Re: [cgal-discuss] How to determine if a Kernel type is standardor extended type?
- To: "" <>
- Subject: Re: [cgal-discuss] How to determine if a Kernel type is standardor extended type?
- Date: Tue, 19 Feb 2008 10:39:19 +0800
- Disposition-notification-to: "Max" <>
- Organization: LoadCom
Hello Peter,
Thank you for your further information.
So, for Nef_polyhedron_3, there's an extra means to
check the kernel type at runtime.
B/Rgds
Max
>Hi Max,
>it is not necessary to put this into the Kernel_traits, since only Nef
>polyhedra use extended kernels. The class Nef_polyhedron_3 has static
>functions
>bool is_standard_kernel()
>bool is_extended_kernel()
>Also the type
>CGAL::Is_extended_kernel<Kernel>
>evaluates to Tag_true or Tag_false depending on the given Kernel. If
>Is_extended_kernel is not known, then include CGAL/Is_extended_kernel.h.
>Peter
>On Sun, 2008-02-17 at 12:44 +0800, Max wrote:
>> Hi,
>> I hope I could determine the type of a Kernel type at either compile time
>> or runtime.
>> I guess the relevant stuff would be in Kernel_traits, but I'm wrong.
>> And I could not found such function or traits template to meet my need.
>> Thanks for any help.
>> B/Rgds
>> Max
>You are currently subscribed to cgal-discuss.
>To unsubscribe or access the archives, go to
>https://lists-sop.inria.fr/wws/info/cgal-discuss
- RE: [cgal-discuss] CGAL::join Function, Kenneth Tham, 02/14/2008
- Re: [cgal-discuss] CGAL::join Function, Ophir Setter, 02/14/2008
- <Possible follow-up(s)>
- RE: [cgal-discuss] CGAL::join Function, Kenneth Tham, 02/16/2008
- [cgal-discuss] How to determine if a Kernel type is standard or extended type?, Max, 02/17/2008
- Re: [cgal-discuss] How to determine if a Kernel type is standard or extended type?, Andreas Fabri, 02/17/2008
- Re: [cgal-discuss] How to determine if a Kernel type is standard or extended type?, Peter Hachenberger, 02/18/2008
- Re: [cgal-discuss] How to determine if a Kernel type is standardor extended type?, Max, 02/19/2008
- RE: [cgal-discuss] CGAL::join Function, guyzucke, 02/18/2008
- RE: [cgal-discuss] CGAL::join Function, Kenneth Tham, 02/19/2008
- RE: [cgal-discuss] CGAL::join Function, guyzucke, 02/20/2008
- Re: [cgal-discuss] CGAL::join Function, Andreas Fabri, 02/19/2008
