[cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine..
- To:
- Subject: [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine..
- Date: Fri, 18 Feb 2011 09:14:57 -0800 (PST)
I am missing a point. Did you install CGAL from source or from a
package?
through macports, CGAL_UseTAUCS.cmake is there but TAUCS is not
If CGAL lib has been successfully built, just go into the example
directory you are interested in and run cmake. TAUCS is not needed
to compile Triangulation_2 example, and if cmake tells you it is the
case, then your CMakeLists.txt is not correct. Use the script
cgal_create_cmake_script (in CGAL_PATH/scripts) to generate a correct
one.
OK, it runs right now, perhaps sth was wrong in the previous set-up
If you really want to install TAUCS, here is the link:
https://gforge.inria.fr/frs/download.php/24628/taucs_full.tgz
thanks for the prompt answers
S.
> TAUCS libraries not found. Please specify libraries location.
> NOTICE: This directory requires the TAUCS library, and some features will
> not be available.
> Configuring
> /Users/nikos/NetBeansProjects/cgal/CGAL-3.7/examples/Surface_mesh_simplification
> example
> Configuring
> /Users/nikos/NetBeansProjects/cgal/CGAL-3.7/examples/Surface_mesher
> example
> Configuring
> /Users/nikos/NetBeansProjects/cgal/CGAL-3.7/examples/Surface_reconstruction_points_3
> example
> NOTICE: Some of the executables in this directory need the TAUCS library
> and
> will not be compiled.
> Configuring
> /Users/nikos/NetBeansProjects/cgal/CGAL-3.7/examples/Triangulation_2
> example
> Configuring
> /Users/nikos/NetBeansProjects/cgal/CGAL-3.7/examples/Triangulation_3
> example
> Configuring
> /Users/nikos/NetBeansProjects/cgal/CGAL-3.7/examples/Voronoi_diagram_2
> example
> Configuring /Users/nikos/NetBeansProjects/cgal/CGAL-3.7/examples/Width_3
> example
> Configuring /Users/nikos/NetBeansProjects/cgal/CGAL-3.7/demo/AABB_tree
> demo
> So TAUCS is the problem.. and now it going to be hell until I install it
> =D
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Cannot-run-the-examples-for-using-Delaunay-Triangulation-2-whereas-Delaunay-Triangulation-3-runs-fin-tp3313008p3313171.html
- [cgal-discuss] Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., nyiotis, 02/18/2011
- Re: [cgal-discuss] Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., Sebastien Loriot (GeometryFactory), 02/18/2011
- [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., nyiotis, 02/18/2011
- Re: [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., Sebastien Loriot (GeometryFactory), 02/18/2011
- Re: [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., Laurent Rineau (GeometryFactory), 02/18/2011
