cgal-discuss - Re: [cgal-discuss] polygon convexity proofs
  • To:
  • Subject: Re: [cgal-discuss] polygon convexity proofs
  • Date: Wed, 07 Mar 2007 14:15:34 -0500
wrote:
Le Mer 7 mars 2007 4:06, Iosif Pinelis a écrit :
This may contain some good ideas, but I have some comments here:
* first of all, there should essentially be two parts of proof: (1)
that your definition of convexity implies that the CGAL test says
"yes" and (2) vice versa. It seems that you present a sketch of
proof of (2) only. (Am I right?)
No. I show that in the flat and non-flat case, CGAL gives the right answer.
Come on Camille. Your own example, from your latest post, shows that CGAL does not give the right answer. You can say that was a minor bug. So, let us get back to your proof. How does one prove that something is _not_ a proof? That may sometimes be more difficult to prove than the thing itself!
I asked if you presented only a sketch of proof of implication (2) (but not of implication (1)). You answer "No." But I can't find anything concerning (1) in your proof, even though I have tried pretty hard.
Indeed, let us discard (just for the simplicity/brevity sake) the flat case (which is trivial anyway) and focus on the non-flat case. Let us consider in detail all that you wrote for that case:
- in the case of non flat polygons, we can assume that three successive
vertices are never aligned (by removing unnecessary vertices),
Well, even at this comparatively minor point, some care should exercised,
depending especially on how exactly the test deals with such degeneracies (we
discussed this a bit back and forth).
and we have
a non-flat locally convex curve P.
Here you are assuming the local convexity, which you said is part of the CGAL test. So, this assumption seems to pertain to implication (2), that the CGAL test's "yes" implies the polygon convexity.
If it has no self intersection, it is
convex, and it has exactly 2 changes of lexicographic order.
The conclusion here, that P is convex, again seems to pertain to the same
implication (2). (Even though no immediate reasons for this conclusion are
given.)
If it has
self intersections, we have to show that there are at least 3 changes of
lexicographic order. Let us call X some intersection point. We can split P
at X into two polygons, P1 and P2. As any polygon, P1 and P2 have at least
2 changes of order each. P is the union of P1 and P2. As such, it has at
least 2 + 2 changes, maybe minus one, in case X is a point with an order
change for both P1 and P2. Hence, we always have at least 3 changes in
case there is an auto intersection.
In this part of the proof, you apparently try to show that lack of simplicity implies
that the CGAL test says "no" (for the reason of more than 2 changes of
order). Equivalently, this would mean that the only-two-changes condition of the test
implies the simplicity, which is one (but not all) of the polygon convexity conditions
required by your definition. So, this last quote is seen as an attempt to prove the
same implication (2). Another way to look at this is that here you try to show that the
only-two-changes condition of the test implies the simplicity, in which case you have
already addressed implication (2) in some way. However, here again your reasoning is
far from sufficient. Indeed, just for one thing, here you are not in any way using the
condition of the CGAL test that all the determinants be of the same sign; nor are you
even referring to that condition, without which your counting of the order changes is
in general incorrect. Consider e.g. polygon Q with vertex list
((0,0),(1,1),(1,0),(0,1)); then Q is self-intersecting and thus not simple (and also
not convex), but it has only 2 changes of lexicographic order.
This concludes the proof.
Well, we can summarize now.
1. Your own example contradicts your proof.
2. The implication (1) of your claim is nowhere addressed in the proof.
3. The proof of the other half of the claim (implication (2)) is
essentially insufficient on several counts.
It remains to address just a few details.
But implication (1) does not seem
trivial. Even the terms of your definition (a mix of topology,
algebra, and order) are quite different from the terms of the CGAL
test (no topology, and quite different kinds of algebra and
order). I think that quite a bit of translation from the one
language into the other is needed here.
The topological definition I gave is just there to express the condition
for flat polygons in terms of topological closure instead of an ad hoc
condition. I leave it to you to check that the two definitions are
equivalent (the topological one, and the one with the number of edges a
non-vertex should belong to).
This particular topological aspect of your definition of polygon convexity is indeed comparatively simple, and it is not what I meant. Rather, if you spell out the term "bounded side" in your defintion:
non-simple polygons are not convex, a simple polygon is convex if the
union of its bounded side and its edges is convex
then you'll get this: "the bounded connected component of the complement of the image of the polygon in R^2", and it is connectedness that is the nontrivial and essential topological aspect. However, it was never used (or even referred to) in your proof.
* Moreover, in your proof of implication (2)(?), you just say: "If
it has no self intersection, it is convex". This is obviously not
true in general, even if "three successive vertices are never
aligned".
You forget that we are in the locally convex case.
No, I don't forget. But, again, you never even referred to local convexity in your original proof. Nor did you ever say which way you are proving: (1) or (2).
This is completely
true. If it were non convex, you would have a ray starting inside its core
and intersecting it twice or more.
In other words, you are saying that, if a polygon P is simple and all the determinants are positive and all rays originating in the bounded connected component IP of the complement of P intersect P (at most) once, then the union of P and IP is a convex set. This statement looks far from obvious. Exactly why is do you say it is true?
By winding around the origin of the ray
and assuming simplicity, you would obtain that the polygon is
disconnected.
Again, exactly how would I obtain this?
Hence it is convex.
Overall, sorry, I do not believe that this constitutes a proof.
Ok. I think everything is said in the sketch of proof I wrote. I leave you
the details to fill.
Thanks for giving me this job. :-) I may take it at some point. However, so far I frankly do not see how to utilize any of your suggestions. Rather, I think the CGAL polygon convexity test is pretty similar to the LEDA test, whose proof can be found at http://arxiv.org/abs/cs.CG/0701045 . So, I believe the CGAL test can be proved similarly to the LEDA test and/or using the latter test.
That you leave the job to me seems rather strange, though. Let me remind you that my questions were as follows:
1. What is the definition of polygon convexity assumed in CGAL?
2. What is the CGAL polygon convexity text?
3. Is there a complete, rigorous proof that the test exactly
corresponds to the definition?
It seems that you (apparently as a person speaking for the CGAL team, no?) gave me more or less clear answers to Questions 1 and 2; however, you had to change the versions a couple of times.
Concerning Question 3, the most important one, you presented what you said was a sketch of proof, but, for the reasons explained above, I regret to say that I do not believe that it qualifies even as a sketch.
However, I am pleased to hear that, at least, this discussion has helped to find a bug in the code. In my view, this and several other aspects of this discussion confirm that careful proofs (and even definitions) concerning polygon convexity are not that easy, and they are highly susceptible to errors (originating from "obvious" pictures). Therefore, I hope that a standard, generally accepted definition of the polygon convexity and careful, detailed proofs will be more widely recognized and appreciated.
Iosif Pinelis, Professor
Department of Mathematical Sciences
Michigan Technological University
Houghton, Michigan 49931-1295 USA
