cgal-discuss - Re: [cgal-discuss] Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine..
  • To:
  • Subject: Re: [cgal-discuss] Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine..
  • Date: Fri, 18 Feb 2011 17:16:36 +0100
nyiotis wrote:
Hi,
I cannot run the examples for the 2D case (they build but I get no result ->
For these examples, did you have a warning or an error when running cmake ?
You said that example are built, but you have no result. What does this mean? no executable get generated?
Which platforms, compiler are you using?
S.
I have seen a possibe explanation through the posts for this absence of
warnings based on whether or not a number of flags have been during
configuration). Still, I do not get what I am missing. As far as I can
recall I never used TAUCS in the past in order to use the Delaunay
Triangulation modules (at least I hope so, since configuring TAUCs for a
snow mac is a pain). Again, the 3D case examples are running properly, so
TAUCS is out of the game. thanks
