- To:
- Subject: Re: [cgal-discuss] Error by compiling poisson_reconstruction_example
- Date: Fri, 25 Jun 2010 10:02:43 +0200
- Organization: INFOTERRA
Hi Xie Yi,
Please try to delete cmake cache and try again:
cd ~/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3
delete CMakeCache.txt
cmake -DCGAL_DIR=$HOME/CGAL-3.6 .
make
Best regards,
Laurent Saboret
Xie Yi wrote:
Hi, everyone,
after Sebastien helped me, finally I installed taucs successfully. I'm only
one step away from compiling. I thought at least.
Now I have an error as follow:
abbotxie@abbotxie-laptop:~/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3$
-- Build type: Release
-- USING CXXFLAGS = ' -frounding-math -O3 -DNDEBUG'
-- USING EXEFLAGS = ' '
-- Targetting Unix Makefiles
-- Using /usr/bin/c++ compiler.
-- TAUCS include: /usr/local/include
-- TAUCS definitions: -- TAUCS library directories: /usr/local/lib
-- TAUCS libraries: /usr/local/lib/libtaucs.a;/usr/local/lib/libmetis.a
-- LAPACK include: -- LAPACK definitions: -- LAPACK library directories: /usr/local/lib
-- LAPACK libraries: true
-- LAPACK link flags: -- BLAS include: -- BLAS definitions: -- BLAS library directories: /usr/local/lib -- BLAS libraries: true -- BLAS link flags: -- MKL not found. Please specify library location. -- NOTICE: Some of the executables in this directory need the MKL library
and will not be compiled.
-- Configuring done
-- Generating done
-- Build files have been written to:
/home/abbotxie/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3
make
Linking CXX executable poisson_reconstruction_example
/usr/bin/ld: cannot find -ltrue collect2: ld returned 1 exit status
make[2]: *** [poisson_reconstruction_example] Error 1
make[1]: *** [CMakeFiles/poisson_reconstruction_example.dir/all] Error 2
make: *** [all] Error 2
I can't find anything about this -ltrue. Has anyone an idea about this?
Thank you.
Best regards
XIE Yi
Ce courrier électronique et toutes les pièces éventuellement jointes qu’il
contient sont CONFIDENTIELS et destinés exclusivement à l’usage de leur
destinataire. Si une erreur de transmission ou une adresse erronée a mal
dirigée ce courrier, merci d’en informer l’expéditeur en lui faisant une
réponse par courrier électronique dès réception. Si vous n’êtes pas le
destinataire de ce courrier, vous ne devez pas l’utiliser, le conserver, en
faire état, le distribuer, le copier, l’imprimer ou en révéler le contenu à
une tierce partie.
Ce courrier électronique est à usage strictement informatif et ne saurait
engager de quelque manière que ce soit SPOT IMAGE SA, ni ses filiales.
This e-mail and any attachments hereto are CONFIDENTIAL and intended solely
for the use of the addressee. If you have received this e-mail in error
please send it back to the person that sent it to you.
If you have received it in error, please notify the sender by return email.
If you are not the addressee of this email, you must not use, keep,
disseminate, copy, print or otherwise deal with it.
This email is for information only and will not bind SPOT IMAGE SA in any
contract or obligation, nor its subsidiaries.
- [cgal-discuss] Error by compiling poisson_reconstruction_example, Xie Yi, 06/24/2010
- Re: [cgal-discuss] Error by compiling poisson_reconstruction_example, Laurent Saboret, 06/25/2010
- [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Xie Yi, 06/25/2010
- Re: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Laurent Saboret, 06/25/2010
- Re: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Laurent Rineau (GeometryFactory), 06/25/2010
