Archives de la liste
- To: Maxim Abalenkov <maxim.abalenkov@gmail.com>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] [LU factorisation: gdb debug output]
- Date: Wed, 20 Dec 2017 14:19:23 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Hello,
Maxim Abalenkov, on mer. 20 déc. 2017 14:06:41 +0100, wrote:
> test: datawizard/data_request.c:150: _starpu_create_data_request:
> Assertion `handling_node == 0 ||
> _starpu_memory_node_get_nworkers(handling_node)’ failed
Which version of starpu is this? The line numbers below don't match what we
have in starpu 1.2
#4 0x00007ffff73bfafd in _starpu_create_data_request (handle=0x555555a2f750,
src_replicate=0x555555a2f848, dst_replicate=0x555555a2f890, handling_node=1,
mode=STARPU_W, ndeps=0, is_prefetch=0,
is_write_invalidation=0) at datawizard/data_request.c:150
#5 0x00007ffff73bbfff in _starpu_create_request_to_fetch_data
(handle=0x555555a2f750, dst_replicate=0x555555a2f890, mode=STARPU_W,
is_prefetch=0, async=0, callback_func=0x0, callback_arg=0x0)
at datawizard/coherency.c:634
#6 0x00007ffff73bc751 in _starpu_fetch_data_on_node (handle=0x555555a2f750,
node=1, dst_replicate=0x555555a2f890, mode=STARPU_W, detached=0,
at datawizard/coherency.c:754
#7 0x00007ffff73bc8eb in fetch_data (handle=0x555555a2f750, node=1,
replicate=0x555555a2f890, mode=STARPU_W) at datawizard/coherency.c:782
#8 0x00007ffff73bd75e in _starpu_fetch_task_input (j=0x555555a5e580) at
datawizard/coherency.c:972
#9 0x00007ffff744197c in execute_job_on_cpu (j=0x555555a5e580,
worker_task=0x555555a5d900, cpu_args=0x7ffff76d0180 <_starpu_config+1248>,
rank=0, perf_arch=0x7ffff76d01c8 <_starpu_config+1320>)
at drivers/cpu/driver_cpu.c:71
Just to be sure: are you using --enable-numa?
Samuel
- [Starpu-devel] [LU factorisation: gdb debug output], Maxim Abalenkov, 20/12/2017
- Re: [Starpu-devel] [LU factorisation: gdb debug output], Samuel Thibault, 20/12/2017
- Re: [Starpu-devel] [LU factorisation: gdb debug output], Maxim Abalenkov, 20/12/2017
