cgal-discuss - Re: [cgal-discuss] cmake does not identify boost
  • To:
  • Cc: "Amir Vaxman" <>
  • Subject: Re: [cgal-discuss] cmake does not identify boost
  • Date: Tue, 2 Feb 2010 14:10:22 +0100
On Tuesday 02 February 2010 13:43:20 Amir Vaxman wrote:
> Oh thanks, I didn't do bjam install (didn't see it in any documentation?)
> the boost documentation is very frustrating; I am trying to install it
> manually, since I want to work 64-bit, and BoostPro only installs 32-bit
> precompiled binaries. If anyone has complete instructions on how to setup
> CGAL, beginning from boost and on to work with 64-bit, I'd be very
> grateful.
I have seen the mention of bjam install here:
http://www.boost.org/doc/libs/1_41_0/more/getting_started/unix-variants.html#easy-build-and-install
There are pages on the web that present steps to install Boost step-by-step
and then compile CGAL. For example:
http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows
(Installation on Windows, 32 bits, as far as I can see.)
http://alice.loria.fr/WIKI/index.php/Graphite/CGAL
(Speaks about CGAL-3.4, but the same should work for CGAL-3.5. Mention
32/64 bits.)
More generally:
http://www.google.com/search?q=install+boost+and+CGAL
Laurent Rineau, PhD
