- To:
- Subject: [cgal-discuss] configure fails
- Date: Tue, 29 Mar 2011 21:57:12 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:date:x-google-sender-auth:message-id:subject :from:to:content-type; b=aEiKQRghJD5M5kzH2l/L+qTPgOp1tezEtSFwFdSLc2xP55BwM/ZvJohkx8zyZOdy2f BuOP9qifxYDdf3vpqtkdBOqz6CYpYm1GNfHCDSmorIc5fxbzlk75THUwHUSxie0fidln vpy6d6Xptv4XbF5JrIASGDcExZSuuVKFNV5YU=
Is it possible to configure CGAL 3.7 with MSVC 2010 64?
I have boost 1.46.1 here and whatever I do to configure CGAL I always see:
The following Boost libraries could not be found:
boost_thread
No Boost libraries were found. You may need to set Boost_LIBRARYDIR to
directory containing Boost libraries or BOOST_ROOT to the location of
Boost.
I set both Boost_LIBRARYDIR and BOOST_ROOT to the right values to no avail. Whatever I put as contents of the thread release/debug libraries they are always reset to NOTFOUND.
I have also removed the FindBoost.cmake in CGAL to use the one bundled in cmake 2.8.4 - no avail.
I will be grateful for any pointers.
Dominik
PS. I tried hacking and hardcoded boost paths/libs but this bites me back later during compilation and linking.
- [cgal-discuss] configure fails, Dominik Szczerba, 03/29/2011
- Re: [cgal-discuss] configure fails, Pierre Alliez, 03/29/2011
- Re: [cgal-discuss] configure fails, Andreas Fabri, 03/29/2011
- Re: [cgal-discuss] configure fails, Dominik Szczerba, 03/30/2011
- Re: [cgal-discuss] configure fails, Andreas Fabri, 03/30/2011
- Re: [cgal-discuss] configure fails, Andreas Fabri, 03/31/2011
- Re: [cgal-discuss] configure fails, Dominik Szczerba, 03/31/2011
