cgal-discuss - Re: [cgal-discuss] CGAL::join Function
  • To:
  • Subject: Re: [cgal-discuss] CGAL::join Function
  • Date: Thu, 14 Feb 2008 10:53:02 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version:content-type:references:x-google-sender-auth; b=sOGvPynW0PexQJdIWVjNAF6HIPQvwuC9euqwVzgK/+xSBQuS/aGsEWFdALR+ayATeEY1c3CoJn8zmvvuIVrINEyFDY6YBBr14uwb6pyEI7YbwtzinDYuT1nhSGdZTlvsJe9xny0IG7bWNCisU2+BTx+lbCEw5FNVbD5VxLp/4Qk=
What number type? - You shoiuld use a kernel that supports exact construction and exact predicates.
I think the best way is if you send code and data that creates the bug.
On Thu, Feb 14, 2008 at 10:45 AM, Kenneth Tham <> wrote:
Hi,
    I am using a Kernel class inheriting from CGAL::Cartesian<Number_type>.
Regards,
Kenneth
-----Original Message-----
Sent: Thursday, February 14, 2008 3:41 PM
To:
Can send the code that generates the code?
What kernel are you using?
Can you send the data that causes this assertion?
On Thu, Feb 14, 2008 at 8:47 AM, Kenneth Tham <> wrote:
Hi,
  Thanks for your help. I am now trying to debug the algorithm for joining the polygons. There is one case where it needs to merge about 300 polygons. After about 200 times, the program gives the error as shown in the attached file. I'm not really sure what it means. Can anybody help? Thanks.
Regards,
Kenneth
Sent: Tuesday, February 12, 2008 10:23 PM
To:
Kenneth Tham wrote:
>Hi,
>    I am using the CGAL::join function for joining polygon_with_holes_2 objects. In my program, I use the join function for about 10000 times consequtively(trying to join a polygon to a set of polygons). My program takes quite a long time to process this part ( several minutes ). Is it normal for this function to take this amount of time? Thanks.
>Regards,
>Kenneth
First of all you should call the join function just once with a range of
input polygons (or polygons with holes). If you intend to perform other
operations in a sequence, you should call the join member function of
Polygon_set_2 instead of the global join function. Finally, I assume you
are using a exact-prediacte exact-construction kernel (for a good
reason). This means that all operations are caried out in an exact
maner. You can try to expedite the computation by reducing the bit
length of the input coordinates.
 ____  _        ____             _
/_____/_) o    /__________  __  //
(____ (   (    (    (_/ (_/-(-'_(/
                       _/
[This e-mail is confidential and may be privileged. If you are not the
intended recipient, please kindly notify us immediately and delete the message
from your system; please do not copy or use it for any purpose, nor disclose
its contents to any other person. Thank you.]
---ST Electronics Group---
