[cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine..
- To:
- Subject: [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine..
- Date: Fri, 18 Feb 2011 08:52:07 -0800 (PST)
I am missing this link:
The CGAL project provides a modified version of TAUCS in the download
section of http://www.cgal.org. This version fixes some bugs, supports
64-bit platforms and allows a simplified installation process. It also
contains a complete LAPACK implementation.
CAUTION: Since version 3.3.1, CGAL is no longer compatible with the official
release of TAUCS (currently 2.2). Make sure to use the modified version
provided in the download section.
so, where is this link?
nyiotis wrote:
> Since I am not the only one complaining about the _fun-time_ one can have
> while installing taucs on a mac snow (see
> http://www.alecjacobson.com/weblog/?p=1191), could anyone point me to the
> right taucs-"edition" that is cgal friendly? I have read people referring
> on it in the forum, but I cannot spot right now...
> Also, note that I installed cgal 3.7 via macports and I take it that there
> are no updates with taucs on it.
> Thanks
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Cannot-run-the-examples-for-using-Delaunay-Triangulation-2-whereas-Delaunay-Triangulation-3-runs-fin-tp3313008p3313117.html
- [cgal-discuss] Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., nyiotis, 02/18/2011
- Re: [cgal-discuss] Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., Sebastien Loriot (GeometryFactory), 02/18/2011
- [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., nyiotis, 02/18/2011
- Re: [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., Sebastien Loriot (GeometryFactory), 02/18/2011
- Re: [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., Laurent Rineau (GeometryFactory), 02/18/2011
