Re: [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted
- To:
- Subject: Re: [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted
- Date: Sat, 12 Feb 2011 11:47:02 +0100
MrVH wrote:
I already check there is no gap :(
indices starts at 0.
Add this assertion in the edge loop and you will see
that the alpha-shape is fine.
assert(
edge->first->vertex( edge->second )->point().weight() ==
edge->first->vertex( edge->third )->point().weight()
CGAL::squared_distance(edge->first->vertex(edge->second)->point(),
edge->first->vertex(edge->third)->point() )
<= 4*edge->first->vertex( edge->third )->point().weight()
also as I already said the radius of the balls in your case
is sqrt(1.8).
But I've a question aboutall except exterior which are simplices of the underlying
Interior
Regular
Singular
Exterior
All are from AlphaShape ?
triangulation which are exterior to the alpha complex.
Cause I print just:
as.get_alpha_shape_cells(std::back_inserter(cells),
Alpha_shape_3::INTERIOR);
as.get_alpha_shape_facets(std::back_inserter(facets),
Alpha_shape_3::REGULAR);
Alpha_shape_3::SINGULAR);
as.get_alpha_shape_edges(std::back_inserter(edges),
If I print all combinason it is not alphashape. I understood that both
Regular Exterior are not alphaShape. Which combinaison I have to screen to
have no distance superior to 2* weights + 2*alphaSphere Ray ?
coords files x y z weights (there is no gap in atom indices :( )
42.040 46.010 64.730 1.800
40.790 45.410 65.220 1.800
39.990 46.470 65.990 1.800
39.880 44.680 64.240 1.800
39.450 43.610 64.670 1.800
39.680 45.060 62.980 1.800
38.970 44.170 62.050 1.800
38.080 45.020 61.140 1.800
38.930 46.290 61.080 1.800
39.530 46.430 62.480 1.800
39.930 43.350 61.190 1.800
41.100 43.740 61.160 1.800
39.460 42.210 60.680 1.800
40.060 41.340 59.660 1.800
38.980 40.410 59.100 1.800
40.670 42.180 58.530 1.800
40.160 43.230 58.150 1.800
41.650 41.570 57.870 1.800
42.320 42.240 56.750 1.800
43.760 41.720 56.750 1.800
44.520 42.000 55.450 1.800
44.810 43.500 55.340 1.800
45.590 43.980 56.190 1.800
44.250 44.230 54.500 1.800
41.520 41.870 55.500 1.800
41.070 40.720 55.400 1.800
41.090 42.940 54.840 1.800
40.270 42.910 53.620 1.800
39.640 44.290 53.470 1.800
38.570 44.440 54.550 1.800
39.160 44.460 52.020 1.800
39.000 45.550 55.510 1.800
41.200 42.410 52.510 1.800
42.190 43.030 52.120 1.800
40.820 41.220 52.080 1.800
41.270 40.540 50.850 1.800
40.990 39.040 50.980 1.800
41.770 38.310 52.080 1.800
41.180 36.920 52.280 1.800
43.270 38.290 51.770 1.800
40.610 41.180 49.630 1.800
39.530 40.790 49.210 1.800
41.200 42.320 49.290 1.800
40.620 43.200 48.270 1.800
41.180 44.620 48.400 1.800
40.670 45.590 47.340 1.800
40.660 45.330 46.140 1.800
40.270 46.760 47.850 1.800
40.820 42.590 46.880 1.800
41.830 42.850 46.220 1.800
39.790 41.870 46.440 1.800
39.550 41.180 45.160 1.800
39.880 41.980 43.900 1.800
40.470 41.430 42.970 1.800
39.570 43.270 44.070 1.800
39.640 44.350 43.080 1.800
38.940 45.650 43.470 1.800
39.120 46.710 42.390 1.800
38.370 48.000 42.700 1.800
38.250 48.810 41.410 1.800
37.080 49.700 41.490 1.800
41.130 44.500 42.770 1.800
41.590 44.200 41.670 1.800
41.930 44.810 43.790 1.800
43.360 45.040 43.560 1.800
44.060 45.470 44.850 1.800
43.610 46.870 45.280 1.800
44.420 47.410 46.460 1.800
44.370 46.850 47.580 1.800
45.210 48.360 46.250 1.800
44.060 43.780 43.030 1.800
44.800 43.810 42.050 1.800
43.770 42.660 43.680 1.800
44.420 41.400 43.270 1.800
44.040 40.280 44.240 1.800
44.050 40.750 45.700 1.800
45.050 39.140 44.120 1.800
43.290 39.840 46.660 1.800
44.170 40.960 41.830 1.800
45.080 40.810 41.010 1.800
42.880 40.920 41.500 1.800
42.480 40.700 40.100 1.800
40.960 40.800 39.980 1.800
40.470 42.080 40.380 1.800
43.140 41.670 39.130 1.800
43.820 41.090 38.280 1.800
43.340 42.920 39.540 1.800
43.980 43.910 38.650 1.800
43.730 45.340 39.130 1.800
45.420 43.500 38.350 1.800
45.830 43.290 37.210 1.800
46.200 43.160 39.370 1.800
47.580 42.650 39.250 1.800
48.130 42.310 40.640 1.800
47.970 43.450 41.650 1.800
47.860 42.960 43.090 1.800
48.250 41.860 43.480 1.800
47.300 43.830 43.930 1.800
47.800 41.470 38.310 1.800
48.660 41.540 37.430 1.800
47.040 40.390 38.440 1.800
47.020 39.190 37.590 1.800
45.930 38.250 38.130 1.800
46.220 37.720 39.540 1.800
45.840 37.060 37.170 1.800
44.940 37.150 40.170 1.800
46.780 39.580 36.130 1.800
47.370 39.050 35.190 1.800
45.710 40.340 35.950 1.800
45.240 40.880 34.670 1.800
44.060 41.840 34.780 1.800
42.790 41.220 35.360 1.800
41.440 41.900 35.140 1.800
41.420 43.370 35.280 1.800
40.900 44.020 36.320 1.800
40.390 43.360 37.370 1.800
41.040 45.360 36.370 1.800
46.330 41.670 33.950 1.800
46.570 41.520 32.750 1.800
47.130 42.490 34.620 1.800
48.370 43.090 34.100 1.800
48.950 44.190 34.990 1.800
49.480 42.140 33.650 1.800
50.200 42.280 32.660 1.800
49.640 41.110 34.480 1.800
50.410 39.900 34.150 1.800
50.400 38.900 35.310 1.800
51.340 37.690 35.280 1.800
51.080 36.610 36.320 1.800
49.850 35.880 35.980 1.800
48.940 35.480 36.880 1.800
49.010 35.670 38.210 1.800
48.060 34.590 36.400 1.800
50.020 39.130 32.890 1.800
50.830 38.930 31.980 1.800
48.710 38.890 32.860 1.800
48.070 38.240 31.710 1.800
46.570 38.240 32.000 1.800
46.180 37.190 33.040 1.800
44.680 37.300 33.340 1.800
46.540 35.800 32.510 1.800
48.310 39.070 30.450 1.800
48.600 38.630 29.340 1.800
48.090 40.380 30.570 1.800
48.280 41.380 29.510 1.800
48.020 42.810 30.000 1.800
48.180 43.840 28.890 1.800
48.280 45.300 29.340 1.800
48.010 46.150 28.100 1.800
48.070 47.580 28.450 1.800
49.630 41.270 28.810 1.800
49.790 40.720 27.730 1.800
50.640 41.410 29.670 1.800
52.080 41.110 29.540 1.800
52.880 41.250 30.830 1.800
53.190 42.710 31.170 1.800
53.260 43.180 32.310 1.800
53.220 43.590 30.180 1.800
52.420 39.800 28.830 1.800
52.980 39.760 27.740 1.800
51.880 38.680 29.300 1.800
51.920 37.310 28.760 1.800
51.020 36.440 29.640 1.800
51.700 36.230 30.990 1.800
50.840 35.470 32.000 1.800
49.630 35.690 32.040 1.800
51.460 34.800 32.970 1.800
51.460 37.100 27.320 1.800
52.140 36.500 26.490 1.800
50.300 37.730 27.120 1.800
49.560 37.850 25.860 1.800
48.050 37.940 26.050 1.800
47.350 38.660 24.900 1.800
47.330 36.640 26.420 1.800
50.330 38.580 24.750 1.800
50.540 38.140 23.630 1.800
50.750 39.780 25.140 1.800
51.530 40.730 24.320 1.800
51.900 42.060 24.980 1.800
50.770 42.730 25.540 1.800
52.420 42.980 23.870 1.800
52.820 40.040 23.850 1.800
53.040 39.830 22.660 1.800
53.600 39.540 24.810 1.800
54.740 38.650 24.600 1.800
55.340 38.100 25.890 1.800
55.880 39.290 26.690 1.800
56.580 38.830 27.960 1.800
57.520 38.030 27.960 1.800
56.070 39.270 29.110 1.800
54.530 37.460 23.660 1.800
55.260 37.450 22.670 1.800
53.510 36.640 23.890 1.800
53.100 35.520 23.030 1.800
51.910 34.860 23.720 1.800
51.430 33.580 23.040 1.800
52.440 32.450 23.290 1.800
50.070 33.280 23.670 1.800
52.780 35.890 21.580 1.800
53.010 35.090 20.670 1.800
52.230 37.080 21.360 1.800
52.040 37.640 20.020 1.800
51.010 38.770 19.960 1.800
49.560 38.430 20.330 1.800
48.710 39.680 20.520 1.800
47.320 39.320 21.060 1.800
46.430 40.480 20.880 1.800
53.210 38.260 19.250 1.800
53.170 38.280 18.020 1.800
54.200 38.680 20.030 1.800
55.550 38.950 19.520 1.800
56.390 39.720 20.560 1.800
55.780 41.060 20.960 1.800
56.490 41.780 22.120 1.800
56.610 41.190 23.210 1.800
57.010 42.900 21.980 1.800
56.330 37.690 19.140 1.800
56.560 37.610 17.940 1.800
56.200 36.640 19.950 1.800
56.720 35.280 19.780 1.800
56.370 34.440 21.010 1.800
57.360 34.580 22.170 1.800
56.730 34.080 23.470 1.800
55.660 33.490 23.540 1.800
57.180 34.730 24.540 1.800
56.070 34.660 18.550 1.800
56.820 34.150 17.710 1.800
54.760 34.830 18.410 1.800
53.960 34.270 17.310 1.800
53.010 33.170 17.790 1.800
52.450 32.440 16.560 1.800
53.570 32.210 18.830 1.800
53.180 35.430 16.700 1.800
52.030 35.690 17.060 1.800
53.790 36.230 15.840 1.800
53.100 37.370 15.240 1.800
54.200 37.990 14.380 1.800
55.520 37.540 15.020 1.800
55.210 36.110 15.460 1.800
51.910 36.800 14.460 1.800
52.160 36.170 13.430 1.800
50.670 37.150 14.780 1.800
49.410 36.670 14.170 1.800
48.460 36.080 15.210 1.800
47.300 36.500 15.210 1.800
49.010 35.200 16.050 1.800
48.280 34.430 17.070 1.800
49.280 33.740 18.000 1.800
48.570 32.670 18.840 1.800
47.720 31.740 18.260 1.800
48.570 32.760 20.230 1.800
46.870 30.950 19.020 1.800
47.710 31.970 20.990 1.800
46.830 31.070 20.400 1.800
47.410 35.240 18.030 1.800
47.930 36.070 18.770 1.800
46.120 34.910 17.950 1.800
45.200 35.710 18.780 1.800
44.310 36.680 18.000 1.800
43.620 36.050 16.920 1.800
45.110 37.870 17.470 1.800
44.490 34.750 19.730 1.800
43.640 33.960 19.320 1.800
44.860 34.720 21.010 1.800
44.080 34.060 22.070 1.800
44.710 34.540 23.380 1.800
46.160 34.870 23.000 1.800
46.060 35.370 21.560 1.800
42.610 34.480 21.940 1.800
42.130 35.600 22.070 1.800
41.750 33.540 21.570 1.800
40.300 33.650 21.390 1.800
39.920 33.480 19.920 1.800
38.470 33.860 19.600 1.800
38.020 33.410 18.210 1.800
36.640 33.760 17.860 1.800
35.950 33.230 16.840 1.800
36.470 32.560 15.800 1.800
34.630 33.430 16.740 1.800
39.430 32.770 22.300 1.800
39.680 31.570 22.410 1.800
38.480 33.560 22.800 1.800
37.390 33.210 23.720 1.800
37.400 34.050 25.000 1.800
36.420 33.710 26.130 1.800
36.660 32.330 26.750 1.800
36.660 34.660 27.310 1.800
35.990 33.340 23.100 1.800
35.690 34.340 22.440 1.800
35.170 32.310 23.240 1.800
33.750 32.400 22.870 1.800
33.480 31.550 21.620 1.800
32.770 32.130 24.020 1.800
33.040 31.310 24.900 1.800
31.720 32.940 24.050 1.800
30.680 32.950 25.090 1.800
30.780 34.230 25.910 1.800
32.180 34.250 26.530 1.800
29.850 34.160 27.130 1.800
32.630 35.440 27.370 1.800
29.350 32.820 24.340 1.800
28.950 33.730 23.620 1.800
28.870 31.580 24.390 1.800
27.480 31.220 24.090 1.800
27.490 29.730 23.750 1.800
26.230 29.210 23.060 1.800
26.070 29.820 21.660 1.800
26.210 27.700 22.860 1.800
26.500 31.580 25.210 1.800
26.890 31.510 26.370 1.800
25.550 32.430 24.820 1.800
24.430 32.710 25.720 1.800
24.250 34.200 26.010 1.800
23.090 34.700 26.870 1.800
23.120 36.220 27.070 1.800
23.570 37.000 26.240 1.800
22.520 36.630 28.180 1.800
23.140 32.290 25.000 1.800
22.960 32.510 23.800 1.800
22.240 31.710 25.780 1.800
20.810 31.500 25.480 1.800
20.300 30.060 25.510 1.800
18.850 29.960 25.030 1.800
21.160 28.950 24.910 1.800
19.960 32.400 26.380 1.800
19.730 32.210 27.580 1.800
19.420 33.370 25.660 1.800
18.490 34.350 26.230 1.800
18.980 35.800 26.290 1.800
19.960 36.190 25.650 1.800
18.260 36.680 26.970 1.800
18.550 38.110 27.160 1.800
17.630 38.820 26.170 1.800
18.260 39.980 25.410 1.800
19.490 40.030 25.360 1.800
17.490 40.840 24.750 1.800
18.280 38.530 28.610 1.800
17.590 39.510 28.900 1.800
18.730 37.660 29.500 1.800
18.830 37.920 30.940 1.800
19.400 36.730 31.710 1.800
18.410 35.570 31.820 1.800
18.910 34.570 32.860 1.800
18.940 35.110 34.230 1.800
18.370 34.550 35.300 1.800
17.560 33.490 35.210 1.800
18.730 35.020 36.500 1.800
19.810 39.100 31.060 1.800
21.010 39.070 30.780 1.800
19.280 40.220 31.540 1.800
19.990 41.460 31.870 1.800
19.020 42.400 32.580 1.800
17.700 42.780 31.900 1.800
17.670 43.100 30.690 1.800
16.740 42.920 32.680 1.800
21.260 41.320 32.720 1.800
22.370 41.650 32.290 1.800
21.050 40.490 33.740 1.800
22.160 40.200 34.660 1.800
21.710 39.460 35.910 1.800
21.240 38.000 35.860 1.800
20.400 37.670 34.990 1.800
21.870 37.160 36.530 1.800
23.290 39.490 33.910 1.800
24.460 39.860 33.930 1.800
22.910 38.440 33.190 1.800
23.850 37.690 32.350 1.800
23.160 36.670 31.450 1.800
22.710 35.470 32.090 1.800
24.590 38.560 31.340 1.800
25.770 38.330 31.050 1.800
23.850 39.460 30.710 1.800
24.360 40.510 29.820 1.800
23.310 41.480 29.280 1.800
22.320 40.760 28.370 1.800
22.510 39.770 27.660 1.800
21.120 41.330 28.470 1.800
25.450 41.380 30.440 1.800
26.510 41.490 29.830 1.800
25.150 41.950 31.600 1.800
26.100 42.710 32.430 1.800
25.370 43.020 33.730 1.800
24.290 44.100 33.630 1.800
23.510 43.960 34.940 1.800
24.680 45.570 33.530 1.800
27.370 41.880 32.630 1.800
28.480 42.370 32.440 1.800
27.280 40.610 33.030 1.800
28.340 39.640 33.340 1.800
27.720 38.340 33.870 1.800
27.030 38.380 35.230 1.800
27.530 39.180 36.250 1.800
25.860 37.680 35.520 1.800
26.840 39.340 37.450 1.800
25.220 37.760 36.760 1.800
25.720 38.580 37.760 1.800
25.050 38.790 38.930 1.800
29.250 39.320 32.160 1.800
30.470 39.370 32.290 1.800
28.610 39.050 31.030 1.800
29.270 38.820 29.730 1.800
28.360 38.400 28.580 1.800
27.510 37.180 28.940 1.800
29.120 38.180 27.270 1.800
26.330 36.940 28.000 1.800
30.070 40.060 29.310 1.800
31.270 39.980 29.090 1.800
29.410 41.220 29.320 1.800
30.020 42.550 29.190 1.800
28.940 43.640 29.270 1.800
27.830 43.440 28.240 1.800
27.900 42.650 27.310 1.800
26.770 44.220 28.490 1.800
31.270 42.810 30.030 1.800
32.160 43.440 29.460 1.800
31.390 42.270 31.240 1.800
32.500 42.470 32.180 1.800
32.030 42.130 33.600 1.800
33.200 42.180 34.580 1.800
30.970 43.180 33.970 1.800
33.650 41.570 31.740 1.800
34.800 42.010 31.700 1.800
33.300 40.350 31.360 1.800
34.210 39.360 30.740 1.800
33.480 38.050 30.440 1.800
32.830 37.290 31.590 1.800
31.750 36.280 31.210 1.800
31.400 35.570 32.520 1.800
30.660 34.320 32.270 1.800
34.920 39.810 29.460 1.800
36.130 40.020 29.600 1.800
34.130 40.220 28.480 1.800
34.550 40.950 27.270 1.800
33.370 41.550 26.500 1.800
32.430 40.470 25.950 1.800
31.010 41.030 25.840 1.800
32.890 39.990 24.570 1.800
35.570 42.040 27.620 1.800
36.710 41.890 27.180 1.800
35.270 42.970 28.520 1.800
36.100 44.150 28.810 1.800
35.390 45.090 29.790 1.800
36.040 46.470 29.780 1.800
35.630 47.100 31.120 1.800
36.220 48.510 31.220 1.800
35.730 49.170 32.440 1.800
37.490 43.790 29.340 1.800
38.520 44.300 28.900 1.800
37.570 42.800 30.220 1.800
38.780 42.090 30.670 1.800
38.250 41.190 31.780 1.800
39.610 41.390 29.590 1.800
40.780 41.750 29.570 1.800
38.980 40.680 28.660 1.800
39.590 40.070 27.470 1.800
38.460 39.230 26.880 1.800
40.220 41.140 26.570 1.800
41.410 40.980 26.290 1.800
39.510 42.200 26.200 1.800
40.050 43.290 25.370 1.800
38.880 44.230 25.090 1.800
39.210 45.150 23.920 1.800
38.060 46.130 23.670 1.800
36.900 45.670 23.630 1.800
38.340 47.290 23.290 1.800
41.320 43.960 25.910 1.800
42.180 44.420 25.160 1.800
41.270 44.250 27.210 1.800
42.390 44.890 27.900 1.800
41.990 45.210 29.350 1.800
40.860 46.240 29.380 1.800
40.340 46.660 30.760 1.800
40.760 45.930 31.680 1.800
39.450 47.530 30.830 1.800
43.630 44.000 27.880 1.800
44.770 44.380 27.600 1.800
43.390 42.760 28.300 1.800
44.510 41.810 28.190 1.800
44.240 40.530 28.990 1.800
44.150 40.830 30.490 1.800
45.130 39.300 28.770 1.800
43.220 39.840 31.180 1.800
45.130 41.560 26.820 1.800
46.340 41.420 26.710 1.800
44.240 41.630 25.830 1.800
44.580 41.390 24.420 1.800
44.040 40.070 23.880 1.800
44.560 39.400 22.980 1.800
42.980 39.580 24.510 1.800
42.160 38.410 24.150 1.800
41.640 37.640 25.370 1.800
42.780 37.290 26.330 1.800
40.880 36.370 24.970 1.800
42.250 37.220 27.760 1.800
41.040 38.880 23.230 1.800
40.170 39.660 23.630 1.800
40.930 38.210 22.080 1.800
39.820 38.210 21.120 1.800
40.340 37.840 19.730 1.800
39.290 37.620 18.640 1.800
39.710 37.610 17.160 1.800
38.520 37.290 16.270 1.800
38.970 37.180 14.870 1.800
38.630 37.420 21.670 1.800
38.660 36.190 21.790 1.800
37.460 38.050 21.710 1.800
36.280 37.570 22.450 1.800
36.140 38.300 23.780 1.800
34.940 37.650 21.700 1.800
34.580 38.720 21.230 1.800
34.310 36.520 21.410 1.800
33.110 36.460 20.550 1.800
33.350 35.260 19.640 1.800
34.570 35.330 18.910 1.800
32.180 35.110 18.660 1.800
31.870 36.220 21.410 1.800
31.750 35.150 22.000 1.800
30.840 37.030 21.190 1.800
29.580 36.900 21.940 1.800
29.170 38.260 22.520 1.800
27.970 38.160 23.460 1.800
27.070 39.130 23.630 1.800
27.590 37.040 24.060 1.800
26.050 38.470 24.180 1.800
26.320 37.200 24.440 1.800
28.460 36.500 20.990 1.800
27.960 37.360 20.270 1.800
28.060 35.230 21.030 1.800
26.880 34.670 20.370 1.800
27.290 33.240 20.000 1.800
28.540 33.120 19.120 1.800
26.090 32.510 19.390 1.800
29.380 31.930 19.570 1.800
25.730 34.760 21.380 1.800
25.980 34.480 22.550 1.800
24.620 35.360 20.950 1.800
23.390 35.420 21.750 1.800
23.050 36.880 22.060 1.800
21.840 37.110 22.970 1.800
21.630 38.600 23.240 1.800
22.650 39.180 24.220 1.800
22.240 40.520 24.660 1.800
22.270 34.750 20.960 1.800
21.560 35.250 20.080 1.800
21.880 33.620 21.540 1.800
20.750 32.810 21.070 1.800
21.070 31.390 21.550 1.800
22.330 30.740 20.980 1.800
22.410 29.240 21.280 1.800
22.440 31.020 19.480 1.800
19.420 33.330 21.620 1.800
19.370 33.800 22.760 1.800
18.390 33.360 20.780 1.800
17.030 33.680 21.220 1.800
16.240 33.600 19.910 1.800
16.940 32.480 19.140 1.800
18.410 32.800 19.420 1.800
16.500 32.890 22.410 1.800
16.900 31.750 22.630 1.800
15.460 33.390 23.080 1.800
14.810 32.630 24.150 1.800
13.890 33.350 25.140 1.800
14.550 34.580 25.790 1.800
13.560 35.040 26.860 1.800
13.460 34.130 28.010 1.800
12.420 33.380 28.390 1.800
11.290 33.180 27.690 1.800
12.600 32.630 29.490 1.800
14.050 31.440 23.550 1.800
14.000 30.400 24.190 1.800
13.720 31.500 22.260 1.800
13.260 30.420 21.380 1.800
12.650 30.860 20.050 1.800
13.560 31.760 19.410 1.800
11.230 31.400 20.190 1.800
14.180 29.220 21.140 1.800
13.670 28.240 20.610 1.800
15.420 29.220 21.620 1.800
16.460 28.210 21.370 1.800
17.880 28.740 21.580 1.800
18.040 29.960 20.850 1.800
18.930 27.760 21.060 1.800
16.230 26.900 22.120 1.800
16.120 26.800 23.340 1.800
15.840 25.920 21.310 1.800
15.910 24.490 21.650 1.800
15.280 23.660 20.530 1.800
16.000 23.570 19.300 1.800
13.820 24.020 20.240 1.800
17.310 23.990 22.020 1.800
18.290 24.540 21.540 1.800
17.250 22.870 22.750 1.800
18.490 22.190 23.130 1.800
18.090 21.100 24.140 1.800
19.230 20.240 24.670 1.800
18.880 19.190 25.720 1.800
17.970 19.340 26.560 1.800
19.630 18.190 25.670 1.800
19.470 21.860 22.000 1.800
20.600 22.320 21.950 1.800
18.840 21.210 21.030 1.800
19.470 20.850 19.750 1.800
18.540 20.140 18.760 1.800
19.070 19.900 17.450 1.800
20.330 21.920 19.060 1.800
21.510 21.740 18.780 1.800
19.630 23.040 18.890 1.800
20.180 24.300 18.400 1.800
19.100 25.370 18.220 1.800
18.090 25.100 17.110 1.800
17.010 26.150 17.360 1.800
16.310 26.070 18.390 1.800
16.840 27.040 16.500 1.800
21.380 24.860 19.170 1.800
22.430 25.100 18.570 1.800
21.250 24.880 20.490 1.800
22.340 25.140 21.440 1.800
22.080 25.140 22.950 1.800
23.190 25.700 23.840 1.800
20.740 25.660 23.470 1.800
23.490 24.170 21.150 1.800
24.460 24.680 20.580 1.800
23.220 22.870 21.100 1.800
24.200 21.850 20.710 1.800
23.540 20.480 20.870 1.800
23.000 20.110 22.260 1.800
24.360 19.780 23.440 1.800
24.530 18.040 23.110 1.800
25.030 22.090 19.440 1.800
26.200 21.730 19.320 1.800
24.280 22.510 18.420 1.800
24.770 22.920 17.100 1.800
23.630 23.400 16.200 1.800
22.550 22.430 15.710 1.800
23.080 21.220 14.950 1.800
21.890 20.360 14.520 1.800
22.400 19.000 14.280 1.800
25.920 23.930 17.250 1.800
27.010 23.690 16.730 1.800
25.590 25.000 17.970 1.800
26.550 26.070 18.270 1.800
25.880 27.250 18.970 1.800
24.950 27.990 18.010 1.800
23.570 27.810 17.920 1.800
25.500 29.090 17.360 1.800
22.790 28.610 17.100 1.800
24.730 29.920 16.550 1.800
23.380 29.670 16.400 1.800
22.570 30.310 15.510 1.800
27.780 25.630 19.060 1.800
28.930 26.020 18.850 1.800
27.560 24.670 19.960 1.800
28.620 23.970 20.700 1.800
28.000 23.130 21.810 1.800
27.120 23.990 22.720 1.800
29.070 22.420 22.650 1.800
25.950 23.270 23.390 1.800
29.630 23.190 19.850 1.800
30.800 23.560 19.750 1.800
29.100 22.230 19.100 1.800
29.830 21.480 18.060 1.800
28.840 20.530 17.380 1.800
28.220 19.670 18.340 1.800
29.430 19.700 16.240 1.800
30.540 22.410 17.070 1.800
31.760 22.310 16.970 1.800
29.940 23.560 16.780 1.800
30.490 24.610 15.910 1.800
29.550 25.750 15.520 1.800
28.660 25.190 14.560 1.800
31.780 25.150 16.530 1.800
32.860 25.060 15.950 1.800
31.670 25.640 17.760 1.800
32.770 26.220 18.540 1.800
32.280 26.890 19.830 1.800
31.230 27.980 19.640 1.800
30.360 28.090 20.900 1.800
31.820 29.350 19.300 1.800
33.920 25.270 18.860 1.800
35.110 25.550 18.950 1.800
33.520 24.030 19.160 1.800
34.400 22.870 19.340 1.800
33.650 21.550 19.510 1.800
32.920 21.450 20.850 1.800
33.390 21.990 21.850 1.800
31.810 20.740 20.970 1.800
35.320 22.590 18.140 1.800
36.530 22.430 18.300 1.800
34.740 22.770 16.960 1.800
35.450 22.550 15.680 1.800
34.400 22.160 14.640 1.800
34.330 20.630 14.610 1.800
33.150 20.180 13.740 1.800
33.040 20.610 12.580 1.800
32.410 19.330 14.290 1.800
36.400 23.660 15.240 1.800
37.440 23.450 14.610 1.800
35.890 24.870 15.410 1.800
36.690 26.070 15.100 1.800
35.820 27.270 15.490 1.800
36.300 28.660 15.050 1.800
37.530 28.800 14.850 1.800
35.330 29.420 14.850 1.800
38.080 26.180 15.710 1.800
38.230 26.470 16.900 1.800
39.080 25.990 14.850 1.800
40.490 26.000 15.280 1.800
41.380 25.500 14.150 1.800
41.280 26.430 13.060 1.800
40.980 27.290 15.940 1.800
41.940 27.230 16.720 1.800
40.370 28.400 15.540 1.800
40.710 29.720 16.100 1.800
40.270 30.910 15.230 1.800
38.860 31.070 15.130 1.800
40.900 30.740 13.840 1.800
40.290 29.930 17.560 1.800
40.890 30.670 18.330 1.800
39.080 29.440 17.840 1.800
38.490 29.330 19.180 1.800
36.980 29.090 19.240 1.800
36.350 29.200 20.640 1.800
36.200 30.060 18.350 1.800
39.280 28.370 20.060 1.800
38.920 27.230 20.350 1.800
40.130 29.080 20.790 1.800
40.980 28.480 21.830 1.800
42.150 29.380 22.270 1.800
43.030 29.640 21.040 1.800
43.280 28.690 20.140 1.800
43.280 30.810 20.470 1.800
43.840 29.240 19.070 1.800
43.750 30.550 19.260 1.800
40.260 27.930 23.060 1.800
40.700 26.940 23.650 1.800
39.280 28.730 23.470 1.800
38.370 28.350 24.570 1.800
36.990 29.010 24.530 1.800
36.770 30.090 23.990 1.800
36.020 28.350 25.150 1.800
34.640 28.870 25.200 1.800
33.860 28.610 23.910 1.800
33.450 27.160 23.640 1.800
34.350 26.330 22.970 1.800
32.140 26.750 23.830 1.800
33.980 25.060 22.550 1.800
31.700 25.520 23.350 1.800
32.640 24.710 22.710 1.800
33.880 28.310 26.400 1.800
34.280 27.410 27.130 1.800
32.720 28.950 26.590 1.800
31.770 28.750 27.690 1.800
32.150 29.650 28.870 1.800
32.030 31.170 28.710 1.800
30.910 31.640 29.630 1.800
33.290 31.980 29.030 1.800
30.310 28.940 27.270 1.800
30.080 29.600 26.260 1.800
29.450 28.370 28.110 1.800
28.060 28.800 27.930 1.800
27.160 27.580 27.710 1.800
25.710 28.020 27.500 1.800
27.420 26.660 26.520 1.800
27.650 29.610 29.150 1.800
27.760 29.200 30.310 1.800
27.020 30.760 28.920 1.800
26.540 31.730 29.920 1.800
26.230 33.100 29.310 1.800
25.920 34.200 30.320 1.800
27.050 34.430 31.330 1.800
28.190 34.710 30.980 1.800
26.660 34.430 32.600 1.800
25.220 31.230 30.520 1.800
24.160 31.190 29.910 1.800
25.480 30.530 31.620 1.800
24.380 30.050 32.470 1.800
25.010 28.870 33.220 1.800
25.770 27.840 32.380 1.800
26.500 26.870 33.320 1.800
25.010 27.180 31.230 1.800
23.820 31.070 33.460 1.800
24.380 32.170 33.490 1.800
22.650 30.820 34.040 1.800
21.630 29.900 33.540 1.800
20.570 29.890 34.650 1.800
20.700 31.290 35.260 1.800
22.200 31.540 35.250 1.800
20.960 30.290 32.230 1.800
21.120 31.380 31.700 1.800
20.680 29.220 31.470 1.800
19.990 29.250 30.170 1.800
19.980 27.850 29.570 1.800
21.390 27.290 29.380 1.800
21.190 25.790 29.130 1.800
22.090 27.940 28.180 1.800
18.550 29.750 30.110 1.800
17.660 29.230 30.790 1.800
18.320 30.890 29.460 1.800
17.040 31.600 29.340 1.800
17.390 33.090 29.400 1.800
16.310 34.150 29.530 1.800
15.260 34.020 30.200 1.800
16.520 35.230 28.930 1.800
16.270 31.290 28.060 1.800
16.630 31.760 26.980 1.800
15.430 30.270 28.230 1.800
14.850 29.590 27.060 1.800
15.650 28.380 26.600 1.800
15.080 27.760 25.440 1.800
13.440 29.180 27.500 1.800
13.220 28.700 28.620 1.800
12.550 29.350 26.530 1.800
11.210 28.760 26.710 1.800
10.300 29.470 25.700 1.800
10.640 29.290 24.220 1.800
9.660 29.980 23.270 1.800
9.560 31.220 23.390 1.800
8.920 29.270 22.560 1.800
11.010 27.250 26.670 1.800
10.180 26.630 27.350 1.800
12.120 26.680 26.220 1.800
12.180 25.220 26.040 1.800
12.840 24.810 24.720 1.800
12.170 25.380 23.470 1.800
10.960 25.460 23.270 1.800
12.960 25.980 22.590 1.800
13.040 24.510 27.070 1.800
14.070 25.060 27.470 1.800
12.620 23.300 27.450 1.800
13.360 22.390 28.340 1.800
12.560 21.120 28.660 1.800
11.250 21.310 29.190 1.800
14.710 22.080 27.700 1.800
14.800 21.790 26.510 1.800
15.790 22.410 28.410 1.800
17.180 22.190 27.980 1.800
17.840 23.430 27.380 1.800
17.100 23.840 26.110 1.800
19.310 23.210 27.020 1.800
17.470 25.240 25.600 1.800
18.060 21.710 29.140 1.800
18.280 22.430 30.110 1.800
18.730 20.600 28.850 1.800
19.650 19.950 29.780 1.800
19.920 18.540 29.230 1.800
20.460 17.720 30.400 1.800
21.330 18.090 31.190 1.800
20.050 16.450 30.410 1.800
20.970 20.720 29.740 1.800
21.670 20.560 28.740 1.800
21.250 21.370 30.870 1.800
22.480 22.170 31.030 1.800
22.430 22.960 32.340 1.800
21.260 23.770 32.320 1.800
23.690 23.720 32.760 1.800
23.680 21.220 30.980 1.800
24.500 21.320 30.080 1.800
23.590 20.130 31.750 1.800
24.650 19.120 31.840 1.800
24.210 17.980 32.770 1.800
25.300 17.030 33.240 1.800
24.780 15.920 34.160 1.800
24.730 16.000 35.410 1.800
24.410 14.860 33.610 1.800
25.000 18.550 30.470 1.800
26.150 18.560 30.010 1.800
23.920 18.160 29.790 1.800
24.100 17.730 28.400 1.800
22.850 17.100 27.780 1.800
22.550 15.710 28.340 1.800
21.520 14.900 27.550 1.800
21.390 15.120 26.330 1.800
20.700 14.180 28.160 1.800
24.660 18.730 27.390 1.800
25.520 18.350 26.600 1.800
24.300 19.990 27.600 1.800
24.840 21.160 26.890 1.800
24.050 22.400 27.290 1.800
24.750 23.700 26.900 1.800
22.740 22.440 26.490 1.800
26.310 21.320 27.290 1.800
27.190 21.410 26.430 1.800
26.600 21.450 28.580 1.800
27.930 21.570 29.190 1.800
27.650 21.690 30.690 1.800
27.040 23.060 31.010 1.800
28.710 21.270 31.710 1.800
27.660 24.350 30.490 1.800
28.990 20.530 28.820 1.800
29.990 20.830 28.170 1.800
28.600 19.260 28.800 1.800
29.450 18.090 28.510 1.800
28.770 16.800 28.990 1.800
29.010 16.740 30.500 1.800
30.040 17.200 30.980 1.800
28.010 16.170 31.180 1.800
29.780 17.930 27.020 1.800
30.630 17.130 26.640 1.800
28.940 18.530 26.190 1.800
29.160 18.590 24.730 1.800
27.990 19.300 24.070 1.800
30.430 19.370 24.400 1.800
30.920 19.200 23.290 1.800
30.710 20.390 25.210 1.800
31.910 21.230 25.100 1.800
32.070 22.360 26.100 1.800
30.780 23.180 26.180 1.800
33.270 23.290 25.860 1.800
30.650 24.070 27.410 1.800
33.150 20.340 25.210 1.800
33.390 19.630 26.200 1.800
34.060 20.650 24.300 1.800
35.460 20.200 24.290 1.800
36.240 20.890 23.170 1.800
36.110 20.440 25.660 1.800
36.050 21.610 26.050 1.800
36.640 19.440 26.350 1.800
37.350 19.630 27.620 1.800
37.500 18.220 28.190 1.800
37.440 17.300 26.960 1.800
36.660 18.040 25.880 1.800
38.590 20.520 27.480 1.800
38.700 21.410 28.310 1.800
39.160 20.430 26.280 1.800
40.300 21.270 25.880 1.800
40.950 20.820 24.580 1.800
41.420 19.360 24.690 1.800
40.370 18.280 24.470 1.800
39.460 18.560 23.660 1.800
40.530 17.170 25.030 1.800
40.000 22.780 25.880 1.800
40.860 23.620 26.110 1.800
38.750 23.120 25.560 1.800
38.200 24.470 25.410 1.800
37.300 24.640 24.190 1.800
38.070 24.280 22.910 1.800
37.470 24.910 21.650 1.800
38.100 24.230 20.430 1.800
37.880 24.780 19.090 1.800
37.430 24.990 26.630 1.800
37.080 26.170 26.660 1.800
37.120 24.120 27.600 1.800
36.250 24.450 28.730 1.800
35.730 23.090 29.220 1.800
34.930 23.050 30.520 1.800
34.230 24.030 30.870 1.800
34.930 21.970 31.150 1.800
36.840 25.320 29.850 1.800
37.060 24.770 30.920 1.800
37.140 26.550 29.450 1.800
37.760 27.590 30.280 1.800
37.810 28.900 29.490 1.800
39.050 28.790 28.600 1.800
36.570 29.240 28.650 1.800
37.060 27.820 31.620 1.800
37.670 28.490 32.460 1.800
35.820 27.380 31.750 1.800
35.100 27.350 33.030 1.800
33.650 27.600 32.610 1.800
33.220 29.070 32.760 1.800
33.700 29.820 33.640 1.800
32.170 29.390 32.170 1.800
35.230 26.130 33.940 1.800
34.730 26.150 35.070 1.800
35.520 25.030 33.260 1.800
35.810 23.750 33.920 1.800
34.510 23.160 34.480 1.800
34.540 22.590 35.570 1.800
33.570 22.920 33.570 1.800
32.220 22.540 34.010 1.800
31.070 23.490 33.670 1.800
31.330 24.820 34.380 1.800
30.300 25.900 34.030 1.800
31.230 24.750 35.910 1.800
31.820 21.160 33.480 1.800
30.820 20.610 33.940 1.800
32.500 20.730 32.420 1.800
32.300 19.390 31.850 1.800
33.230 19.110 30.670 1.800
34.610 19.270 31.000 1.800
33.040 20.030 29.460 1.800
32.750 18.320 32.850 1.800
33.760 18.490 33.520 1.800
32.010 17.210 32.850 1.800
32.230 16.090 33.770 1.800
31.290 14.920 33.520 1.800
29.930 15.340 33.730 1.800
33.660 15.560 33.770 1.800
34.180 15.190 34.820 1.800
34.310 15.510 32.600 1.800
35.760 15.340 32.450 1.800
36.130 15.570 30.990 1.800
35.260 14.600 30.190 1.800
37.640 15.360 30.860 1.800
35.550 14.570 28.680 1.800
36.600 16.200 33.410 1.800
37.390 15.640 34.170 1.800
36.600 17.510 33.180 1.800
37.310 18.460 34.050 1.800
37.300 19.830 33.370 1.800
38.130 19.840 32.080 1.800
39.090 19.100 31.850 1.800
37.660 20.550 31.060 1.800
36.910 18.420 35.530 1.800
37.820 18.300 36.340 1.800
35.660 18.010 35.770 1.800
35.100 17.850 37.110 1.800
33.590 17.700 36.960 1.800
35.730 16.640 37.810 1.800
36.470 16.800 38.780 1.800
35.650 15.550 37.060 1.800
36.190 14.250 37.480 1.800
37.690 14.240 37.750 1.800
38.130 13.540 38.660 1.800
38.370 14.990 36.880 1.800
39.790 15.250 37.160 1.800
40.350 16.020 35.960 1.800
40.500 15.160 34.700 1.800
40.630 16.030 33.450 1.800
40.890 15.240 32.230 1.800
40.990 15.660 30.960 1.800
40.910 16.960 30.640 1.800
41.500 14.900 29.980 1.800
40.050 16.000 38.470 1.800
40.540 15.370 39.410 1.800
39.500 17.180 38.720 1.800
39.690 17.950 39.950 1.800
38.860 19.220 39.770 1.800
38.830 20.200 40.950 1.800
40.200 20.690 41.440 1.800
37.780 21.290 40.710 1.800
39.240 17.200 41.200 1.800
40.040 17.020 42.120 1.800
38.020 16.660 41.140 1.800
37.310 15.790 42.080 1.800
35.980 15.260 41.540 1.800
38.180 14.660 42.650 1.800
38.300 14.590 43.870 1.800
39.000 14.160 41.730 1.800
39.910 13.050 42.050 1.800
39.720 11.840 41.120 1.800
38.350 11.160 41.050 1.800
38.090 10.470 42.400 1.800
36.700 9.990 42.320 1.800
35.620 10.610 42.820 1.800
35.650 11.740 43.530 1.800
34.410 10.120 42.540 1.800
41.390 13.430 42.110 1.800
42.220 12.570 42.380 1.800
41.700 14.720 42.270 1.800
43.000 15.390 42.350 1.800
44.020 15.130 41.240 1.800
45.220 15.250 41.470 1.800
43.460 15.070 40.030 1.800
44.130 15.060 38.730 1.800
43.360 14.120 37.800 1.800
43.430 12.600 37.930 1.800
44.560 12.180 38.270 1.800
42.410 11.920 37.670 1.800
44.150 16.500 38.220 1.800
43.340 16.840 37.360 1.800
45.150 17.280 38.630 1.800
45.280 18.740 38.540 1.800
45.640 19.240 39.940 1.800
44.400 19.700 40.720 1.800
43.460 18.590 41.180 1.800
44.790 20.650 41.860 1.800
46.100 19.300 37.370 1.800
45.780 20.380 36.880 1.800
47.090 18.530 36.950 1.800
47.890 18.860 35.760 1.800
49.010 17.850 35.500 1.800
50.040 17.870 36.630 1.800
51.080 18.530 36.590 1.800
50.070 16.810 37.430 1.800
47.010 18.890 34.500 1.800
47.060 19.770 33.640 1.800
45.920 18.130 34.590 1.800
45.070 17.790 33.450 1.800
44.400 16.410 33.530 1.800
45.410 15.270 33.330 1.800
46.450 15.470 32.670 1.800
45.090 14.200 33.890 1.800
43.900 18.710 33.090 1.800
43.530 18.830 31.920 1.800
43.260 19.350 34.060 1.800
41.970 20.050 33.970 1.800
41.070 19.430 35.050 1.800
41.470 19.790 36.800 1.800
41.980 21.570 34.120 1.800
42.970 22.240 34.400 1.800
40.810 22.020 33.680 1.800
40.270 23.340 34.020 1.800
39.350 23.830 32.900 1.800
40.060 24.230 31.610 1.800
40.660 25.480 31.470 1.800
40.060 23.340 30.540 1.800
41.130 25.900 30.230 1.800
40.540 23.730 29.300 1.800
41.060 25.020 29.170 1.800
39.520 23.280 35.350 1.800
38.860 22.300 35.680 1.800
39.880 24.190 36.260 1.800
39.120 24.290 37.510 1.800
40.120 24.230 38.660 1.800
41.030 23.000 38.680 1.800
39.460 24.530 40.010 1.800
42.380 23.230 39.360 1.800
38.140 25.470 37.550 1.800
38.490 26.540 37.070 1.800
36.860 25.320 37.890 1.800
35.840 26.380 37.920 1.800
34.600 25.780 38.580 1.800
34.700 24.280 38.310 1.800
36.200 24.020 38.100 1.800
36.320 27.650 38.630 1.800
37.110 27.640 39.580 1.800
36.050 28.690 37.850 1.800
36.660 29.990 38.120 1.800
36.450 30.960 36.950 1.800
36.880 30.160 35.360 1.800
36.420 30.650 39.480 1.800
37.410 31.080 40.080 1.800
35.210 30.690 40.020 1.800
34.930 31.170 41.380 1.800
33.400 31.220 41.480 1.800
32.990 32.210 40.530 1.800
32.880 31.660 42.850 1.800
35.740 30.400 42.420 1.800
36.500 31.120 43.070 1.800
35.660 29.080 42.520 1.800
36.620 28.240 43.250 1.800
36.380 26.820 42.730 1.800
34.850 26.850 42.630 1.800
34.570 28.230 42.020 1.800
38.070 28.740 43.160 1.800
38.760 28.930 44.160 1.800
38.640 28.770 41.960 1.800
39.980 29.270 41.640 1.800
40.110 29.520 40.140 1.800
40.520 28.220 39.440 1.800
40.500 28.420 37.920 1.800
41.860 28.960 37.460 1.800
42.970 28.010 37.610 1.800
40.240 30.670 42.220 1.800
41.200 30.880 42.950 1.800
39.420 31.660 41.890 1.800
39.490 33.010 42.460 1.800
39.480 33.150 43.980 1.800
40.330 33.810 44.590 1.800
38.660 32.250 44.520 1.800
38.580 31.990 45.960 1.800
37.370 31.090 46.220 1.800
35.710 31.740 45.780 1.800
39.880 31.450 46.570 1.800
40.280 31.860 47.660 1.800
40.400 30.420 45.910 1.800
41.670 29.800 46.280 1.800
42.170 28.650 45.400 1.800
43.310 27.720 45.810 1.800
42.970 26.890 47.050 1.800
43.710 26.810 44.640 1.800
42.830 30.790 46.410 1.800
43.720 30.610 47.250 1.800
42.890 31.600 45.350 1.800
43.750 32.770 45.150 1.800
43.760 33.300 43.710 1.800
44.970 34.140 43.310 1.800
46.210 33.270 43.090 1.800
46.670 32.580 44.020 1.800
46.800 33.210 41.990 1.800
43.670 33.840 46.240 1.800
44.690 34.030 46.890 1.800
42.430 34.140 46.600 1.800
42.160 34.920 47.820 1.800
40.640 35.060 47.810 1.800
40.300 36.110 46.740 1.800
38.810 35.860 46.480 1.800
40.500 37.520 47.300 1.800
42.590 34.320 49.160 1.800
43.150 35.110 49.910 1.800
42.510 33.010 49.400 1.800
43.080 32.250 50.510 1.800
42.640 30.780 50.560 1.800
41.110 30.770 50.620 1.800
43.160 30.100 51.830 1.800
40.480 29.540 49.970 1.800
44.600 32.420 50.520 1.800
45.160 32.260 51.600 1.800
45.200 32.210 49.340 1.800
46.660 32.250 49.190 1.800
47.060 31.760 47.800 1.800
47.050 30.270 47.480 1.800
47.680 30.140 46.090 1.800
47.530 28.670 45.680 1.800
48.210 28.600 44.370 1.800
47.360 33.570 49.510 1.800
48.360 33.610 50.220 1.800
46.630 34.580 49.030 1.800
46.970 35.980 49.280 1.800
45.830 36.710 48.580 1.800
46.030 37.180 47.140 1.800
47.380 37.850 46.840 1.800
47.880 38.800 47.490 1.800
47.910 37.420 45.800 1.800
47.150 36.430 50.730 1.800
47.350 37.630 50.920 1.800
46.640 35.630 51.660 1.800
46.790 35.620 53.120 1.800
45.840 34.740 53.930 1.800
46.220 33.360 53.820 1.800
44.380 34.900 53.530 1.800
48.200 35.370 53.670 1.800
48.620 36.080 54.580 1.800
48.910 34.460 53.030 1.800
50.160 33.810 53.470 1.800
50.060 32.460 54.190 1.800
51.000 31.680 54.340 1.800
48.940 32.360 54.900 1.800
48.580 31.160 55.660 1.800
47.280 31.340 56.450 1.800
47.020 30.240 57.480 1.800
47.250 32.640 57.250 1.800
48.380 29.930 54.770 1.800
47.510 29.930 53.900 1.800
49.140 28.890 55.100 1.800
49.040 27.670 54.300 1.800
50.090 26.730 54.890 1.800
51.200 27.700 55.280 1.800
50.390 28.850 55.880 1.800
47.680 26.990 54.530 1.800
47.090 27.240 55.580 1.800
47.210 26.290 53.500 1.800
45.940 25.550 53.450 1.800
45.340 25.400 52.050 1.800
45.120 26.840 51.590 1.800
43.980 24.710 51.940 1.800
46.030 27.080 50.380 1.800
46.170 24.160 54.060 1.800
45.450 23.740 54.970 1.800
47.270 23.470 53.790 1.800
47.520 22.100 54.230 1.800
48.930 21.730 53.740 1.800
47.570 22.080 55.760 1.800
48.010 23.020 56.430 1.800
46.810 21.160 56.340 1.800
46.560 20.910 57.770 1.800
45.310 21.620 58.300 1.800
44.640 21.060 59.170 1.800
45.050 22.830 57.800 1.800
43.970 23.730 58.230 1.800
44.050 25.040 57.430 1.800
45.240 25.990 57.560 1.800
45.200 26.840 58.830 1.800
45.630 26.020 59.970 1.800
45.470 26.350 61.260 1.800
44.940 27.500 61.700 1.800
46.100 25.550 62.130 1.800
42.600 23.140 57.920 1.800
42.400 22.440 56.930 1.800
41.580 23.490 58.700 1.800
40.210 22.970 58.540 1.800
39.580 22.580 59.870 1.800
38.330 21.700 59.880 1.800
38.330 20.370 60.020 1.800
37.090 22.050 59.540 1.800
37.140 19.870 59.710 1.800
36.380 20.940 59.460 1.800
39.420 23.920 57.640 1.800
38.970 25.000 58.050 1.800
38.780 23.340 56.630 1.800
38.020 24.070 55.610 1.800
38.550 23.770 54.200 1.800
36.570 23.580 55.690 1.800
36.260 22.410 55.890 1.800
35.700 24.580 55.810 1.800
34.240 24.450 55.770 1.800
33.660 24.890 57.120 1.800
32.140 24.750 57.010 1.800
34.180 23.980 58.240 1.800
33.660 25.190 54.560 1.800
33.770 26.410 54.430 1.800
33.180 24.340 53.650 1.800
32.480 24.740 52.420 1.800
32.810 23.740 51.310 1.800
32.030 24.000 50.010 1.800
34.310 23.850 51.030 1.800
30.970 24.740 52.640 1.800
30.440 23.650 52.840 1.800
30.330 25.910 52.570 1.800
28.870 26.000 52.670 1.800
28.390 26.980 53.740 1.800
26.930 26.700 54.110 1.800
29.130 26.940 55.080 1.800
28.240 26.290 51.310 1.800
28.400 27.370 50.750 1.800
27.520 25.280 50.810 1.800
26.950 25.110 49.470 1.800
27.790 24.130 48.640 1.800
28.970 24.200 48.970 1.800
27.170 23.310 47.800 1.800
27.730 22.130 47.120 1.800
27.160 20.810 47.650 1.800
25.650 20.580 47.620 1.800
25.180 19.170 47.950 1.800
23.770 19.100 48.370 1.800
23.200 18.080 49.020 1.800
23.960 17.090 49.510 1.800
21.990 18.170 49.600 1.800
27.720 22.180 45.590 1.800
28.080 21.200 44.940 1.800
27.420 23.370 45.090 1.800
27.180 23.630 43.660 1.800
26.620 24.940 43.110 1.800
27.540 26.040 43.100 1.800
28.230 23.200 42.630 1.800
29.410 23.270 42.980 1.800
27.770 22.820 41.440 1.800
28.750 22.410 40.430 1.800
27.940 21.940 39.220 1.800
27.180 20.640 39.520 1.800
26.570 20.320 38.160 1.800
25.580 19.170 37.960 1.800
25.630 18.630 36.590 1.800
29.770 23.460 39.990 1.800
30.910 23.160 39.640 1.800
29.300 24.700 40.040 1.800
30.010 25.930 39.670 1.800
28.990 27.060 39.520 1.800
27.820 26.760 38.590 1.800
29.670 28.360 39.060 1.800
28.090 26.220 37.180 1.800
31.000 26.250 40.790 1.800
32.130 26.670 40.560 1.800
30.540 26.260 42.040 1.800
31.290 26.820 43.180 1.800
30.600 28.020 43.830 1.800
31.590 28.730 44.750 1.800
30.010 28.990 42.810 1.800
31.480 25.720 44.230 1.800
32.640 25.390 44.470 1.800
30.480 25.420 45.060 1.800
30.560 24.410 46.120 1.800
31.440 23.170 46.040 1.800
32.430 22.950 46.740 1.800
31.080 22.290 45.100 1.800
31.740 21.000 44.860 1.800
30.860 20.120 43.960 1.800
33.210 21.120 44.460 1.800
34.020 20.650 45.250 1.800
33.490 21.960 43.460 1.800
34.870 22.410 43.180 1.800
34.790 23.060 41.800 1.800
33.360 23.590 41.640 1.800
32.580 22.630 42.530 1.800
35.650 23.060 44.320 1.800
36.820 22.730 44.490 1.800
34.990 23.950 45.060 1.800
35.660 24.660 46.170 1.800
34.740 25.610 46.940 1.800
35.510 26.700 47.690 1.800
36.590 27.870 46.800 1.800
38.170 27.150 47.190 1.800
36.210 23.590 47.120 1.800
37.400 23.660 47.430 1.800
35.390 22.580 47.380 1.800
35.700 21.480 48.310 1.800
34.520 20.560 48.630 1.800
34.930 19.190 49.170 1.800
34.870 18.030 48.520 1.800
35.510 18.900 50.330 1.800
35.560 17.140 49.220 1.800
35.930 17.640 50.400 1.800
36.970 20.780 47.840 1.800
37.890 20.390 48.550 1.800
36.850 20.280 46.610 1.800
37.880 19.540 45.870 1.800
37.480 19.160 44.440 1.800
36.170 18.450 44.120 1.800
35.790 17.650 45.000 1.800
35.550 18.920 43.140 1.800
39.240 20.250 45.830 1.800
40.200 19.650 46.290 1.800
39.250 21.550 45.540 1.800
40.450 22.390 45.650 1.800
40.460 23.860 45.230 1.800
40.190 24.150 43.750 1.800
39.860 25.640 43.830 1.800
41.490 23.910 42.990 1.800
41.080 22.470 47.050 1.800
42.270 22.170 47.060 1.800
40.370 22.720 48.150 1.800
40.890 22.830 49.520 1.800
39.800 23.340 50.470 1.800
39.360 24.750 50.070 1.800
37.900 24.940 50.480 1.800
40.200 25.870 50.680 1.800
41.350 21.430 49.920 1.800
42.380 21.320 50.580 1.800
40.600 20.380 49.590 1.800
41.050 19.020 49.890 1.800
39.920 18.040 49.580 1.800
40.260 16.600 49.990 1.800
40.000 16.330 51.470 1.800
39.570 15.510 49.170 1.800
42.410 18.610 49.310 1.800
43.220 18.120 50.090 1.800
42.530 18.810 48.000 1.800
43.780 18.450 47.300 1.800
43.490 18.440 45.800 1.800
42.490 17.310 45.500 1.800
41.270 17.550 45.040 1.800
42.520 15.980 45.900 1.800
40.520 16.450 45.080 1.800
41.290 15.460 45.530 1.800
43.550 15.170 46.360 1.800
41.050 14.110 45.750 1.800
43.310 13.820 46.540 1.800
42.050 13.290 46.270 1.800
44.950 19.310 47.780 1.800
46.070 18.820 47.730 1.800
44.660 20.590 48.030 1.800
45.510 21.480 48.840 1.800
45.100 22.890 48.410 1.800
45.730 23.160 47.050 1.800
46.860 23.620 46.890 1.800
44.890 23.120 46.020 1.800
45.640 21.330 50.360 1.800
45.690 22.200 51.230 1.800
45.420 20.050 50.650 1.800
45.720 19.320 51.890 1.800
47.240 19.180 51.950 1.800
47.710 18.070 51.000 1.800
47.090 17.010 50.920 1.800
48.700 18.390 50.180 1.800
45.050 19.810 53.170 1.800
45.360 19.480 54.320 1.800
43.960 20.560 53.020 1.800
43.110 20.850 54.190 1.800
42.330 22.100 53.810 1.800
42.160 19.730 54.600 1.800
41.850 18.880 53.750 1.800
41.690 19.830 55.840 1.800
40.680 18.900 56.360 1.800
40.930 18.760 57.860 1.800
42.270 18.330 58.130 1.800
39.960 17.690 58.370 1.800
39.310 19.500 56.020 1.800
38.940 20.520 56.610 1.800
38.610 18.900 55.070 1.800
37.480 19.660 54.510 1.800
37.470 19.870 53.000 1.800
36.430 20.940 52.670 1.800
38.850 20.360 52.560 1.800
36.100 19.100 54.850 1.800
35.790 17.930 54.630 1.800
35.260 19.980 55.390 1.800
33.850 19.610 55.550 1.800
33.390 20.070 56.940 1.800
34.210 19.470 57.940 1.800
31.900 19.920 57.240 1.800
33.070 20.400 54.500 1.800
33.260 21.560 54.130 1.800
32.080 19.690 53.960 1.800
30.990 20.210 53.110 1.800
30.910 19.490 51.760 1.800
32.210 19.470 51.180 1.800
29.910 20.110 50.780 1.800
29.640 20.150 53.820 1.800
29.210 19.080 54.260 1.800
29.050 21.330 53.950 1.800
27.690 21.650 54.420 1.800
27.770 22.730 55.500 1.800
28.960 22.460 56.860 1.800
26.680 22.110 53.370 1.800
27.090 22.890 52.500 1.800
25.400 21.860 53.630 1.800
24.300 22.210 52.730 1.800
24.130 21.000 51.800 1.800
24.010 19.650 52.500 1.800
22.810 19.130 52.740 1.800
24.990 18.820 52.840 1.800
23.090 17.880 53.100 1.800
24.400 17.680 53.180 1.800
23.030 22.510 53.530 1.800
23.110 22.450 54.760 1.800
21.920 22.630 52.810 1.800
20.600 22.890 53.400 1.800
19.480 23.180 52.390 1.800
19.140 22.040 51.600 1.800
20.070 21.820 54.340 1.800
19.550 22.260 55.370 1.800
20.430 20.550 54.160 1.800
20.060 19.510 55.130 1.800
19.840 18.130 54.500 1.800
18.450 18.000 53.880 1.800
18.210 18.810 52.600 1.800
16.760 19.310 52.470 1.800
15.750 18.290 52.140 1.800
20.960 19.330 56.360 1.800
20.740 18.480 57.220 1.800
22.050 20.090 56.380 1.800
23.020 20.120 57.480 1.800
24.310 20.770 56.960 1.800
24.810 20.000 55.880 1.800
25.420 20.910 58.000 1.800
22.470 20.780 58.750 1.800
21.840 21.830 58.720 1.800
22.490 19.930 59.780 1.800
22.170 20.250 61.180 1.800
21.880 18.990 61.990 1.800
23.300 20.980 61.910 1.800
24.480 20.740 61.640 1.800
22.890 21.990 62.670 1.800
23.700 22.900 63.500 1.800
24.210 22.160 64.740 1.800
23.090 21.420 65.460 1.800
22.120 22.020 66.140 1.800
22.860 20.130 65.670 1.800
21.350 21.140 66.770 1.800
21.760 19.930 66.400 1.800
24.760 23.420 62.520 1.800
25.930 23.060 62.670 1.800
24.290 24.220 61.580 1.800
25.240 24.930 60.700 1.800
24.510 25.810 59.690 1.800
25.320 26.260 58.480 1.800
25.770 25.100 57.590 1.800
24.650 27.300 57.570 1.800
26.190 25.860 61.460 1.800
27.390 25.800 61.200 1.800
25.790 26.530 62.530 1.800
26.550 27.460 63.380 1.800
25.590 28.030 64.430 1.800
25.120 27.170 65.610 1.800
24.790 26.000 65.340 1.800
25.360 27.600 66.760 1.800
27.730 26.750 64.040 1.800
28.840 27.280 64.000 1.800
27.530 25.540 64.540 1.800
28.640 24.650 64.890 1.800
28.080 23.430 65.630 1.800
27.530 23.770 67.020 1.800
26.880 22.560 67.680 1.800
27.410 21.430 67.670 1.800
25.990 22.750 68.540 1.800
29.530 24.300 63.690 1.800
30.730 24.360 63.930 1.800
29.000 23.730 62.620 1.800
29.780 23.290 61.450 1.800
28.890 22.690 60.360 1.800
28.260 21.380 60.830 1.800
29.220 20.230 61.170 1.800
30.300 20.070 60.560 1.800
28.790 19.370 61.960 1.800
30.670 24.380 60.870 1.800
31.710 24.010 60.320 1.800
30.210 25.620 60.700 1.800
31.010 26.790 60.310 1.800
30.110 28.030 60.250 1.800
30.730 29.370 59.860 1.800
29.050 27.780 59.180 1.800
32.160 27.060 61.280 1.800
33.240 27.540 60.930 1.800
31.930 26.950 62.580 1.800
32.780 27.310 63.730 1.800
31.950 27.290 65.010 1.800
32.630 27.990 66.180 1.800
32.950 27.320 67.160 1.800
32.730 29.310 66.040 1.800
34.090 26.530 63.840 1.800
35.060 27.010 64.420 1.800
34.020 25.320 63.280 1.800
35.150 24.470 62.900 1.800
34.740 23.140 62.280 1.800
34.000 22.390 63.400 1.800
33.530 21.080 62.770 1.800
32.640 20.410 63.820 1.800
31.940 19.230 63.290 1.800
36.170 25.150 61.990 1.800
37.370 25.110 62.260 1.800
35.630 25.970 61.090 1.800
36.330 26.610 59.970 1.800
37.580 27.410 60.320 1.800
37.370 28.550 60.730 1.800
38.770 26.910 60.010 1.800
39.920 27.830 59.900 1.800
41.240 27.070 59.820 1.800
41.440 26.320 61.140 1.800
41.630 27.040 62.150 1.800
41.630 25.090 61.120 1.800
39.880 28.730 58.660 1.800
40.360 29.850 58.560 1.800
39.470 28.030 57.600 1.800
39.060 28.550 56.290 1.800
39.770 27.970 55.070 1.800
41.290 27.900 55.260 1.800
39.390 28.800 53.840 1.800
42.040 26.750 54.600 1.800
37.550 28.290 56.200 1.800
37.120 27.150 56.390 1.800
36.850 29.310 55.720 1.800
35.430 29.290 55.360 1.800
34.690 30.090 56.440 1.800
33.170 30.030 56.380 1.800
32.640 28.700 56.940 1.800
32.590 31.260 57.070 1.800
35.130 29.840 53.960 1.800
35.310 31.050 53.810 1.800
34.680 28.950 53.080 1.800
34.120 29.410 51.800 1.800
34.930 28.990 50.580 1.800
34.490 29.780 49.350 1.800
36.450 29.100 50.750 1.800
32.620 29.090 51.770 1.800
32.290 27.910 51.740 1.800
31.900 30.170 51.510 1.800
30.440 30.110 51.430 1.800
29.750 30.820 52.600 1.800
28.290 30.370 52.620 1.800
30.420 30.780 53.970 1.800
29.840 30.650 50.130 1.800
29.960 31.840 49.850 1.800
29.160 29.740 49.450 1.800
28.380 30.110 48.260 1.800
29.080 29.840 46.920 1.800
27.050 29.360 48.230 1.800
26.860 28.250 47.720 1.800
26.110 30.080 48.830 1.800
24.740 29.640 49.120 1.800
24.490 29.670 50.630 1.800
24.870 30.970 51.100 1.800
25.270 28.680 51.500 1.800
23.550 30.350 48.470 1.800
22.560 29.770 48.030 1.800
23.690 31.660 48.260 1.800
22.700 32.540 47.620 1.800
21.740 33.160 48.640 1.800
20.600 33.500 48.310 1.800
22.220 33.130 49.880 1.800
21.350 33.410 51.030 1.800
21.160 32.170 51.900 1.800
20.570 30.960 51.160 1.800
19.180 31.190 50.550 1.800
18.360 32.080 50.800 1.800
18.920 30.220 49.690 1.800
21.910 34.550 51.890 1.800
22.800 34.310 52.710 1.800
21.410 35.760 51.680 1.800
21.980 37.020 52.190 1.800
20.940 38.080 51.810 1.800
19.670 37.230 51.650 1.800
20.210 36.030 50.870 1.800
22.280 37.030 53.690 1.800
21.450 36.940 54.590 1.800
23.570 37.240 53.960 1.800
24.090 37.310 55.330 1.800
23.850 38.690 55.930 1.800
24.340 39.750 54.940 1.800
24.000 41.190 55.330 1.800
22.900 41.380 55.910 1.800
24.830 42.120 55.310 1.800
23.680 36.180 56.290 1.800
23.780 36.400 57.500 1.800
23.350 35.020 55.730 1.800
22.970 33.840 56.520 1.800
22.710 32.700 55.520 1.800
22.290 31.310 56.010 1.800
22.200 30.220 54.540 1.800
23.710 29.360 54.940 1.800
24.030 33.390 57.530 1.800
23.750 33.290 58.720 1.800
25.260 33.260 57.050 1.800
26.410 32.830 57.860 1.800
27.560 32.240 57.040 1.800
28.820 31.960 57.870 1.800
27.250 31.010 56.180 1.800
26.780 34.050 58.710 1.800
26.950 35.110 58.100 1.800
26.470 33.940 59.990 1.800
26.490 35.030 60.980 1.800
25.550 34.680 62.130 1.800
24.060 34.760 61.780 1.800
23.680 36.200 61.430 1.800
22.390 36.350 60.620 1.800
22.380 37.700 60.040 1.800
27.900 35.140 61.560 1.800
28.650 34.170 61.620 1.800
28.270 36.360 61.970 1.800
29.540 36.710 62.610 1.800
29.830 35.770 63.790 1.800
30.830 35.060 63.700 1.800
28.910 35.560 64.720 1.800
29.070 34.640 65.860 1.800
27.650 34.470 66.420 1.800
27.400 35.460 67.560 1.800
25.960 35.960 67.720 1.800
25.140 35.320 68.410 1.800
25.680 37.050 67.160 1.800
29.660 33.260 65.570 1.800
30.300 32.670 66.440 1.800
29.240 32.720 64.430 1.800
29.690 31.390 64.000 1.800
28.860 31.000 62.770 1.800
27.340 30.960 62.930 1.800
26.660 31.360 64.000 1.800
26.460 30.760 61.880 1.800
25.370 31.430 63.690 1.800
25.210 31.020 62.430 1.800
26.680 30.240 60.610 1.800
24.110 30.640 61.670 1.800
25.520 29.950 59.890 1.800
24.240 30.110 60.390 1.800
31.140 31.330 63.540 1.800
31.830 30.310 63.580 1.800
31.720 32.420 63.020 1.800
33.120 32.470 62.570 1.800
33.500 33.850 62.010 1.800
32.550 34.480 60.990 1.800
34.930 33.960 61.490 1.800
32.150 33.580 59.820 1.800
34.040 32.270 63.770 1.800
34.090 33.000 64.760 1.800
34.790 31.200 63.560 1.800
35.990 30.860 64.340 1.800
36.610 29.590 63.750 1.800
37.780 28.980 64.520 1.800
38.310 27.770 63.760 1.800
39.560 27.250 64.480 1.800
39.760 25.830 64.180 1.800
36.950 32.050 64.390 1.800
37.150 32.730 63.380 1.800
37.210 32.460 65.630 1.800
38.210 33.480 65.960 1.800
38.430 33.230 67.460 1.800
36.990 32.920 67.860 1.800
36.610 31.850 66.830 1.800
39.570 33.290 65.280 1.800
40.270 32.300 65.480 1.800
39.710 34.110 64.240 1.800
40.920 34.210 63.430 1.800
40.790 33.420 62.120 1.800
41.790 32.880 61.670 1.800
39.590 33.350 61.560 1.800
39.360 32.580 60.330 1.800
37.930 32.040 60.350 1.800
39.490 33.430 59.070 1.800
39.490 34.650 58.970 1.800
39.660 32.640 58.010 1.800
39.770 33.080 56.610 1.800
40.900 32.420 55.830 1.800
42.240 32.580 56.550 1.800
41.020 33.070 54.450 1.800
43.340 31.610 56.110 1.800
38.370 32.850 56.040 1.800
37.850 31.740 55.930 1.800
37.720 33.980 55.730 1.800
36.310 34.000 55.310 1.800
35.550 34.800 56.380 1.800
34.100 35.110 56.020 1.800
35.490 33.900 57.620 1.800
36.190 34.540 53.890 1.800
36.590 35.670 53.630 1.800
35.870 33.620 52.970 1.800
35.700 33.860 51.530 1.800
36.610 32.890 50.770 1.800
38.030 32.630 51.280 1.800
36.420 33.000 49.260 1.800
38.970 33.830 51.140 1.800
34.240 33.670 51.120 1.800
33.630 32.630 51.350 1.800
33.690 34.850 50.830 1.800
32.250 34.960 50.550 1.800
31.730 36.030 51.530 1.800
30.260 36.440 51.440 1.800
29.470 35.700 50.830 1.800
30.000 37.510 52.030 1.800
31.910 35.310 49.100 1.800
32.380 36.290 48.530 1.800
31.050 34.420 48.600 1.800
30.680 34.390 47.180 1.800
30.740 32.940 46.700 1.800
32.340 32.110 46.990 1.800
29.330 35.030 46.840 1.800
28.900 35.020 45.680 1.800
28.690 35.620 47.840 1.800
27.290 36.070 47.820 1.800
27.150 37.330 46.970 1.800
27.880 38.320 47.090 1.800
26.050 37.380 46.230 1.800
25.640 38.580 45.480 1.800
26.020 38.470 44.010 1.800
27.480 38.270 43.600 1.800
25.370 39.630 43.240 1.800
28.340 39.360 44.240 1.800
24.130 38.470 45.660 1.800
23.460 37.560 45.180 1.800
23.800 39.080 46.800 1.800
22.380 39.280 47.110 1.800
22.080 38.580 48.440 1.800
22.740 37.200 48.530 1.800
22.230 36.150 48.180 1.800
23.840 37.130 49.280 1.800
22.250 40.800 47.190 1.800
23.010 41.440 47.910 1.800
21.200 41.410 46.640 1.800
20.920 42.840 46.510 1.800
20.020 43.020 45.280 1.800
20.740 42.630 43.980 1.800
21.860 43.330 43.550 1.800
20.200 41.560 43.280 1.800
22.510 42.850 42.420 1.800
20.870 41.110 42.150 1.800
22.060 41.720 41.760 1.800
22.820 41.090 40.820 1.800
20.060 43.360 47.660 1.800
19.050 42.750 48.030 1.800
20.240 44.560 48.210 1.800
21.410 45.430 47.990 1.800
21.240 46.580 48.980 1.800
22.330 47.650 48.960 1.800
22.620 47.850 50.450 1.800
24.050 48.390 50.550 1.800
24.580 48.550 51.910 1.800
22.700 44.640 48.200 1.800
22.660 43.850 49.140 1.800
23.700 44.770 47.330 1.800
24.820 43.830 47.180 1.800
25.660 44.120 45.930 1.800
26.390 42.870 45.450 1.800
24.800 44.530 44.730 1.800
25.660 43.670 48.450 1.800
26.710 44.280 48.660 1.800
25.250 42.560 49.060 1.800
25.810 42.000 50.300 1.800
24.780 42.110 51.420 1.800
24.660 43.610 51.690 1.800
23.380 41.510 51.270 1.800
26.030 40.490 50.130 1.800
25.280 39.780 49.470 1.800
27.000 39.980 50.890 1.800
27.290 38.540 50.760 1.800
26.410 37.600 51.580 1.800
25.280 37.910 51.930 1.800
26.820 36.340 51.450 1.800
26.150 35.240 52.150 1.800
26.560 33.880 51.560 1.800
25.870 33.610 50.220 1.800
24.820 34.220 49.930 1.800
26.270 32.660 49.520 1.800
26.380 35.210 53.670 1.800
25.720 34.560 54.470 1.800
27.420 35.980 53.980 1.800
27.970 36.090 55.340 1.800
29.470 35.790 55.250 1.800
30.150 35.870 56.620 1.800
29.590 34.340 54.780 1.800
27.680 37.500 55.860 1.800
27.490 38.480 55.130 1.800
27.360 37.610 57.140 1.800
27.170 38.950 57.730 1.800
26.520 38.770 59.100 1.800
28.590 39.480 57.950 1.800
29.340 39.090 58.840 1.800
28.930 40.370 57.020 1.800
30.240 41.010 56.920 1.800
30.370 41.910 55.700 1.800
31.740 42.540 55.420 1.800
32.830 41.940 54.790 1.800
31.940 43.850 55.830 1.800
34.060 42.530 54.530 1.800
33.180 44.440 55.690 1.800
34.240 43.820 55.030 1.800
35.500 44.280 55.260 1.800
30.690 41.800 58.160 1.800
31.770 41.580 58.710 1.800
29.810 42.740 58.500 1.800
30.050 43.670 59.610 1.800
28.810 44.550 59.700 1.800
28.880 45.990 59.180 1.800
28.390 46.290 58.070 1.800
29.390 46.850 59.930 1.800
30.310 43.000 60.960 1.800
30.930 43.610 61.830 1.800
29.640 41.860 61.150 1.800
29.870 40.890 62.230 1.800
28.680 39.930 62.150 1.800
27.410 40.710 62.510 1.800
26.080 39.950 62.510 1.800
26.060 38.730 62.770 1.800
25.110 40.650 62.140 1.800
31.200 40.150 62.040 1.800
32.180 40.180 62.780 1.800
31.270 39.370 60.970 1.800
32.460 38.580 60.620 1.800
32.160 37.800 59.340 1.800
33.850 39.210 60.640 1.800
34.720 38.590 61.260 1.800
33.920 40.440 60.140 1.800
35.170 41.220 60.240 1.800
35.140 42.600 59.580 1.800
33.930 43.480 59.900 1.800
33.970 44.820 59.160 1.800
32.840 45.680 59.720 1.800
32.640 46.910 58.950 1.800
35.840 41.360 61.610 1.800
37.060 41.230 61.740 1.800
34.980 41.450 62.620 1.800
35.270 41.490 64.060 1.800
34.150 42.160 64.860 1.800
33.770 43.570 64.400 1.800
34.580 44.720 65.000 1.800
35.790 44.620 65.290 1.800
34.080 45.820 65.320 1.800
35.750 40.170 64.680 1.800
36.040 40.110 65.870 1.800
35.590 39.110 63.900 1.800
36.010 37.760 64.300 1.800
34.900 36.720 64.400 1.800
34.200 36.860 65.760 1.800
33.020 35.890 65.740 1.800
32.650 35.740 67.160 1.800
32.810 34.590 67.840 1.800
33.210 33.460 67.240 1.800
32.760 34.610 69.180 1.800
37.130 37.130 63.460 1.800
37.920 36.390 64.040 1.800
36.950 37.240 62.150 1.800
37.910 36.720 61.160 1.800
37.340 36.840 59.740 1.800
39.220 37.500 61.170 1.800
39.370 38.480 61.900 1.800
40.220 36.830 60.610 1.800
41.530 37.440 60.330 1.800
42.690 36.470 60.550 1.800
42.370 35.260 59.870 1.800
41.640 38.050 58.930 1.800
42.230 39.120 58.800 1.800
41.120 37.310 57.960 1.800
41.050 37.830 56.590 1.800
42.010 37.090 55.660 1.800
43.470 37.300 56.050 1.800
44.250 36.380 56.750 1.800
44.170 38.340 55.450 1.800
45.600 36.520 57.020 1.800
45.540 38.490 55.630 1.800
46.250 37.580 56.410 1.800
39.640 37.530 56.060 1.800
39.020 36.490 56.300 1.800
39.090 38.470 55.300 1.800
37.720 38.450 54.780 1.800
36.780 39.030 55.830 1.800
35.330 38.740 55.440 1.800
37.030 40.530 56.030 1.800
34.400 38.790 56.650 1.800
37.660 39.200 53.450 1.800
38.490 40.060 53.140 1.800
36.860 38.620 52.550 1.800
36.500 39.170 51.240 1.800
36.100 38.010 50.320 1.800
35.020 37.230 50.840 1.800
37.390 37.250 49.990 1.800
35.300 40.130 51.240 1.800
34.250 39.640 51.650 1.800
35.360 41.360 50.750 1.800
34.250 42.320 50.700 1.800
34.960 43.650 50.430 1.800
36.190 43.220 49.630 1.800
36.650 41.970 50.390 1.800
33.260 41.950 49.600 1.800
33.530 41.300 48.590 1.800
32.000 42.330 49.810 1.800
30.960 42.330 48.770 1.800
29.900 41.270 49.040 1.800
28.810 41.180 47.970 1.800
30.540 39.880 49.140 1.800
30.350 43.720 48.560 1.800
30.070 44.350 49.580 1.800
30.430 44.180 47.310 1.800
31.250 43.630 46.220 1.800
30.710 44.290 44.950 1.800
30.070 45.570 45.490 1.800
29.480 45.200 46.850 1.800
32.740 43.910 46.420 1.800
33.250 44.260 47.490 1.800
33.510 43.270 45.550 1.800
34.920 43.610 45.370 1.800
35.880 42.580 45.970 1.800
37.080 42.870 45.960 1.800
35.430 41.350 46.160 1.800
36.290 40.310 46.750 1.800
36.340 39.200 45.690 1.800
37.270 39.130 44.900 1.800
35.390 38.270 45.750 1.800
35.400 37.090 44.870 1.800
34.470 35.980 45.360 1.800
34.170 34.770 44.470 1.800
35.050 35.410 46.660 1.800
35.010 37.400 43.420 1.800
35.710 37.050 42.480 1.800
33.970 38.220 43.300 1.800
33.420 38.550 41.970 1.800
34.440 38.950 40.900 1.800
34.520 38.160 39.970 1.800
35.350 39.900 41.100 1.800
36.350 40.180 40.070 1.800
36.920 41.540 40.490 1.800
36.910 41.560 42.020 1.800
35.650 40.730 42.280 1.800
37.370 39.060 39.910 1.800
37.930 38.930 38.820 1.800
37.770 38.370 40.980 1.800
38.670 37.210 40.930 1.800
38.920 36.750 42.370 1.800
39.680 37.770 43.220 1.800
41.390 38.070 42.620 1.800
42.100 36.450 42.770 1.800
38.190 36.110 39.980 1.800
38.960 35.440 39.290 1.800
36.880 35.930 40.050 1.800
36.100 35.010 39.210 1.800
34.590 35.130 39.430 1.800
34.350 34.490 40.690 1.800
33.730 34.440 38.380 1.800
36.540 35.220 37.760 1.800
37.160 34.450 37.020 1.800
36.390 36.490 37.390 1.800
36.680 36.990 36.040 1.800
36.150 38.410 35.900 1.800
36.290 38.930 34.460 1.800
34.700 38.600 36.360 1.800
38.130 36.810 35.580 1.800
38.370 36.200 34.540 1.800
39.130 37.120 36.400 1.800
40.580 37.020 36.150 1.800
41.310 37.570 37.370 1.800
40.920 35.550 35.900 1.800
41.570 35.220 34.910 1.800
40.360 34.620 36.670 1.800
40.630 33.180 36.560 1.800
39.990 32.480 37.760 1.800
40.670 32.760 39.100 1.800
42.450 32.320 39.170 1.800
43.190 33.700 40.020 1.800
40.220 32.600 35.200 1.800
41.120 32.080 34.550 1.800
39.040 32.950 34.700 1.800
38.490 32.730 33.350 1.800
37.070 33.310 33.290 1.800
36.360 33.050 31.960 1.800
36.240 31.540 31.720 1.800
35.070 33.860 31.870 1.800
39.470 33.150 32.260 1.800
39.920 32.240 31.570 1.800
39.760 34.450 32.270 1.800
40.840 35.030 31.470 1.800
41.050 36.460 31.980 1.800
39.820 37.350 32.040 1.800
39.160 37.750 30.380 1.800
37.590 36.910 30.370 1.800
42.160 34.240 31.430 1.800
42.560 33.740 30.380 1.800
42.620 33.850 32.610 1.800
43.850 33.060 32.770 1.800
44.020 32.970 34.290 1.800
45.360 32.380 34.710 1.800
45.230 32.100 36.200 1.800
45.360 32.920 37.120 1.800
44.930 30.870 36.580 1.800
43.820 31.640 32.200 1.800
44.820 31.090 31.740 1.800
42.620 31.090 32.360 1.800
42.220 29.820 31.720 1.800
40.990 29.230 32.400 1.800
41.360 28.720 33.690 1.800
42.040 29.920 30.210 1.800
42.490 29.020 29.490 1.800
41.580 31.050 29.680 1.800
41.580 31.280 28.230 1.800
40.760 32.520 27.870 1.800
39.570 32.380 28.640 1.800
40.260 32.320 26.440 1.800
42.980 31.480 27.640 1.800
43.290 31.010 26.540 1.800
43.830 32.140 28.420 1.800
45.260 32.340 28.130 1.800
45.860 33.400 29.060 1.800
47.360 33.600 28.810 1.800
45.180 34.760 28.890 1.800
45.980 30.990 28.090 1.800
46.830 30.710 27.240 1.800
45.640 30.110 29.020 1.800
46.090 28.720 29.150 1.800
45.850 28.190 30.560 1.800
46.750 27.020 30.950 1.800
46.270 26.350 32.240 1.800
46.180 27.030 33.280 1.800
45.710 25.240 32.100 1.800
45.700 27.790 28.000 1.800
46.610 27.320 27.330 1.800
44.440 27.960 27.580 1.800
43.920 27.150 26.480 1.800
42.410 27.300 26.290 1.800
42.030 28.670 26.120 1.800
44.710 27.380 25.190 1.800
45.200 26.490 24.490 1.800
44.730 28.650 24.800 1.800
45.490 29.350 23.760 1.800
45.480 30.870 23.920 1.800
46.980 29.010 23.800 1.800
47.570 28.870 22.730 1.800
47.630 29.110 24.960 1.800
49.040 28.700 25.060 1.800
49.530 29.190 26.430 1.800
50.850 28.670 26.990 1.800
51.730 29.770 27.590 1.800
52.950 29.080 28.210 1.800
53.890 30.090 28.710 1.800
49.180 27.200 24.780 1.800
50.040 26.780 24.000 1.800
48.320 26.420 25.410 1.800
48.290 24.960 25.200 1.800
47.290 24.150 26.020 1.800
47.590 23.780 27.470 1.800
46.570 22.760 28.000 1.800
46.470 22.810 29.460 1.800
46.450 21.810 30.360 1.800
46.680 20.510 30.110 1.800
46.190 22.110 31.640 1.800
48.030 24.510 23.760 1.800
48.520 23.410 23.490 1.800
47.380 25.320 22.920 1.800
47.190 25.090 21.490 1.800
46.150 26.100 21.000 1.800
45.830 26.050 19.500 1.800
45.060 25.010 18.980 1.800
46.330 27.040 18.670 1.800
44.720 25.060 17.630 1.800
45.930 27.160 17.350 1.800
45.130 26.130 16.850 1.800
48.460 25.170 20.640 1.800
48.660 24.320 19.770 1.800
49.240 26.180 21.020 1.800
50.530 26.510 20.410 1.800
50.930 27.930 20.840 1.800
49.940 28.980 20.330 1.800
50.430 30.190 21.120 1.800
49.970 29.220 18.820 1.800
51.700 25.600 20.800 1.800
52.560 25.350 19.960 1.800
51.670 25.140 22.050 1.800
52.520 24.110 22.660 1.800
52.170 24.000 24.150 1.800
52.790 25.030 25.100 1.800
52.590 24.730 26.590 1.800
52.860 23.590 27.010 1.800
52.320 25.760 27.250 1.800
52.380 22.730 22.020 1.800
51.506 22.616 20.984 1.800
53.141 21.729 22.538 1.800
- [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted, (continued)
- [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted, MrVH, 02/10/2011
- [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted, MrVH, 02/11/2011
- Re: [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted, Sebastien Loriot (GeometryFactory), 02/11/2011
- [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted, MrVH, 02/12/2011
- Re: [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted, Sebastien Loriot (GeometryFactory), 02/12/2011
- [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted, MrVH, 02/14/2011
- Re: [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted, Sebastien Loriot (GeometryFactory), 02/16/2011
