cgal-discuss - Re: [cgal-discuss] configure fails
  • To:
  • Subject: Re: [cgal-discuss] configure fails
  • Date: Wed, 30 Mar 2011 12:35:12 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=eU0P13Eecif9WsxsbbxjgCT4JCB1n+EMVySCehbiCI69sJqDhPbQCg/6qM75d2DZTO sml6PkYiYOh/qOj+5Vb7p3madj3DkiTeTzDMYBO5xeTUH+vCn4KPtAvuIMd3je0FSeLT yberl0v55srulbP/5GVVxI+X/axAXMTUcsVII=
Hmmm, this switch is not documented (no mention in bjam --help) so I assume 64 bit version would be built on 64 bit command prompt.
But anyway, I compiled a version with your switch, but the problem is still there.
Dominik
On Wed, Mar 30, 2011 at 9:16 AM, Andreas Fabri <> wrote:
Hi Dominik,
there is a switch:
bjam address-model=64
andreas
On 30/03/2011 09:06, Dominik Szczerba wrote:
I have built boost in the 64 bit VC prompt, so I assume so. I did not
see a switch to chose 32/64 with bjam.
$BOOST_ROOT/lib contains files like boost_thread-vc100-mt-1_46_1.lib/dll.
Dominik
On Tue, Mar 29, 2011 at 11:00 PM, Andreas Fabri
<mailto:>> wrote:
   Hi Dominik,
   Did you build boost for 64 bits?  The precompiled versions from
   Boost Consulting are for 32 bit.
   What are the files in your directory
   $BOOST_ROOT/lib
   andreas
   On 29/03/2011 21:57, Dominik Szczerba wrote:
       Is it possible to configure CGAL 3.7 with MSVC 2010 64?
       I have boost 1.46.1 here and whatever I do to configure CGAL I
       always see:
       The following Boost libraries could not be found:
                boost_thread
       No Boost libraries were found.  You may need to set
       Boost_LIBRARYDIR to
       directory containing Boost libraries or BOOST_ROOT to the
       location of
       Boost.
       I set both Boost_LIBRARYDIR and BOOST_ROOT to the right values to no
       avail. Whatever I put as contents of the thread release/debug
       libraries
       they are always reset to NOTFOUND.
       I have also removed the FindBoost.cmake in CGAL to use the one
       bundled
       in cmake 2.8.4 - no avail.
       I will be grateful for any pointers.
       Dominik
       PS. I tried hacking and hardcoded boost paths/libs but this bites me
       back later during compilation and linking.
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: ++33.492.954.912    skype: andreas.fabri
