cgal-discuss - triangulations with genus > 0
  • To: CGAL <>
  • Subject: triangulations with genus > 0
  • Date: Thu, 18 Oct 2007 15:47:35 +0200
Hi all,
It seems that the CGAL Triangulation_3 does not support holes. When I build
such a triangulation by manipulation the data_structure "by hand", then
the validity check on the data structure fails with "Euler relation
unsatisfied". I guess that could be expected since the manual mentions how
the triangulation is actually a covering of the 4D sphere.
Can anyone comment on the problems of using the CGAL Triangulation for
genus > 0 objects? It is at least possible to traverse the object. Could I
disable the check for conformity to the Euler relation and have something
workable, or would I be bound to run into troubles along the road?
If so, are there plans to support such triangulations in the future?
Matthijs Sypkens Smit
