- To:
- Subject: Re: [cgal-discuss] Problem with Visual Studio 2005: default
- Date: Fri, 19 Sep 2008 11:10:54 +0200 (CEST)
- Importance: Normal
It compiles for me in VS2005 and VS2008. As an exercise, try in the
Linker->Input, to tell the compiler to ignore the library MSVCRT. Google
how to ignore specific libraries if you don't know how to
Jens Munk Hansen
>>i have to compile a Visual Studio project that need the CGAL library.
>>I have installed the library and the project compiles without prblems,
>> but the
>>Linker throw an error:
>> defaultlib 'MSVCRT' conflicts with use of other libs;
>> fatal error LNK1169: one or more multiply defined symbols found
> I use CGAL 3.2.1 with visual studio 2005 without any problem.
> First build the solutions in the "src" folder, so that the CGAL libraries
> are built. Then before you sompile your project, check to see if
> CGAL examples and demos run without error.
> Mahmood Naderan
> ----- Original Message ----
> From:
> To:
> Sent: Thursday, September 18, 2008 11:02:48 AM
> Subject: [cgal-discuss] Problem with Visual Studio 2005: default library
> and CGAL library conflict
> Hi,
> I have installed the library and the project compiles without prblems, but
> the
> Can you help me to fix this problem?
> Andrea Brandolese
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Problem with Visual Studio 2005: default library and CGAL library conflict, brandorama, 09/18/2008
- Re: [cgal-discuss] Problem with Visual Studio 2005: default library, Laurent Saboret, 09/18/2008
- Re: [cgal-discuss] Problem with Visual Studio 2005: default library, brandorama, 09/18/2008
- Re: [cgal-discuss] Problem with Visual Studio 2005: default library, Laurent Rineau, 09/18/2008
- Re: [cgal-discuss] Problem with Visual Studio 2005: default libraryand CGAL library conflict, Max, 09/19/2008
- Re: [cgal-discuss] Problem with Visual Studio 2005: default, jmh, 09/19/2008
- Re: [cgal-discuss] Problem with Visual Studio 2005: default, Max, 09/22/2008
- <Possible follow-up(s)>
- Re: [cgal-discuss] Problem with Visual Studio 2005: default library and CGAL library conflict, Mahmood Naderan, 09/19/2008
