- To: <>
- Subject: RE: [cgal-discuss] cmake does not identify boost
- Date: Wed, 3 Feb 2010 18:10:55 +0200
I ran it from the directory of cmake 2.8\bin itself, which is also produced
to the "which" command. However, I saw that all my directories concerning
the "which" command are given as /cygdrive/c... I find it odd, since I run
everything on a windows server, which also has cygwin installed upon for
other matters, but I don't know what it has got to do with it.
%PATH% is set to the cmake 2.8 directory before any other version.
-----Original Message-----
[mailto:]
Sent: Wednesday, February 03, 2010 5:57 PM
To:
Subject: Re: [cgal-discuss] cmake does not identify boost
On Wednesday 03 February 2010 16:38:40 Amir Vaxman wrote:
> I am getting the "running from cygwin" notice in cmake even when I
> installed the brand new cmake 2.8 version
Are you sure you launched branch new cmake you just installed?
What is the content of %PATH%? In your shell, what says "which cmake-gui"?
What if you call cmake-gui using its full path (something like "C:\Program
Files\CMake-2.6\bin\cmake-gui.exe")?
> (and it does show that I am
> using 2.8 in the log). And still - no STL. I am beginning to think that
it
> may be a problem of the VC2008 directory structure not matching something
> that CGAL makes.
CGAL is tested every night with VC2008 (32 bits, though).
Laurent Rineau, PhD
- RE: [cgal-discuss] cmake does not identify boost, (continued)
- RE: [cgal-discuss] cmake does not identify boost, Amir Vaxman, 02/02/2010
- Re: [cgal-discuss] cmake does not identify boost, Laurent Rineau (GeometryFactory), 02/02/2010
- RE: [cgal-discuss] cmake does not identify boost, Amir Vaxman, 02/03/2010
- Re: [cgal-discuss] cmake does not identify boost, Laurent Rineau (GeometryFactory), 02/03/2010
- RE: [cgal-discuss] cmake does not identify boost, Amir Vaxman, 02/10/2010
- Re: [cgal-discuss] cmake does not identify boost, Yang Liu, 02/10/2010
- [cgal-discuss] Pb with mesh_3D_image example, Sylvain Gouttebroze, 02/10/2010
