- To: <>
- Subject: RE: [cgal-discuss] CGAL::join Function
- Date: Sat, 16 Feb 2008 12:09:36 +0800
Hi,
Attached is my code that gives the error. The error occurs when the join
function is called. I have commented out the code that checks for orientation
of the Polygon Q as that also gives an error. The interesting thing is that
if the first three points are not added in Polygon Q, the resulting polygon
is anti-clockwise oriented. But when the 3 points are added, it cannot pass
the checking. Thanks for your help.
Regards,
Kenneth
-----Original Message-----
on behalf of Ophir Setter
Sent: Thu 2/14/2008 4:53 PM
To:
Cc:
Subject: Re: [cgal-discuss] CGAL::join Function
What number type? - You shoiuld use a kernel that supports exact
construction and exact predicates.
I think the best way is if you send code and data that creates the
bug.
On Thu, Feb 14, 2008 at 10:45 AM, Kenneth Tham
wrote:
Hi,
I am using a Kernel class inheriting from
CGAL::Cartesian<Number_type>.
Regards,
Kenneth
[mailto:]On
Behalf Of Ophir Setter
Sent: Thursday, February 14, 2008 3:41 PM
To:
Can send the code that generates the code?
What kernel are you using?
Can you send the data that causes this assertion?
On Thu, Feb 14, 2008 at 8:47 AM, Kenneth Tham
wrote:
Hi,
Thanks for your help. I am now trying to
debug the algorithm for joining the polygons. There is one case where it
needs to merge about 300 polygons. After about 200 times, the program gives
the error as shown in the attached file. I'm not really sure what it means.
Can anybody help? Thanks.
Regards,
Kenneth
[mailto:]
Sent: Tuesday, February 12, 2008 10:23 PM
To:
Function
Kenneth Tham wrote:
>Hi,
> I am using the CGAL::join function for
joining polygon_with_holes_2 objects. In my program, I use the join function
for about 10000 times consequtively(trying to join a polygon to a set of
polygons). My program takes quite a long time to process this part ( several
minutes ). Is it normal for this function to take this amount of time? Thanks.
>Regards,
>Kenneth
First of all you should call the join
function just once with a range of
input polygons (or polygons with holes). If
you intend to perform other
operations in a sequence, you should call the
join member function of
Polygon_set_2 instead of the global join
function. Finally, I assume you
are using a exact-prediacte
exact-construction kernel (for a good
reason). This means that all operations are
caried out in an exact
maner. You can try to expedite the
computation by reducing the bit
length of the input coordinates.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
[This e-mail is confidential and may be
privileged. If you are not the
intended recipient, please kindly notify us
immediately and delete the message
from your system; please do not copy or use
it for any purpose, nor disclose
its contents to any other person. Thank you.]
---ST Electronics Group---
<<winmail.dat>>
- RE: [cgal-discuss] CGAL::join Function, Kenneth Tham, 02/14/2008
- Re: [cgal-discuss] CGAL::join Function, Ophir Setter, 02/14/2008
- <Possible follow-up(s)>
- RE: [cgal-discuss] CGAL::join Function, Kenneth Tham, 02/16/2008
- [cgal-discuss] How to determine if a Kernel type is standard or extended type?, Max, 02/17/2008
- Re: [cgal-discuss] How to determine if a Kernel type is standard or extended type?, Andreas Fabri, 02/17/2008
- Re: [cgal-discuss] How to determine if a Kernel type is standard or extended type?, Peter Hachenberger, 02/18/2008
- RE: [cgal-discuss] CGAL::join Function, guyzucke, 02/18/2008
- RE: [cgal-discuss] CGAL::join Function, Kenneth Tham, 02/19/2008
- RE: [cgal-discuss] CGAL::join Function, guyzucke, 02/20/2008
- Re: [cgal-discuss] CGAL::join Function, Andreas Fabri, 02/19/2008
