cgal-discuss - Re: [cgal-discuss] Problem with Visual Studio 2005: default
  • To:
  • Subject: Re: [cgal-discuss] Problem with Visual Studio 2005: default
  • Date: Fri, 19 Sep 2008 12:49:54 +0200 (CEST)
  • Importance: Normal
You shouldn't.
What you can do, is to recompile everything - and I mean everything. Clean
the solution. Your problem looks like an old object file resides which has
been linked to and older version of MSVCRT.
/Jens Munk Hansen
> I encountered the similar problem with CGAL3.3.1+VS2008.
> Error message:
> libcmt.lib(tidtable.obj) : error LNK2005: __encode_pointer already defined
> in msvcrt.lib(MSVCR90.dll)
> I solved this problem by setting libcmt.lib as 'Ignore specific library'
> in the project configuration.
> But I feel uncomfortable with this solution.
> B/Rgds
> Max
>>Hi,
>>i have to compile a Visual Studio project that need the CGAL library.
>>I have installed the library and the project compiles without prblems,
>> but the
>>Linker throw an error:
>> defaultlib 'MSVCRT' conflicts with use of other libs;
>> fatal error LNK1169: one or more multiply defined symbols found
>>Can you help me to fix this problem?
>>Andrea Brandolese
>>You are currently subscribed to cgal-discuss.
>>To unsubscribe or access the archives, go to
>>https://lists-sop.inria.fr/wws/info/cgal-discuss
