cgal-discuss - Re: [cgal-discuss] Problem with Visual Studio 2005: default library
  • To:
  • Subject: Re: [cgal-discuss] Problem with Visual Studio 2005: default library
  • Date: Thu, 18 Sep 2008 10:57:37 +0200
I recommend you to use CGAL 3.3.1 as:
- the problem that you reported below does not occur in 3.3.1
- 3.2.1 does not support officially Visual Studio 2005
If you want to use 3.2.1 anyway:
You must make sure that you use the same Windows runtime when compiling your application and all libraries linked with it. As CGAL and the third-party libraries shipped with it are compiled with the DLL multithread (/MD) runtime, the easiest way is to use the same runtime for your application.
See http://msdn.microsoft.com/fr-fr/library/2kzt1wy3(en-us,VS.80).aspx
Best regards,
Laurent Saboret
brandorama a écrit :
I tried to use the last version CGAL 3.3.1, but in this version some classes are deprecated and the project that i have to compile need this classes; for this reason i installed the 3.2.1 version.
----- Original Message ----- From: "Laurent Saboret" <>
To:
Sent: Thursday, September 18, 2008 10:11 AM
a écrit :
Hi,
i have to compile a Visual Studio project that need the CGAL library.
I have installed the library and the project compiles without prblems, but the
Linker throw an error:
defaultlib 'MSVCRT' conflicts with use of other libs; fatal error LNK1169: one or more multiply defined symbols found
Can you help me to fix this problem?
Andrea Brandolese
Hi,
Which version of CGAL are you using?
Laurent Saboret
INRIA Sophia-Antipolis
