- To: Kenneth Tham <>,
- Subject: RE: [cgal-discuss] CGAL::join Function
- Date: Wed, 20 Feb 2008 10:54:57 +0200
Hi,
Generally, a stricly simple polygon is one whose outer boundary contains every vertice only once (except the first/last vertice) while a simple polygon may have the same vertice appear twice or more on the outer boundary.
Simple, but not necessarily strictly simple, polygons are allowed as the outside boundaries of polygons with holes.
The is_simple() query checks for if a polygon is stirctly simple.
Here are the relevant parts from the user manual:
A polygon P is said to be simple (or Jordan) if the only points of the plane belonging to two polygon edges of P are the polygon vertices of P. Namely, the polygon edges are pairwise disjoint in their interior. Such a polygon has a well-defined interior and exterior and is topologically equivalent to a disk. A polygon in our context must be simple and its vertices must be ordered in a counterclockwise direction around the interior of the polygon.
A polygon whose boundary contains the same vertex twice or more is connected and simple but not necessarily strictly simple.
A polygon with holes represents a point set that may be bounded or unbounded. In case of a bounded set, its outer boundary is represented as a simple (but not necessarily strictly simple) polygon, whose vertices are oriented in a counterclockwise order around the interior of the set. In addition, the set may contain holes, where each hole is represented as a strictly simple polygon, whose vertices are oriented in a clockwise order around the interior of the hole.
Using the topological terminology, a general polygon can represent any simply-connected point set whose boundary is a strictly simple curve. Such a polygon is a model of the GeneralPolygon_2 concept.
For further elaboration look at the Boolean Set Operations_2 user manual.
Good day,
Guy
Quoting Kenneth Tham
Hi,
Thanks for your help. Yes, the polygon has 1 common point so it is probably not simple, which may be the cause of the failure. I have added a check using the method is_simple() to check if the joined polygon is simple after joining. It seems to work better with the code now. What is the difference between simple and strictly simple polygons? Thank you.
Regards,
Kenneth
-----Original Message-----
[mailto:]
Sent: Tuesday, February 19, 2008 4:41 AM
To:
Hi Kenneth,
There are a few faults in your example which cause the errors.
I'll refer to the following small part of Q from your example:
Q.push_back (Point_2(103.63966979999999,1.2391405));
Q.push_back (Point_2(103.64162709999999,1.2391810999999999));
Q.push_back (Point_2(103.6397209,1.2391553));
Q.push_back (Point_2(103.6395785,1.2391258000000001));
Q.push_back (Point_2(103.6395201,1.2391295));
Q.push_back (Point_2(103.6394873,1.2391405));
1. Polygon Q maybe simple but is definitely not strictly simple
(points 1 and 4 are the same).The predicate
is_counterclockwise_oriented() has a precondition that allows ony
strictly simple polygons to be tested.
2. 1. Polygon Q is clockwise oriented. The Polygons package reqires
the polygon boundaries to be oriented in a counter clockwise manner
which may be the reason join() fails.
I suggest you try to split your polygon Q into a series of smaller
strictly simple counterclockwise oriented polygons and try to perform
the join operation.
If this doesn't work, try and minimize Q to the smallest polygon that
fails (hopefully less ten 10 vertices), and I'll have a another look...
Sincerely,
Guy Zucker
Hi,
Attached is my code that gives the error. The error occurs when
the join function is called. I have commented out the code that
checks for orientation of the Polygon Q as that also gives an error.
The interesting thing is that if the first three points are not
added in Polygon Q, the resulting polygon is anti-clockwise
oriented. But when the 3 points are added, it cannot pass the
checking. Thanks for your help.
Regards,
Kenneth
on behalf of Ophir Setter
Sent: Thu 2/14/2008 4:53 PM
To:
Cc:
Subject: Re: [cgal-discuss] CGAL::join Function
What number type? - You shoiuld use a kernel that supports exact
construction and exact predicates.
I think the best way is if you send code and data that creates the
bug.
On Thu, Feb 14, 2008 at 10:45 AM, Kenneth Tham
wrote:
Hi,
I am using a Kernel class inheriting from CGAL::Cartesian<Number_type>.
Regards,
Kenneth
[mailto:]On
Behalf Of Ophir Setter
Sent: Thursday, February 14, 2008 3:41 PM
To:
Can send the code that generates the code?
What kernel are you using?
Can you send the data that causes this assertion?
On Thu, Feb 14, 2008 at 8:47 AM, Kenneth Tham
wrote:
Hi,
Thanks for your help. I am now trying to
debug the algorithm
for joining the polygons. There is one case where it needs to merge
about 300 polygons. After about 200 times, the program gives the
error as shown in the attached file. I'm not really sure what it
means. Can anybody help? Thanks.
Regards,
Kenneth
[mailto:]
Sent: Tuesday, February 12, 2008 10:23 PM
To:
Function
Kenneth Tham wrote:
>Hi,
> I am using the CGAL::join function for
joining
polygon_with_holes_2 objects. In my program, I use the join function
for about 10000 times consequtively(trying to join a polygon to a
set of polygons). My program takes quite a long time to process
this part ( several minutes ). Is it normal for this function to
take this amount of time? Thanks.
>Regards,
>Kenneth
First of all you should call the join
function just once with a range of
input polygons (or polygons with holes). If
you intend to perform other
operations in a sequence, you should call the
join member function of
Polygon_set_2 instead of the global join
function. Finally, I assume you
are using a exact-prediacte
exact-construction kernel (for a good
reason). This means that all operations are
caried out in an exact
maner. You can try to expedite the
computation by reducing the bit
length of the input coordinates.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
[This e-mail is confidential and may be
privileged. If you are not the
intended recipient, please kindly notify us
immediately and
delete the message
from your system; please do not copy or use
it for any purpose,
nor disclose
its contents to any other person. Thank you.]
---ST Electronics Group---
----- End forwarded message -----
- RE: [cgal-discuss] CGAL::join Function, (continued)
- RE: [cgal-discuss] CGAL::join Function, Kenneth Tham, 02/14/2008
- Re: [cgal-discuss] CGAL::join Function, Ophir Setter, 02/14/2008
- RE: [cgal-discuss] CGAL::join Function, Kenneth Tham, 02/16/2008
- [cgal-discuss] How to determine if a Kernel type is standard or extended type?, Max, 02/17/2008
- Re: [cgal-discuss] How to determine if a Kernel type is standard or extended type?, Andreas Fabri, 02/17/2008
- Re: [cgal-discuss] How to determine if a Kernel type is standard or extended type?, Peter Hachenberger, 02/18/2008
- RE: [cgal-discuss] CGAL::join Function, guyzucke, 02/18/2008
- RE: [cgal-discuss] CGAL::join Function, Kenneth Tham, 02/19/2008
- RE: [cgal-discuss] CGAL::join Function, guyzucke, 02/20/2008
- Re: [cgal-discuss] CGAL::join Function, Andreas Fabri, 02/19/2008
