- To: ,
- Cc: Iosif Pinelis <>
- Subject: Re: [cgal-discuss] algorithms for polygons
- Date: Tue, 06 Mar 2007 18:25:55 -0500
wrote:
The CGAL definition of simplicity is the usual one. You have it in theThanks a lot for this post. This helps.
manual:
"A polygon is a closed chain of edges. Several algorithms are available
for polygons. For some of those algorithms, it is necessary that the
polygon is simple. A polygon is simple if edges don't intersect, except
consecutive edges, which intersect in their common vertex."
It could be more precise by telling you that any degenerate edgeSounds great.
(zero-length edge) is discarded first.
The definition of convexity seems to be missing from the manual. However,
there again, it is the usual one:
non-simple polygons are not convex, a simple polygon is convex if the
union of its bounded side and its edges is convex.
This touches perhaps on the very cause of my problems. As I wrote before, I have tried to install CGAL on Windows XP (after installing Visual C++ 2005 Express edition (version 8.0) and also boost) using the CGAL Windows Installer (which says it assumes Visual C++ 2003 (version 7.1)), and the installation fails to complete, perhaps not surprisingly. A CGAL installation manual says that only Visual C++ 2003 (version 7.1) is supported by CGAL, but 7.1 does not appear to be available any more, as it has been replaced by 8.0 by Microsoft.I have been able to find online only extremely brief
descriptions of the corresponding pieces of code. As for the polygon
simplicity, it is said there that a sweep algorithm is used, but no
details are given.
I don't see why you would need more in the manual. If you need more, a
quite precise description is present at the beginning of the
Polygon_2_simplicity.h file, and you have the code itself.
Anyway, now I have many .h files in my CGAL download, but I can't find Polygon_2_simplicity.h anywhere, even with the Google desktop search.
This gives me a pretty clear idea about the algorithm. Questions I still have here:As for the polygon convexity, nothing at all is
said about the algorithm.
Indeed. It may be interesting to present it. Basically, it checks the
local convexity (by successive orientation tests) and checks that there is
not more than two changes of lexicographic order along the polygon, which
ensures simplicity (given the local convexity, of course).
1. Just to be sure, do you mean by the local convexity that all the
2-by-2 determinants (y_{i+1}-y_i) (x_i-x_{i-1}) - (x_{i+1}-x_i)
(y_i-y_{i-1}) formed by the coordinates of the adjacent
edge-vectors have the same sign? Here (x_i,y_i) is the ith vertex.
2. Do you allow any of these determinants to be zero?
3. The _biggest_ question remaining now: is there a rigorous proof
that the CGAL convexity test exactly corresponds to the definition
that you gave?
Alas, as I said, it hasn't worked for me. If it's too difficult to fix my installation problem, is it possible to e-mail me copies of Polygon_2_simplicity.h and, I'd guess, Polygon_2_convexity.h or whatever -- containing a description of the convexity test and/or the corresponding code?How then could I look at it?
I guess downloading it would be a step in the right direction. It is
available at
http://cgal.org/download/
Many thanks for your patience with me.
Iosif Pinelis
- Re: [cgal-discuss] algorithms for polygons, Camille . Wormser, 03/06/2007
- Re: [cgal-discuss] algorithms for polygons, Camille . Wormser, 03/07/2007
- Re: [cgal-discuss] algorithms for polygons, Iosif Pinelis, 03/07/2007
- polygon convexity proofs, Iosif Pinelis, 03/07/2007
- Re: [cgal-discuss] polygon convexity proofs, Camille . Wormser, 03/07/2007
- Re: [cgal-discuss] polygon convexity proofs, Iosif Pinelis, 03/07/2007
- Re: [cgal-discuss] polygon convexity proofs, Iosif Pinelis, 03/08/2007
- Re: [cgal-discuss] polygon convexity proofs, Iosif Pinelis, 03/09/2007
