff76d09d0
<_starpu_config+3376>, workerid=2, memnode=0) at
drivers/driver_common/driver_common.c:436
#2 0x00007ffff744237a in _starpu_cpu_driver_run_once
(cpu_worker=0x7ffff76d09d0 <_starpu_config+3376>) at
drivers/cpu/driver_cpu.c:243
#3 0x00007ffff74429ef in _starpu_cpu_worker (arg=0x7ffff76d09d0
<_starpu_config+3376>) at drivers/cpu/driver_cpu.c:361
#4 0x00007ffff355508a in start_thread () from /usr/lib/libpthread.so.0
#5 0x00007ffff328c42f in clone () from /usr/lib/libc.so.6
Thread 3 (Thread 0x7fffeecde700 (LWP 11306)):
#0 _starpu_get_worker_struct (id=1) at ./core/workers.h:462
#1 0x00007ffff7349c7d in _starpu_worker_mutex_is_sched_mutex (workerid=1,
mutex=0x7ffff76d06c0 <_starpu_config+2592>) at ./core/workers.h:533
#2 0x00007ffff7349da5 in starpu_pthread_mutex_unlock_sched
(mutex=0x7ffff76d06c0 <_starpu_config+2592>) at common/thread.c:618
#3 0x00007ffff73b7554 in _starpu_get_worker_task (worker=0x7ffff76d05a8
<_starpu_config+2312>, workerid=1, memnode=0) at
drivers/driver_common/driver_common.c:433
#4 0x00007ffff744237a in _starpu_cpu_driver_run_once
(cpu_worker=0x7ffff76d05a8 <_starpu_config+2312>) at
#5 0x00007ffff74429ef in _starpu_cpu_worker (arg=0x7ffff76d05a8
<_starpu_config+2312>) at drivers/cpu/driver_cpu.c:361
Thread 2 (Thread 0x7fffef4df700 (LWP 11305)):
#0 0x00007ffff31ca860 in raise () from /usr/lib/libc.so.6
#1 0x00007ffff31cbec9 in abort () from /usr/lib/libc.so.6
#2 0x00007ffff31c30bc in __assert_fail_base () from /usr/lib/libc.so.6
#3 0x00007ffff31c3133 in __assert_fail () from /usr/lib/libc.so.6
#4 0x00007ffff73bfafd in _starpu_create_data_request (handle=0x555555a2f750,
src_replicate=0x555555a2f848, dst_replicate=0x555555a2f890, handling_node=1,
mode=STARPU_W, ndeps=0, is_prefetch=0,
is_write_invalidation=0) at datawizard/data_request.c:150
#5 0x00007ffff73bbfff in _starpu_create_request_to_fetch_data
(handle=0x555555a2f750, dst_replicate=0x555555a2f890, mode=STARPU_W,
is_prefetch=0, async=0, callback_func=0x0, callback_arg=0x0)
at datawizard/coherency.c:634
#6 0x00007ffff73bc751 in _starpu_fetch_data_on_node (handle=0x555555a2f750,
node=1, dst_replicate=0x555555a2f890, mode=STARPU_W, detached=0,
at datawizard/coherency.c:754
#7 0x00007ffff73bc8eb in fetch_data (handle=0x555555a2f750, node=1,
replicate=0x555555a2f890, mode=STARPU_W) at datawizard/coherency.c:782
#8 0x00007ffff73bd75e in _starpu_fetch_task_input (j=0x555555a5e580) at
datawizard/coherency.c:972
#9 0x00007ffff744197c in execute_job_on_cpu (j=0x555555a5e580,
worker_task=0x555555a5d900, cpu_args=0x7ffff76d0180 <_starpu_config+1248>,
rank=0, perf_arch=0x7ffff76d01c8 <_starpu_config+1320>)
at drivers/cpu/driver_cpu.c:71
#10 0x00007ffff744282e in _starpu_cpu_driver_run_once
(cpu_worker=0x7ffff76d0180 <_starpu_config+1248>) at
drivers/cpu/driver_cpu.c:300
#11 0x00007ffff74429ef in _starpu_cpu_worker (arg=0x7ffff76d0180
<_starpu_config+1248>) at drivers/cpu/driver_cpu.c:361
#12 0x00007ffff355508a in start_thread () from /usr/lib/libpthread.so.0
#13 0x00007ffff328c42f in clone () from /usr/lib/libc.so.6
Thread 1 (Thread 0x7ffff7fa6c00 (LWP 11301)):
#0 0x00007ffff355b38d in pthread_cond_wait@@GLIBC_2.3.2 () from
#1 0x00007ffff734395f in _starpu_barrier_counter_wait_for_empty_counter
(barrier_c=0x7ffff76e7b60 <_starpu_config+97984>) at
common/barrier_counter.c:44
#2 0x00007ffff739bd5f in _starpu_wait_for_all_tasks_of_sched_ctx
(sched_ctx_id=0) at core/sched_ctx.c:1312
#3 0x00007ffff7356039 in
_starpu_task_wait_for_all_in_ctx_and_return_nb_waited_tasks (sched_ctx=0) at
core/task.c:887
#4 0x00007ffff7355fc8 in
_starpu_task_wait_for_all_and_return_nb_waited_tasks () at core/task.c:874
#5 0x00007ffff7355ffa in starpu_task_wait_for_all () at core/task.c:880
---Type <return> to continue, or q <return> to quit---
#6 0x00007ffff7b5a150 in plasma_zgetrf (m=16, n=16, pA=0x555555a19bd0,
lda=16, iPiv=0x555555a13eb0) at compute/zgetrf.c:152
#7 0x000055555557d2f1 in test_zgetrf (param=0x7fffffffa5c0, run=true) at
test/test_zgetrf.c:122
#8 0x0000555555574c43 in run_routine (name=0x7fffffffb052 "zgetrf",
pval=0x7fffffffa5c0, run=true) at test/test.c:501
#9 0x00005555555746a3 in test_routine (name=0x7fffffffb052 "zgetrf",
pval=0x7fffffffa5c0, test=true) at test/test.c:397
#10 0x0000555555574225 in main (argc=5, argv=0x7fffffffad18) at
test/test.c:250
Maxim Abalenkov \\ maxim.abalenkov@gmail.com
+44 7 486 486 505 \\ http://mabalenk.gitlab.io
Haut de le page
