cgal-discuss - Re: [cgal-discuss] polygon convexity proofs
  • To:
  • Subject: Re: [cgal-discuss] polygon convexity proofs
  • Date: Fri, 09 Mar 2007 07:51:06 -0500
Iosif Pinelis wrote, in part:
I think the CGAL polygon convexity test is pretty similar to the LEDA test, whose proof can be found at http://arxiv.org/abs/cs.CG/0701045 . So, I believe the CGAL test can be proved similarly to the LEDA test and/or using the latter test.
Indeed, it turns out to be easily proved that an appropriate version of the CGAL polygon convexity test (as I understood it, with the bug observed by Camille Wormser fixed) is exactly equivalent to the ``non-strict'' version of the LEDA test, with collinear vertices allowed. Quite similarly, the strict variant of the LEDA test is equivalent to a strict variant of the CGAL test. I am going to write up the proof of the equivalence of the two tests and then let you know.
Iosif Pinelis
