Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] [LU factorisation: gdb debug output]
Archives de la liste
Chronologique Discussions
  • To: Maxim Abalenkov <maxim.abalenkov@gmail.com>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] [LU factorisation: gdb debug output]
  • Date: Wed, 20 Dec 2017 14:25:06 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Samuel Thibault, on mer. 20 déc. 2017 14:19:23 +0100, wrote:
> Just to be sure: are you using --enable-numa?
Or are you using out-of-core support?
In other words: I don't understand why you have node=1 in your
backtrace: with a CPU-only system, without NUMA support, and without
disk, there should be only one node, node 0, for the main RAM.
Perhaps you should post the output of starpu_machine_display, so we can
be sure about what is enabled.
Samuel
Haut de le page
