Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] [LU factorisation: gdb debug output]
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@inria.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] [LU factorisation: gdb debug output]
  • Date: Wed, 20 Dec 2017 14:30:11 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=maxim.abalenkov@gmail.com; spf=Pass smtp.mailfrom=maxim.abalenkov@gmail.com; spf=None smtp.helo=postmaster@mail-wm0-f48.google.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello Samuel,
Below is the output of “starpu_machine_display”:
StarPU has found :
4 CPU threads
CPU 0
CPU 1
CPU 2
CPU 3
0 CUDA devices
0 OpenCL devices
topology ... (hwloc logical indexes)
pack 0 core 0 PU 0 CPU 0
PU 1
core 1 PU 2 CPU 1
PU 3
core 2 PU 4 CPU 2
PU 5
core 3 PU 6 CPU 3
PU 7
bandwidth and latency ...
from/to RAM
RAM 0
RAM 0
Best wishes,
Maxim
Maxim Abalenkov \\ maxim.abalenkov@gmail.com
+44 7 486 486 505 \\ http://mabalenk.gitlab.io
On 20 Dec 2017, at 14:25, Samuel Thibault <samuel.thibault@inria.fr> wrote:
Samuel Thibault, on mer. 20 déc. 2017 14:19:23 +0100, wrote:
Just to be sure: are you using --enable-numa?
Or are you using out-of-core support?
In other words: I don't understand why you have node=1 in your
backtrace: with a CPU-only system, without NUMA support, and without
disk, there should be only one node, node 0, for the main RAM.
Perhaps you should post the output of starpu_machine_display, so we can
be sure about what is enabled.
Samuel
Haut de le page
