- To:
- Subject: RE: [cgal-discuss] CGAL::join Function
- Date: Mon, 18 Feb 2008 22:40:42 +0200
Hi Kenneth,
There are a few faults in your example which cause the errors.
I'll refer to the following small part of Q from your example:
Q.push_back (Point_2(103.63966979999999,1.2391405));
Q.push_back (Point_2(103.64162709999999,1.2391810999999999));
Q.push_back (Point_2(103.6397209,1.2391553));
Q.push_back (Point_2(103.6395785,1.2391258000000001));
Q.push_back (Point_2(103.6395201,1.2391295));
Q.push_back (Point_2(103.6394873,1.2391405));
1. Polygon Q maybe simple but is definitely not strictly simple
(points 1 and 4 are the same).The predicate
is_counterclockwise_oriented() has a precondition that allows ony
strictly simple polygons to be tested.
2. 1. Polygon Q is clockwise oriented. The Polygons package reqires
the polygon boundaries to be oriented in a counter clockwise manner
which may be the reason join() fails.
I suggest you try to split your polygon Q into a series of smaller
strictly simple counterclockwise oriented polygons and try to perform
the join operation.
If this doesn't work, try and minimize Q to the smallest polygon that
fails (hopefully less ten 10 vertices), and I'll have a another look...
Sincerely,
Guy Zucker
Quoting Kenneth Tham
Hi,
Attached is my code that gives the error. The error occurs when the join function is called. I have commented out the code that checks for orientation of the Polygon Q as that also gives an error. The interesting thing is that if the first three points are not added in Polygon Q, the resulting polygon is anti-clockwise oriented. But when the 3 points are added, it cannot pass the checking. Thanks for your help.
Regards,
Kenneth
-----Original Message-----
on behalf of Ophir Setter
Sent: Thu 2/14/2008 4:53 PM
To:
Cc:
Subject: Re: [cgal-discuss] CGAL::join Function
What number type? - You shoiuld use a kernel that supports exact construction and exact predicates.
I think the best way is if you send code and data that creates the
bug.
On Thu, Feb 14, 2008 at 10:45 AM, Kenneth Tham <> wrote:
Hi,
I am using a Kernel class inheriting from
CGAL::Cartesian<Number_type>.
Regards,
Kenneth
Sent: Thursday, February 14, 2008 3:41 PM
To:
Can send the code that generates the code?
What kernel are you using?
Can you send the data that causes this assertion?
On Thu, Feb 14, 2008 at 8:47 AM, Kenneth Tham <> wrote:
Hi,
Thanks for your help. I am now trying to debug the algorithm for joining the polygons. There is one case where it needs to merge about 300 polygons. After about 200 times, the program gives the error as shown in the attached file. I'm not really sure what it means. Can anybody help? Thanks.
Regards,
Kenneth
[mailto:]
Sent: Tuesday, February 12, 2008 10:23 PM
To:
Function
Kenneth Tham wrote:
>Hi,
> I am using the CGAL::join function for joining polygon_with_holes_2 objects. In my program, I use the join function for about 10000 times consequtively(trying to join a polygon to a set of polygons). My program takes quite a long time to process this part ( several minutes ). Is it normal for this function to take this amount of time? Thanks.
>Regards,
>Kenneth
First of all you should call the join
function just once with a range of
input polygons (or polygons with holes). If
you intend to perform other
operations in a sequence, you should call the
join member function of
Polygon_set_2 instead of the global join
function. Finally, I assume you
are using a exact-prediacte
exact-construction kernel (for a good
reason). This means that all operations are
caried out in an exact
maner. You can try to expedite the
computation by reducing the bit
length of the input coordinates.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
[This e-mail is confidential and may be
privileged. If you are not the
intended recipient, please kindly notify us immediately and delete the message
from your system; please do not copy or use it for any purpose, nor disclose
its contents to any other person. Thank you.]
---ST Electronics Group---
----- End forwarded message -----
- RE: [cgal-discuss] CGAL::join Function, Kenneth Tham, 02/14/2008
- Re: [cgal-discuss] CGAL::join Function, Ophir Setter, 02/14/2008
- <Possible follow-up(s)>
- RE: [cgal-discuss] CGAL::join Function, Kenneth Tham, 02/16/2008
- [cgal-discuss] How to determine if a Kernel type is standard or extended type?, Max, 02/17/2008
- Re: [cgal-discuss] How to determine if a Kernel type is standard or extended type?, Andreas Fabri, 02/17/2008
- Re: [cgal-discuss] How to determine if a Kernel type is standard or extended type?, Peter Hachenberger, 02/18/2008
- RE: [cgal-discuss] CGAL::join Function, guyzucke, 02/18/2008
- RE: [cgal-discuss] CGAL::join Function, Kenneth Tham, 02/19/2008
- RE: [cgal-discuss] CGAL::join Function, guyzucke, 02/20/2008
- Re: [cgal-discuss] CGAL::join Function, Andreas Fabri, 02/19/2008
