Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] [LU factorisation: gdb debug output]
Archives de la liste
Chronologique Discussions
  • To: Maxim Abalenkov <maxim.abalenkov@gmail.com>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] [LU factorisation: gdb debug output]
  • Date: Wed, 20 Dec 2017 14:35:36 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
  • Ironport-phdr: 9a23:DLrbwBKtNBu3YqKlsNmcpTZWNBhigK39O0sv0rFitYgeLvvxwZ3uMQTl6Ol3ixeRBMOHs6sC07KempujcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS47xaFLIv3K98yMZFAnhOgppPOT1HZPZg9iq2+yo9JDffxhEiCChbb9uMR67sRjfus4KjIV4N60/0AHJonxGe+RXwWNnO1eelAvi68mz4ZBu7T1et+ou+MBcX6r6eb84TaFDAzQ9L281/szrugLdQgaJ+3ART38ZkhtMAwjC8RH6QpL8uTb0u+ZhxCWXO9D9QKsqUjq+8ahkVB7oiD8GNzEn9mHXltdwh79frB64uhBz35LYbISTOfFjfK3SYMkaSHJPUMhRSSJPH4Cyb4UAAOUdIOlWoIvyp1wAohalGQmhB//jxiNUinLs36A31fkqHwHc3AwnGtIDqGnao8/wNKcPT++1yLTDwyvDb/NXwjjy8pXIchQ9ofqRWr9watDeyUwyFwzbilWcs5DlPzOU1usWqWeb8u5gVf60hm4mrQFxuDmvyd02honHnIIY01bJ/jh6zoYtPdC0VUF2bcO+HJdOtyyXN5F6Tt48T2xroio216UKtYO0cSUI0pgr2QPTZ+Cdf4SW7R/uVPydLSp7iX55fr+0mgy8/lK6yuLmU8m5yFZKoTRBktnLrn0N1wLc6tKdRfdn5EihwCuP1wHX6u5aJ0A7i7bbJ4Qvwr4qjpYTsELDETHqmEjukaObeVgo9vK25+nnYrjqvIKQO5F3hw3kL6gigsm/Dv45MggKUWib4+O81Lj78E3iWrpKi+A2nbfdsJzAOcQbpq+5DBRP3YY+7xa/Eyyr38oenXkcNV5FfBKGj4/vO13UJ/D4F/i/j0y2kDh33/DGIqHhApLVI3jYjLfuZ6x961ZByAYq0N9Q+YxUBa8FIP/oXk/xtcfYDgMiMwCuzObnBtJ91pkRWW2RGKOZMaXSsUWJ5u01OeWMapUV637BLK0A7u7viDcQk1YZcK+q2oVfPHWxDvVjZUyTaH7hhNQGD08FuwM/SKrhj1jUAhBJYHPnZKs5+zw/QL6mDI3KW4SxyOia1SKmE5kQemBHAFmRFWvAdoOeWv5KZjjEcZwpqSANSbX0E9xp7hqprgKvjuM/duc=
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Maxim Abalenkov, on mer. 20 déc. 2017 14:30:11 +0100, wrote:
> Below is the output of “starpu_machine_display”:
> StarPU has found :
> 4 CPU threads
> CPU 0
> CPU 1
> CPU 2
> CPU 3
> 0 CUDA devices
> 0 OpenCL devices
> topology ... (hwloc logical indexes)
> pack 0 core 0 PU 0 CPU 0
> PU 1
> core 1 PU 2 CPU 1
> PU 3
> core 2 PU 4 CPU 2
> PU 5
> core 3 PU 6 CPU 3
> PU 7
> bandwidth and latency ...
> from/to RAM
> RAM 0
> RAM 0
Ok, so there is no reason why node is 1 in your backtrace.
Are you using the nodes or dyn_nodes field in the codelet structure?
Within
Thread 2 (Thread 0x7fffef4df700 (LWP 11305)):
#0 0x00007ffff31ca860 in raise () from /usr/lib/libc.so.6
#1 0x00007ffff31cbec9 in abort () from /usr/lib/libc.so.6
#2 0x00007ffff31c30bc in __assert_fail_base () from /usr/lib/libc.so.6
#3 0x00007ffff31c3133 in __assert_fail () from /usr/lib/libc.so.6
#4 0x00007ffff73bfafd in _starpu_create_data_request (handle=0x555555a2f750,
src_replicate=0x555555a2f848, dst_replicate=0x555555a2f890, handling_node=1,
mode=STARPU_W, ndeps=0, is_prefetch=0,
is_write_invalidation=0) at datawizard/data_request.c:150
#5 0x00007ffff73bbfff in _starpu_create_request_to_fetch_data
(handle=0x555555a2f750, dst_replicate=0x555555a2f890, mode=STARPU_W,
is_prefetch=0, async=0, callback_func=0x0, callback_arg=0x0)
at datawizard/coherency.c:634
#6 0x00007ffff73bc751 in _starpu_fetch_data_on_node (handle=0x555555a2f750,
node=1, dst_replicate=0x555555a2f890, mode=STARPU_W, detached=0,
at datawizard/coherency.c:754
#7 0x00007ffff73bc8eb in fetch_data (handle=0x555555a2f750, node=1,
replicate=0x555555a2f890, mode=STARPU_W) at datawizard/coherency.c:782
#8 0x00007ffff73bd75e in _starpu_fetch_task_input (j=0x555555a5e580) at
datawizard/coherency.c:972
#9 0x00007ffff744197c in execute_job_on_cpu (j=0x555555a5e580,
worker_task=0x555555a5d900, cpu_args=0x7ffff76d0180 <_starpu_config+1248>,
rank=0, perf_arch=0x7ffff76d01c8 <_starpu_config+1320>)
it would be useful to run
gdb> thread 2
gdb> frame 8
gdb> print node
gdb> print local_memory_node
gdb> print descrs[index].node
to make sure where this bogus node is coming from.
Samuel
Haut de le page
