- To:
- Subject: Re: [cgal-discuss] triangulations with genus > 0
- Date: Mon, 22 Oct 2007 14:51:48 +0200
On Monday 22 October 2007 14:27, Laurent Rineau wrote:
> On Monday 22 October 2007 14:12:15 Matthijs Sypkens Smit wrote:
> > Dear Monique,
> > I want to use the CGAL to inspect/traverse and maybe manipulate the
> > triangulations of 3D higher genus objects. These triangulations are
> > likely to originate from other sources and are built into a CGAL
> > triangulation by my own code.
> If I have understood your needs, you can just a boolean in the cells
> base class, that tells if a given tetrahedron is in you object or not.
> Traversing/inspecting an object using such boolean is easy.
This is not specifically directed at Laurent:
I just realised that the terminology that I'm using might be a bit
confusing. I'm not talking about a surface triangulation of a higher genus
object, but rather of a tetrahedralisation of a 3d object with higher
genus.
I already use the 'tagging' technique in another context, so I am familiar
with the idea. Maybe I do not understand you well, but I do not see an
easy way to detect and fill up the holes in the tetrahedralisations that I
load, with real tets. The holes can have non-convex shapes.
- triangulations with genus > 0, Matthijs Sypkens Smit, 10/18/2007
- Re: [cgal-discuss] triangulations with genus > 0, Sylvain Pion, 10/18/2007
- Re: [cgal-discuss] triangulations with genus > 0, Andreas Fabri, 10/18/2007
- Re: [cgal-discuss] triangulations with genus > 0, Monique . Teillaud, 10/22/2007
- Re: [cgal-discuss] triangulations with genus > 0, Matthijs Sypkens Smit, 10/22/2007
- Re: [cgal-discuss] triangulations with genus > 0, Laurent Rineau, 10/22/2007
