- To:
- Subject: Re: [cgal-discuss] triangulations with genus > 0
- Date: Mon, 22 Oct 2007 14:33:09 +0200
Matthijs Sypkens Smit wrote:
On Monday 22 October 2007 13:51,
wrote:
Dear Matthijs,
I am not sure I understand what you need. Which kind of objects are you
trying to triangulate?
The data structure is in fact able to store more than a triangulation of
the sphere in 4D. We are re-using it for storing the triangulation of a
torus in 4D (3D periodic space).
Do you need triangulations with boundaries? The CGAL triangulations have
some properties, like for instance the fact that each facet is common to
two tetrahedra. So, no boundaries.
Dear Monique,
I want to use the CGAL to inspect/traverse and maybe manipulate the triangulations of 3D higher genus objects.
you mean a triangulation of the interior of a torus in 3d (doughnut or higher genus)?
These triangulations are likely to originate from other sources and are built into a CGAL triangulation by my own code. I suspected that it would be possible to also work with triangulations of higher genus objects with the data structure, but I concluded that there are no guarantees, since the is_valid() method returns false in that case. That is why I asked what kind of problems I can expect. As Andreas pointed out, there are indeed class-methods, such as locate(), that rely on certain assumptions (effectively, that the model is convex, I believe), thus some caution is called for. I hope this clarifies my original question sufficiently.
- triangulations with genus > 0, Matthijs Sypkens Smit, 10/18/2007
- Re: [cgal-discuss] triangulations with genus > 0, Sylvain Pion, 10/18/2007
- Re: [cgal-discuss] triangulations with genus > 0, Andreas Fabri, 10/18/2007
- Re: [cgal-discuss] triangulations with genus > 0, Monique . Teillaud, 10/22/2007
- Re: [cgal-discuss] triangulations with genus > 0, Matthijs Sypkens Smit, 10/22/2007
- Re: [cgal-discuss] triangulations with genus > 0, Laurent Rineau, 10/22/2007
