cgal-discuss - Re: [cgal-discuss] Problem with Visual Studio 2005: default library
  • To: <>
  • Subject: Re: [cgal-discuss] Problem with Visual Studio 2005: default library
  • Date: Thu, 18 Sep 2008 10:35:15 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:from:to:references:subject:date:mime-version :content-type:content-transfer-encoding:x-priority:x-msmail-priority :x-mailer:x-mimeole; b=nqHSQi95hv+2zB6pVEI1u021+Fv3AKTd7QVm/BE+LslM/EBaAZit/j53RwJ/DLo4ux EOGUPpBSArDYSO0AvSJVaCIH8+buikSgpj7Fjocc38Yown0Bz2rj4Wqd+p3SXFgVEJh4 mrmvdlMMG2Tz/8DLqlYRvJskybjAhmZiir6oo=
I tried to use the last version CGAL 3.3.1, but in this version some classes are deprecated and the project that i have to compile need this classes; for this reason i installed the 3.2.1 version.
----- Original Message ----- From: "Laurent Saboret" <>
To:
Sent: Thursday, September 18, 2008 10:11 AM
a écrit :
Hi,
i have to compile a Visual Studio project that need the CGAL library.
I have installed the library and the project compiles without prblems, but the
Linker throw an error:
defaultlib 'MSVCRT' conflicts with use of other libs; fatal error LNK1169: one or more multiply defined symbols found
Can you help me to fix this problem?
Andrea Brandolese
Hi,
Which version of CGAL are you using?
Laurent Saboret
INRIA Sophia-Antipolis
