cgal-discuss - Re: [cgal-discuss] polygon convexity proofs
  • To:
  • Subject: Re: [cgal-discuss] polygon convexity proofs
  • Date: Wed, 07 Mar 2007 22:53:25 -0500
wrote:
Le Mer 7 mars 2007 20:15, Iosif Pinelis a écrit :
Come on Camille. Your own example, from your latest post, shows that
CGAL does not give the right answer.
In my message, I explicitely mention
"in the case of non flat polygons, we can assume that three successive
vertices are never aligned (by removing unnecessary vertices)"
This is where CGAL fails.
It does appear that the test fails there. That is why I said in my comment to this part of your proof that one should be careful even at such a comparatively minor point, depending especially on how exactly the test deals with such degeneracies (I still don't know all the details of how the CGAL test works).
As for the rest of your message, I think it has nothing to do on such a
mailing-list.
I don't understand this. On a "micro level", I was analyzing the proof that you posted on the list, that is, the proof of the CGAL test (and the later additions to/clarifications of the proof), and I used the same convenient point-by-point format as you use in your messages.
On a "macro level", the point that I was trying to make -- in general and for polygon convexity in particular -- is that we do need (i) exact definitions of the geometric traits tested, (ii) exact and complete descriptions of the corresponding tests, and (iii) rigorous and complete proofs that each test exactly verifies the definition of the corresponding tested notion. Related to this was the suggestion that it would be great to have for each given notion (such as polygon convexity, say) a standard, generally accepted definition -- rather than a disparate variety of them with no mutual relations established or proved. I believe that the papers at http://arxiv.org/abs/cs.CG/0609141 and http://arxiv.org/abs/cs.CG/0701045 (and ones referenced therein) serve these goals as far as the polygon convexity is concerned. In particular, I think that the methods and/or results especially of the second one of these two papers can be used to rigorously prove the CGAL convexity test. Since convexity tests are also used in other problems, both 2D and higher-dimensional, I would expect this to be of interest to this forum. --
Iosif Pinelis, Professor
Department of Mathematical Sciences
Michigan Technological University
Houghton, MI 49931 USA
