cgal-discuss - Re: [cgal-discuss] algorithms for polygons
  • To:
  • Subject: Re: [cgal-discuss] algorithms for polygons
  • Date: Wed, 7 Mar 2007 01:31:04 +0100 (CET)
  • Importance: Normal
Le Mer 7 mars 2007 0:45, Iosif Pinelis a écrit :
> Thank you again. This may address one of my 3 remaining questions. I am
> not quite sure, though, what exactly you mean here by:
> 1. a polygon (a closed piecewise-linear curve?)
I would define a polygon as a closed piecewise-linear curve with a set of
vertices on it, such that each singular point (i.e. with a discontinuous
derivative) is a vertex.
> 2. a flat polygon (a polygon for which some of the determinants are
> zero?)
I would say a polygon which is contained in a line, in other words, a
polygon such that the determinant at each vertex is zero.
> 3. a vertex (where the determinant is nonzero?)
I would say the set of vertices is some finite set of points on the curve,
which contains the singular points.
> Given the definition of a polygon as a closed piecewise-linear curve,
> your nicer, topological definition would be clear. But the "biggest"
> question remains: is there a rigorous proof that the CGAL convexity
> test exactly corresponds to the definition that you gave?
Check whether you are convinced by my sketch of proof (in the previous
message) or not.
Camille Wormser
