- To:
- Subject: Re: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example
- Date: Fri, 25 Jun 2010 11:01:28 +0200
- Organization: INFOTERRA
Xie Yi wrote: Hi,Laurent Saboret-2 wrote:Hi Xie Yi, Please try to delete cmake cache and try again: cd ~/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3 delete CMakeCache.txt cmake -DCGAL_DIR=$HOME/CGAL-3.6 . make Best regards, Laurent Saboret Xie Yi wrote:Hi, everyone, after Sebastien helped me, finally I installed taucs successfully. I'm only one step away from compiling. I thought at least. Now I have an error as follow: cmake -DCGAL_DIR=$HOME/CGAL-3.6 . -- Build type: Release -- USING CXXFLAGS = ' -frounding-math -O3 -DNDEBUG' -- USING EXEFLAGS = ' ' -- Targetting Unix Makefiles -- Using /usr/bin/c++ compiler. -- TAUCS include: /usr/local/include -- TAUCS definitions: -- TAUCS library directories: /usr/local/lib -- TAUCS libraries: /usr/local/lib/libtaucs.a;/usr/local/lib/libmetis.a -- LAPACK include: -- LAPACK definitions: -- LAPACK library directories: /usr/local/lib -- LAPACK libraries: true -- LAPACK link flags: -- BLAS include: -- BLAS definitions: -- BLAS library directories: /usr/local/lib -- BLAS libraries: true -- BLAS link flags: -- MKL not found. Please specify library location. -- NOTICE: Some of the executables in this directory need the MKL library and will not be compiled. -- Configuring done -- Generating done -- Build files have been written to: /home/abbotxie/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3 make Linking CXX executable poisson_reconstruction_example /usr/bin/ld: cannot find -ltrue collect2: ld returned 1 exit status make[2]: *** [poisson_reconstruction_example] Error 1 make[1]: *** [CMakeFiles/poisson_reconstruction_example.dir/all] Error 2 make: *** [all] Error 2 I can't find anything about this -ltrue. Has anyone an idea about this? Thank you. Best regards XIE YiThank you Laurent. I found out what the problem was. I was stupid putting BLAS_LIBRARIES=true and BLAS_LIBRARIES_DIR=/usr/lib/. That's why I got -ltrue and cannot find it anywhere. But now I'm facing another problem here: make Scanning dependencies of target poisson_reconstruction_example [100%] Building CXX object CMakeFiles/poisson_reconstruction_example.dir/poisson_reconstruction_example.o Linking CXX executable poisson_reconstruction_example /usr/local/lib/libtaucs.a(taucs_vec_base.o): In function `taucs_vec_norm2': taucs_vec_base.c:(.text+0x3aa): undefined reference to `dnrm2_' taucs_vec_base.c:(.text+0x3c2): undefined reference to `dznrm2_' taucs_vec_base.c:(.text+0x3da): undefined reference to `scnrm2_' taucs_vec_base.c:(.text+0x3f2): undefined reference to `snrm2_' /usr/local/lib/libtaucs.a(taucs_ccs_ooc_llt_D.o): In function `recursive_leftlooking_supernodal_update': taucs_ccs_ooc_llt.c:(.text+0x370): undefined reference to `dsyrk_' taucs_ccs_ooc_llt.c:(.text+0x3fb): undefined reference to `dgemm_' /usr/local/lib/libtaucs.a(taucs_ccs_ooc_llt_D.o): In function `recursive_leftlooking_supernodal_update_panel_ooc': taucs_ccs_ooc_llt.c:(.text+0x849): undefined reference to `dsyrk_' taucs_ccs_ooc_llt.c:(.text+0x8d7): undefined reference to `dgemm_' taucs_ccs_ooc_llt.c:(.text+0xd3c): undefined reference to `dsyrk_' taucs_ccs_ooc_llt.c:(.text+0xdca): undefined reference to `dgemm_' /usr/local/lib/libtaucs.a(taucs_ccs_ooc_llt_D.o): In function `leftlooking_supernodal_front_factor': taucs_ccs_ooc_llt.c:(.text+0x174f): undefined reference to `dpotrf_' taucs_ccs_ooc_llt.c:(.text+0x1809): undefined reference to `dtrsm_' /usr/local/lib/libtaucs.a(taucs_ccs_ooc_llt_D.o): In function `recursive_supernodal_solve_l_ooc': taucs_ccs_ooc_llt.c:(.text+0x1be3): undefined reference to `dtrsm_' taucs_ccs_ooc_llt.c:(.text+0x1c52): undefined reference to `dgemm_' /usr/local/lib/libtaucs.a(taucs_ccs_ooc_llt_D.o): In function `recursive_supernodal_solve_lt_ooc': taucs_ccs_ooc_llt.c:(.text+0x2139): undefined reference to `dtrsm_' taucs_ccs_ooc_llt.c:(.text+0x2512): undefined reference to `dgemm_' /usr/local/lib/libtaucs.a(taucs_ccs_ooc_llt_S.o): In function `recursive_leftlooking_supernodal_update': taucs_ccs_ooc_llt.c:(.text+0x370): undefined reference to `ssyrk_' taucs_ccs_ooc_llt.c:(.text+0x3fb): undefined reference to `sgemm_' /usr/local/lib/libtaucs.a(taucs_ccs_ooc_llt_S.o): In function `recursive_leftlooking_supernodal_update_panel_ooc': taucs_ccs_ooc_llt.c:(.text+0x849): undefined reference to `ssyrk_' taucs_ccs_ooc_llt.c:(.text+0x8d7): undefined reference to `sgemm_' taucs_ccs_ooc_llt.c:(.text+0xd3c): undefined reference to `ssyrk_' taucs_ccs_ooc_llt.c:(.text+0xdca): undefined reference to `sgemm_' /usr/local/lib/libtaucs.a(taucs_ccs_ooc_llt_S.o): In function `leftlooking_supernodal_front_factor': taucs_ccs_ooc_llt.c:(.text+0x174f): undefined reference to `spotrf_' taucs_ccs_ooc_llt.c:(.text+0x180c): undefined reference to `strsm_' /usr/local/lib/libtaucs.a(taucs_ccs_ooc_llt_S.o): In function `recursive_supernodal_solve_l_ooc': taucs_ccs_ooc_llt.c:(.text+0x1bda): undefined reference to `strsm_' taucs_ccs_ooc_llt.c:(.text+0x1c43): undefined reference to `sgemm_' /usr/local/lib/libtaucs.a(taucs_ccs_ooc_llt_S.o): In function `recursive_supernodal_solve_lt_ooc': taucs_ccs_ooc_llt.c:(.text+0x2131): undefined reference to `strsm_' taucs_ccs_ooc_llt.c:(.text+0x2513): undefined reference to `sgemm_' /usr/local/lib/libtaucs.a(taucs_ccs_ooc_llt_Z.o): In function `recursive_leftlooking_supernodal_update': taucs_ccs_ooc_llt.c:(.text+0x36d): undefined reference to `zherk_' taucs_ccs_ooc_llt.c:(.text+0x3f4): undefined reference to `zgemm_' /usr/local/lib/libtaucs.a(taucs_ccs_ooc_llt_Z.o): In function `recursive_leftlooking_supernodal_update_panel_ooc': taucs_ccs_ooc_llt.c:(.text+0x852): undefined reference to `zherk_' taucs_ccs_ooc_llt.c:(.text+0x8e2): undefined reference to `zgemm_' taucs_ccs_ooc_llt.c:(.text+0xd42): undefined reference to `zherk_' taucs_ccs_ooc_llt.c:(.text+0xdd7): undefined reference to `zgemm_' /usr/local/lib/libtaucs.a(taucs_ccs_ooc_llt_Z.o): In function `leftlooking_supernodal_front_factor': taucs_ccs_ooc_llt.c:(.text+0x1798): undefined reference to `zpotrf_' taucs_ccs_ooc_llt.c:(.text+0x1854): undefined reference to `ztrsm_' /usr/local/lib/libtaucs.a(taucs_ccs_ooc_llt_Z.o): In function `recursive_supernodal_solve_l_ooc': taucs_ccs_ooc_llt.c:(.text+0x1cfd): undefined reference to `ztrsm_' taucs_ccs_ooc_llt.c:(.text+0x1d63): undefined reference to `zgemm_' /usr/local/lib/libtaucs.a(taucs_ccs_ooc_llt_Z.o): In function `recursive_supernodal_solve_lt_ooc': taucs_ccs_ooc_llt.c:(.text+0x2359): undefined reference to `ztrsm_' taucs_ccs_ooc_llt.c:(.text+0x299a): undefined reference to `zgemm_' /usr/local/lib/libtaucs.a(taucs_ccs_ooc_llt_C.o): In function `recursive_leftlooking_supernodal_update': taucs_ccs_ooc_llt.c:(.text+0x370): undefined reference to `cherk_' taucs_ccs_ooc_llt.c:(.text+0x3fb): undefined reference to `cgemm_' /usr/local/lib/libtaucs.a(taucs_ccs_ooc_llt_C.o): In function `recursive_leftlooking_supernodal_update_panel_ooc': taucs_ccs_ooc_llt.c:(.text+0x869): undefined reference to `cherk_' taucs_ccs_ooc_llt.c:(.text+0x8f7): undefined reference to `cgemm_' taucs_ccs_ooc_llt.c:(.text+0xd6c): undefined reference to `cherk_' taucs_ccs_ooc_llt.c:(.text+0xdfa): undefined reference to `cgemm_' /usr/local/lib/libtaucs.a(taucs_ccs_ooc_llt_C.o): In function `leftlooking_supernodal_front_factor': taucs_ccs_ooc_llt.c:(.text+0x17b0): undefined reference to `cpotrf_' taucs_ccs_ooc_llt.c:(.text+0x186c): undefined reference to `ctrsm_' /usr/local/lib/libtaucs.a(taucs_ccs_ooc_llt_C.o): In function `recursive_supernodal_solve_l_ooc': taucs_ccs_ooc_llt.c:(.text+0x1cf2): undefined reference to `ctrsm_' taucs_ccs_ooc_llt.c:(.text+0x1d5e): undefined reference to `cgemm_' /usr/local/lib/libtaucs.a(taucs_ccs_ooc_llt_C.o): In function `recursive_supernodal_solve_lt_ooc': taucs_ccs_ooc_llt.c:(.text+0x2327): undefined reference to `ctrsm_' taucs_ccs_ooc_llt.c:(.text+0x2930): undefined reference to `cgemm_' /usr/local/lib/libtaucs.a(taucs_sn_llt_D.o): In function `recursive_supernodal_solve_l': taucs_sn_llt.c:(.text+0x3fc): undefined reference to `dtrsm_' taucs_sn_llt.c:(.text+0x477): undefined reference to `dgemm_' /usr/local/lib/libtaucs.a(taucs_sn_llt_D.o): In function `recursive_supernodal_solve_lt': taucs_sn_llt.c:(.text+0x6d0): undefined reference to `dtrsm_' taucs_sn_llt.c:(.text+0x76a): undefined reference to `dgemm_' /usr/local/lib/libtaucs.a(taucs_sn_llt_D.o): In function `recursive_leftlooking_supernodal_update': taucs_sn_llt.c:(.text+0xbde): undefined reference to `dsyrk_' taucs_sn_llt.c:(.text+0xc69): undefined reference to `dgemm_' /usr/local/lib/libtaucs.a(taucs_sn_llt_D.o): In function `recursive_leftlooking_supernodal_factor_llt': taucs_sn_llt.c:(.text+0x11ab): undefined reference to `dpotrf_' taucs_sn_llt.c:(.text+0x122d): undefined reference to `dtrsm_' And another one: ./Point_set_demo ### Loading "libPS_demo_average_spacing_plugin.so"... ### Loading "libPS_demo_cleaning_plugin.so"... ### Loading "libPS_demo_inside_out_plugin.so"... ### Loading "libPS_demo_local_spacing_plugin.so"... ### Loading "libPS_demo_normal_estimation_plugin.so"... ### Loading "libPS_demo_off_plugin.so"... ### Loading "libPS_demo_poisson_plugin.so"... Error loading "libPS_demo_poisson_plugin.so": Cannot load library /home/abbotxie/Programs/CGAL-3.6/demo/Surface_reconstruction_points_3/libPS_demo_poisson_plugin.so: (/home/abbotxie/Programs/CGAL-3.6/demo/Surface_reconstruction_points_3/libPS_demo_poisson_plugin.so: undefined symbol: dnrm2_) ### Loading "libPS_demo_simplification_plugin.so"... ### Loading "libPS_demo_smoothing_plugin.so"... ### Loading "libPS_demo_xyz_plugin.so"... Write setting... done. And still a question. Where can the Lib MKL be found? It's kind of required by configuring. Best regards XIE, Yi /usr/local/lib/libtaucs.a(taucs_sn_llt_D.o): In function `recursive_multifrontal_supernodal_factor_llt': taucs_sn_llt.c:(.text+0x1f95): undefined reference to `dpotrf_' taucs_sn_llt.c:(.text+0x21f5): undefined reference to `dtrsm_' taucs_sn_llt.c:(.text+0x22c2): undefined reference to `dsyrk_' /usr/local/lib/libtaucs.a(taucs_sn_llt_S.o): In function `recursive_supernodal_solve_l': taucs_sn_llt.c:(.text+0x3f6): undefined reference to `strsm_' taucs_sn_llt.c:(.text+0x471): undefined reference to `sgemm_' /usr/local/lib/libtaucs.a(taucs_sn_llt_S.o): In function `recursive_supernodal_solve_lt': taucs_sn_llt.c:(.text+0x6c8): undefined reference to `strsm_' taucs_sn_llt.c:(.text+0x76b): undefined reference to `sgemm_' /usr/local/lib/libtaucs.a(taucs_sn_llt_S.o): In function `recursive_leftlooking_supernodal_update': taucs_sn_llt.c:(.text+0xbde): undefined reference to `ssyrk_' taucs_sn_llt.c:(.text+0xc69): undefined reference to `sgemm_' /usr/local/lib/libtaucs.a(taucs_sn_llt_S.o): In function `recursive_leftlooking_supernodal_factor_llt': taucs_sn_llt.c:(.text+0x11ae): undefined reference to `spotrf_' taucs_sn_llt.c:(.text+0x1230): undefined reference to `strsm_' /usr/local/lib/libtaucs.a(taucs_sn_llt_S.o): In function `recursive_multifrontal_supernodal_factor_llt': taucs_sn_llt.c:(.text+0x1fa0): undefined reference to `spotrf_' taucs_sn_llt.c:(.text+0x2205): undefined reference to `strsm_' taucs_sn_llt.c:(.text+0x22d2): undefined reference to `ssyrk_' /usr/local/lib/libtaucs.a(taucs_sn_llt_Z.o): In function `recursive_supernodal_solve_l': taucs_sn_llt.c:(.text+0x40c): undefined reference to `ztrsm_' taucs_sn_llt.c:(.text+0x484): undefined reference to `zgemm_' /usr/local/lib/libtaucs.a(taucs_sn_llt_Z.o): In function `recursive_supernodal_solve_lt': taucs_sn_llt.c:(.text+0x704): undefined reference to `ztrsm_' taucs_sn_llt.c:(.text+0x7ae): undefined reference to `zgemm_' /usr/local/lib/libtaucs.a(taucs_sn_llt_Z.o): In function `recursive_leftlooking_supernodal_update': taucs_sn_llt.c:(.text+0xc23): undefined reference to `zherk_' taucs_sn_llt.c:(.text+0xca9): undefined reference to `zgemm_' /usr/local/lib/libtaucs.a(taucs_sn_llt_Z.o): In function `recursive_leftlooking_supernodal_factor_llt': taucs_sn_llt.c:(.text+0x1231): undefined reference to `zpotrf_' taucs_sn_llt.c:(.text+0x12b6): undefined reference to `ztrsm_' /usr/local/lib/libtaucs.a(taucs_sn_llt_Z.o): In function `recursive_multifrontal_supernodal_factor_llt': taucs_sn_llt.c:(.text+0x210c): undefined reference to `zpotrf_' taucs_sn_llt.c:(.text+0x23a0): undefined reference to `ztrsm_' taucs_sn_llt.c:(.text+0x246d): undefined reference to `zherk_' /usr/local/lib/libtaucs.a(taucs_sn_llt_C.o): In function `recursive_supernodal_solve_l': taucs_sn_llt.c:(.text+0x40e): undefined reference to `ctrsm_' taucs_sn_llt.c:(.text+0x486): undefined reference to `cgemm_' /usr/local/lib/libtaucs.a(taucs_sn_llt_C.o): In function `recursive_supernodal_solve_lt': taucs_sn_llt.c:(.text+0x6ee): undefined reference to `ctrsm_' taucs_sn_llt.c:(.text+0x78d): undefined reference to `cgemm_' /usr/local/lib/libtaucs.a(taucs_sn_llt_C.o): In function `recursive_leftlooking_supernodal_update': taucs_sn_llt.c:(.text+0xc03): undefined reference to `cherk_' taucs_sn_llt.c:(.text+0xc8e): undefined reference to `cgemm_' /usr/local/lib/libtaucs.a(taucs_sn_llt_C.o): In function `recursive_leftlooking_supernodal_factor_llt': taucs_sn_llt.c:(.text+0x1222): undefined reference to `cpotrf_' taucs_sn_llt.c:(.text+0x12a6): undefined reference to `ctrsm_' /usr/local/lib/libtaucs.a(taucs_sn_llt_C.o): In function `recursive_multifrontal_supernodal_factor_llt': taucs_sn_llt.c:(.text+0x20cc): undefined reference to `cpotrf_' taucs_sn_llt.c:(.text+0x2360): undefined reference to `ctrsm_' taucs_sn_llt.c:(.text+0x242d): undefined reference to `cherk_' collect2: ld returned 1 exit status make[2]: *** [poisson_reconstruction_example] Error 1 make[1]: *** [CMakeFiles/poisson_reconstruction_example.dir/all] Error 2 make: *** [all] Error 2 The errors above mean that the linker did not find blas and lapack. CMake should have found them and added them to linker parameters. Did you delete cmake and run again cmake and make as I suggested (see top of this email)? Regards, Laurent Saboret
- [cgal-discuss] Error by compiling poisson_reconstruction_example, Xie Yi, 06/24/2010
- Re: [cgal-discuss] Error by compiling poisson_reconstruction_example, Laurent Saboret, 06/25/2010
- [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Xie Yi, 06/25/2010
- Re: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Laurent Saboret, 06/25/2010
- Re: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Laurent Rineau (GeometryFactory), 06/25/2010
- [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Xie Yi, 06/28/2010
- Re: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Laurent Saboret, 06/29/2010
