cgal-discuss - RE: [cgal-discuss] CGAL::join Function
  • To: <>
  • Subject: RE: [cgal-discuss] CGAL::join Function
  • Date: Tue, 19 Feb 2008 16:29:03 +0800
Hi,
Just wondering, is there a function in CGAL for us to plot out the points
in a polygon to view it visually? Thanks.
Regards,
Kenneth
-----Original Message-----
[mailto:]
Sent: Tuesday, February 19, 2008 4:41 AM
To:
Hi Kenneth,
There are a few faults in your example which cause the errors.
I'll refer to the following small part of Q from your example:
Q.push_back (Point_2(103.63966979999999,1.2391405));
Q.push_back (Point_2(103.64162709999999,1.2391810999999999));
Q.push_back (Point_2(103.6397209,1.2391553));
Q.push_back (Point_2(103.6395785,1.2391258000000001));
Q.push_back (Point_2(103.6395201,1.2391295));
Q.push_back (Point_2(103.6394873,1.2391405));
1. Polygon Q maybe simple but is definitely not strictly simple
(points 1 and 4 are the same).The predicate
is_counterclockwise_oriented() has a precondition that allows ony
strictly simple polygons to be tested.
2. 1. Polygon Q is clockwise oriented. The Polygons package reqires
the polygon boundaries to be oriented in a counter clockwise manner
which may be the reason join() fails.
I suggest you try to split your polygon Q into a series of smaller
strictly simple counterclockwise oriented polygons and try to perform
the join operation.
If this doesn't work, try and minimize Q to the smallest polygon that
fails (hopefully less ten 10 vertices), and I'll have a another look...
Sincerely,
Guy Zucker
Quoting Kenneth Tham
> Hi,
> Attached is my code that gives the error. The error occurs when
> the join function is called. I have commented out the code that
> checks for orientation of the Polygon Q as that also gives an error.
> The interesting thing is that if the first three points are not
> added in Polygon Q, the resulting polygon is anti-clockwise
> oriented. But when the 3 points are added, it cannot pass the
> checking. Thanks for your help.
> Regards,
> Kenneth
> From:
> on behalf of Ophir Setter
> Sent: Thu 2/14/2008 4:53 PM
> To:
> Cc:
> Subject: Re: [cgal-discuss] CGAL::join Function
> What number type? - You shoiuld use a kernel that supports exact
> construction and exact predicates.
> I think the best way is if you send code and data that creates the
> bug.
> On Thu, Feb 14, 2008 at 10:45 AM, Kenneth Tham
> wrote:
> Hi,
> I am using a Kernel class inheriting from
> CGAL::Cartesian<Number_type>.
> Regards,
> Kenneth
> From:
> [mailto:]On
> Behalf Of Ophir Setter
> Sent: Thursday, February 14, 2008 3:41 PM
> To:
> Can send the code that generates the code?
> What kernel are you using?
> Can you send the data that causes this assertion?
> On Thu, Feb 14, 2008 at 8:47 AM, Kenneth Tham
> wrote:
> Hi,
> Thanks for your help. I am now trying to
> debug the algorithm
> for joining the polygons. There is one case where it needs to merge
> about 300 polygons. After about 200 times, the program gives the
> error as shown in the attached file. I'm not really sure what it
> means. Can anybody help? Thanks.
> Regards,
> Kenneth
> From: Efi Fogel
> [mailto:]
> Sent: Tuesday, February 12, 2008 10:23 PM
> To:
> Function
> Kenneth Tham wrote:
> >Hi,
> > I am using the CGAL::join function for
> joining
> polygon_with_holes_2 objects. In my program, I use the join function
> for about 10000 times consequtively(trying to join a polygon to a
> set of polygons). My program takes quite a long time to process
> this part ( several minutes ). Is it normal for this function to
> take this amount of time? Thanks.
> >Regards,
> >Kenneth
> First of all you should call the join
> function just once with a range of
> input polygons (or polygons with holes). If
> you intend to perform other
> operations in a sequence, you should call the
> join member function of
> Polygon_set_2 instead of the global join
> function. Finally, I assume you
> are using a exact-prediacte
> exact-construction kernel (for a good
> reason). This means that all operations are
> caried out in an exact
> maner. You can try to expedite the
> computation by reducing the bit
> length of the input coordinates.
> ____ _ ____ _
> /_____/_) o /__________ __ //
> (____ ( ( ( (_/ (_/-(-'_(/
> _/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
> [This e-mail is confidential and may be
> privileged. If you are not the
> intended recipient, please kindly notify us
> immediately and
> delete the message
> from your system; please do not copy or use
> it for any purpose,
> nor disclose
> its contents to any other person. Thank you.]
> ---ST Electronics Group---
----- End forwarded message -----
