- To: <>
- Subject: RE: [cgal-discuss] cmake does not identify boost
- Date: Wed, 10 Feb 2010 11:41:25 +0200
Grr, this is taking a lot of my time. Does anyone perchance has built
binaries of CGAL 3.5.1 for VC2008 Win64? It might be enough.
Thanks, Amir.
-----Original Message-----
[mailto:]
Sent: Wednesday, February 03, 2010 6:37 PM
To:
Subject: Re: [cgal-discuss] cmake does not identify boost
On Wednesday 03 February 2010 17:10:55 Amir Vaxman wrote:
> I ran it from the directory of cmake 2.8\bin itself, which is also
produced
> to the "which" command. However, I saw that all my directories concerning
> the "which" command are given as /cygdrive/c... I find it odd, since I run
> everything on a windows server, which also has cygwin installed upon for
> other matters, but I don't know what it has got to do with it.
which is a cygwin tool. It is normal if it display paths the cygwin way.
You can also confirm cmake is the right one using:
cmake --version
cmake-gui --version
> %PATH% is set to the cmake 2.8 directory before any other version.
OK. So the problem is somewhere else.
Maybe its time to launch the command line cmake, with the options --debug-
trycompile and --debug-output
With --debug-trycompile, cmake lets the temporary files in CMakeFiles/ sub-
directories. In those files, you should find some named *.log, or output.txt
(or something similar), with the error that is really reported by cl.exe
(before CMake says the STL is not working).
Laurent Rineau, PhD
- RE: [cgal-discuss] cmake does not identify boost, (continued)
- RE: [cgal-discuss] cmake does not identify boost, Amir Vaxman, 02/02/2010
- Re: [cgal-discuss] cmake does not identify boost, Laurent Rineau (GeometryFactory), 02/02/2010
- RE: [cgal-discuss] cmake does not identify boost, Amir Vaxman, 02/03/2010
- Re: [cgal-discuss] cmake does not identify boost, Laurent Rineau (GeometryFactory), 02/03/2010
- RE: [cgal-discuss] cmake does not identify boost, Amir Vaxman, 02/10/2010
- Re: [cgal-discuss] cmake does not identify boost, Yang Liu, 02/10/2010
- [cgal-discuss] Pb with mesh_3D_image example, Sylvain Gouttebroze, 02/10/2010
