- To:
- Subject: Re: [cgal-discuss] Problem with Visual Studio 2005: default library
- Date: Thu, 18 Sep 2008 10:11:54 +0200
a écrit :
Hi,
i have to compile a Visual Studio project that need the CGAL library.
I have installed the library and the project compiles without prblems, but the
Linker throw an error:
defaultlib 'MSVCRT' conflicts with use of other libs; fatal error LNK1169: one or more multiply defined symbols found
Can you help me to fix this problem?
Andrea Brandolese
Hi,
Which version of CGAL are you using?
Laurent Saboret
INRIA Sophia-Antipolis
- [cgal-discuss] Problem with Visual Studio 2005: default library and CGAL library conflict, brandorama, 09/18/2008
- Re: [cgal-discuss] Problem with Visual Studio 2005: default library, Laurent Saboret, 09/18/2008
- Re: [cgal-discuss] Problem with Visual Studio 2005: default library, brandorama, 09/18/2008
- Re: [cgal-discuss] Problem with Visual Studio 2005: default library, Laurent Rineau, 09/18/2008
- Re: [cgal-discuss] Problem with Visual Studio 2005: default libraryand CGAL library conflict, Max, 09/19/2008
- Re: [cgal-discuss] Problem with Visual Studio 2005: default, jmh, 09/19/2008
- Re: [cgal-discuss] Problem with Visual Studio 2005: default, Max, 09/22/2008
- <Possible follow-up(s)>
- Re: [cgal-discuss] Problem with Visual Studio 2005: default library and CGAL library conflict, Mahmood Naderan, 09/19/2008
