Re: [cgal-discuss] Problem with Visual Studio 2005: default libraryand CGAL library conflict
- To: "" <>
- Subject: Re: [cgal-discuss] Problem with Visual Studio 2005: default libraryand CGAL library conflict
- Date: Fri, 19 Sep 2008 09:03:39 +0800
- Organization: Max
I encountered the similar problem with CGAL3.3.1+VS2008.
Error message:
libcmt.lib(tidtable.obj) : error LNK2005: __encode_pointer already defined in
msvcrt.lib(MSVCR90.dll)
I solved this problem by setting libcmt.lib as 'Ignore specific library' in
the project configuration.
But I feel uncomfortable with this solution.
B/Rgds
Max
>Hi,
>i have to compile a Visual Studio project that need the CGAL library.
>I have installed the library and the project compiles without prblems, but
>the
>Linker throw an error:
> defaultlib 'MSVCRT' conflicts with use of other libs;
> fatal error LNK1169: one or more multiply defined symbols found
>Can you help me to fix this problem?
>Andrea Brandolese
>You are currently subscribed to cgal-discuss.
>To unsubscribe or access the archives, go to
>https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Problem with Visual Studio 2005: default library and CGAL library conflict, brandorama, 09/18/2008
- Re: [cgal-discuss] Problem with Visual Studio 2005: default library, Laurent Saboret, 09/18/2008
- Re: [cgal-discuss] Problem with Visual Studio 2005: default library, brandorama, 09/18/2008
- Re: [cgal-discuss] Problem with Visual Studio 2005: default library, Laurent Rineau, 09/18/2008
- Re: [cgal-discuss] Problem with Visual Studio 2005: default libraryand CGAL library conflict, Max, 09/19/2008
- Re: [cgal-discuss] Problem with Visual Studio 2005: default, jmh, 09/19/2008
- Re: [cgal-discuss] Problem with Visual Studio 2005: default, Max, 09/22/2008
- <Possible follow-up(s)>
- Re: [cgal-discuss] Problem with Visual Studio 2005: default library and CGAL library conflict, Mahmood Naderan, 09/19/2008
