Re: [cgal-discuss] How to determine if a Kernel type is standard or extended type?
- To:
- Subject: Re: [cgal-discuss] How to determine if a Kernel type is standard or extended type?
- Date: Mon, 18 Feb 2008 11:53:40 +0100
Hi Max,
it is not necessary to put this into the Kernel_traits, since only Nef
polyhedra use extended kernels. The class Nef_polyhedron_3 has static
functions
bool is_standard_kernel()
bool is_extended_kernel()
Also the type
CGAL::Is_extended_kernel<Kernel>
evaluates to Tag_true or Tag_false depending on the given Kernel. If
Is_extended_kernel is not known, then include CGAL/Is_extended_kernel.h.
Peter
On Sun, 2008-02-17 at 12:44 +0800, Max wrote:
> Hi,
> I hope I could determine the type of a Kernel type at either compile time
> or runtime.
> I guess the relevant stuff would be in Kernel_traits, but I'm wrong.
> And I could not found such function or traits template to meet my need.
> Thanks for any help.
> B/Rgds
> Max
- RE: [cgal-discuss] CGAL::join Function, Kenneth Tham, 02/14/2008
- Re: [cgal-discuss] CGAL::join Function, Ophir Setter, 02/14/2008
- <Possible follow-up(s)>
- RE: [cgal-discuss] CGAL::join Function, Kenneth Tham, 02/16/2008
- [cgal-discuss] How to determine if a Kernel type is standard or extended type?, Max, 02/17/2008
- Re: [cgal-discuss] How to determine if a Kernel type is standard or extended type?, Andreas Fabri, 02/17/2008
- Re: [cgal-discuss] How to determine if a Kernel type is standard or extended type?, Peter Hachenberger, 02/18/2008
- RE: [cgal-discuss] CGAL::join Function, guyzucke, 02/18/2008
- RE: [cgal-discuss] CGAL::join Function, Kenneth Tham, 02/19/2008
- RE: [cgal-discuss] CGAL::join Function, guyzucke, 02/20/2008
- Re: [cgal-discuss] CGAL::join Function, Andreas Fabri, 02/19/2008
