- To:
- Subject: Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges
- Date: Mon, 03 Nov 2008 12:13:12 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:subject:references :in-reply-to:content-type:content-transfer-encoding; b=cLU6At9gzSkcVANpLChmZYm6siZdtGavg3pQt8ISIE8yd87JKuDEjv97NtjPbe3yj8 b2S+BJIK9jFC0YmsOnUBR65qGhFnXlLbed17lJHP2ll/qlVkFkA3FEGOhA82t0KkVj1t 4yqqPayI5loABfzfjmrQGt7L5y4ExnAG5CvC8=
Very Good joke. You made my day ;)
But if you had tried to understand you would know, that I`m only
searching for a method which tells me, if the triangulations gone wrong
because of the same x_y coordinates and so on.
Best.,
Dennis
Andreas Fabri schrieb:
> Dennis Endt wrote:
>> Monique Teillaud schrieb:
>>> If you are lucky (= your points really don't belong to a plane
>>> parallel to any xy,xz,yz plane), you will get the same triangulation
>>> three times, which is not what you want (I guess so). Yhen using one
>>> of these random traits should give you what you want.
>>> If you are less lucky, one of the computationa will crash. Then, use
>>> one of the other two.
>>> I'm afraid that's the best you can do if you don't know anything about
>>> your data, except the fact that they are almost coplanar.
>>> best,
>>> Monique Teillaud
>> Hi,
>> thanks so far for your help.
>> My last question is:
>> How can I check if a computational will crash? What is the best method
>> for this?
> You should
> #include <CGAL/Cristall_ball.h>
> It provides a constructor with an unsigned int specifying the number
> of milliseconds you want to look into the future.
> It's an undocumented feature, but that is what we recommend for
> avoiding planes to fall from the sky.
>> I tried to use is_valid(), but this didn`t worked. Is it enough to check
>> for the number_of_vertices != 0 of a fassade?
>> Best,
>> Dennis
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, (continued)
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Dennis Endt, 11/02/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Monique Teillaud, 11/02/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Nico Kruithof, 11/02/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Monique Teillaud, 11/03/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Nico Kruithof, 11/03/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Olivier Devillers, 11/03/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Dennis Endt, 11/03/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Andreas Fabri, 11/03/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Bernd Gaertner, 11/03/2008
