cgal-discuss - [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine..
  • To:
  • Subject: [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine..
  • Date: Fri, 18 Feb 2011 09:57:39 -0800 (PST)
On Fri, Feb 18, 2011 at 6:45 PM, Laurent Rineau (GeometryFactory) [via cgal-discuss] <[hidden email]> wrote:
Le vendredi 18 février 2011 17:33:46, nyiotis a écrit :
Some parts of examples/Surface_reconstruction do need TAUCS.
> Configuring /Users/nikos/NetBeansProjects/cgal/CGAL-3.7/examples/Triangulation_2
> example
> Configuring /Users/nikos/NetBeansProjects/cgal/CGAL-3.7/examples/Triangulation_3
> example
Triangulation examples do not need TAUCS. The explanation is somewhere else.
OK, so as just to confirm, neither Triangulation2D/3D nor Voronoi2D/3D needs TAUCS right?
Laurent Rineau, PhD
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
Release Manager of the CGAL Project       http://www.cgal.org/
To unsubscribe from Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., click here.
View this message in context: Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine..
