- To: ,
- Cc: Iosif Pinelis <>
- Subject: Re: [cgal-discuss] algorithms for polygons
- Date: Tue, 06 Mar 2007 18:45:16 -0500
wrote:
Le Mar 6 mars 2007 22:53,Thank you again. This may address one of my 3 remaining questions. I am not quite sure, though, what exactly you mean here by:
a écrit :
The definition of convexity seems to be missing from the manual. However,
there again, it is the usual one:
non-simple polygons are not convex, a simple polygon is convex if the
union of its bounded side and its edges is convex.
I am wrong here:
a flat polygon (hence non-simple) is considered convex if each point of
the polygon which is not a vertex belongs to exactly two edges.
In nicer terms, if P is the set of polygons, and CSP is the set of convex
simple polygons, the set of convex polygons CP is the topological closure
of CSP in P for the topology induced by the pseudo-distance
d(P1, P2) = min_{all parameterizations f_P1 f_P2} d(f_P1, f_P2)
1. a polygon (a closed piecewise-linear curve?)
2. a flat polygon (a polygon for which some of the determinants are
zero?)
3. a vertex (where the determinant is nonzero?)
Given the definition of a polygon as a closed piecewise-linear curve, your nicer, topological definition would be clear. But the "biggest" question remains: is there a rigorous proof that the CGAL convexity test exactly corresponds to the definition that you gave?
Iosif Pinelis
- Re: [cgal-discuss] algorithms for polygons, Camille . Wormser, 03/06/2007
- Re: [cgal-discuss] algorithms for polygons, Camille . Wormser, 03/07/2007
- Re: [cgal-discuss] algorithms for polygons, Iosif Pinelis, 03/07/2007
- polygon convexity proofs, Iosif Pinelis, 03/07/2007
- Re: [cgal-discuss] polygon convexity proofs, Camille . Wormser, 03/07/2007
- Re: [cgal-discuss] polygon convexity proofs, Iosif Pinelis, 03/07/2007
- Re: [cgal-discuss] polygon convexity proofs, Iosif Pinelis, 03/08/2007
- Re: [cgal-discuss] polygon convexity proofs, Iosif Pinelis, 03/09/2007
