- To:
- Subject: Re: [cgal-discuss] configure fails
- Date: Wed, 30 Mar 2011 15:12:54 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=WPXvwApCmMxjxX7kvce03h0STpSMqxeUtPtXIkROcZZop27pkBLz9KE5Yv1X3gy/Jt NkHljS+ca0xclFLUEr5Ieq8sCOpU/1Np+0ol8pv3H5hTI2boSK27RVnKKg5kPWTB5Vzh DvcFXf6BxTC4+oTVkgH+jy4g+V5unspmTgvaY=
I have configured and installed boost like this:
bjam --prefix=P:\boost-1.44.0\x64\Release address-model=64 variant=release --with-thread --with-date_time --with-program_options --with-filesystem --with-system install
bjam --prefix=P:\boost-1.44.0\x64\Debug address-model=64 variant=debug --with-thread --with-date_time --with-program_options --with-filesystem --with-system install
I configure CGAL with cmake 2.8.4 like this:
E:\build\cgal-3.7>cmake -DBoost_INCLUDE_DIR:PATH=P:/boost-1.44.0/x64/Release/inc
lude/boost-1_44 -DBoost_LIBRARY_DIRS:FILEPATH=P:/boost-1.44.0/x64/Release/lib -D
Boost_THREAD_LIBRARY:FILEPATH=optimized;P:/boost-1.44.0/x64/Release/lib/libboost
_thread-vc100-mt-1_44.lib;debug;P:/boost-1.44.0/x64/Debug/lib/libboost_thread-vc
100-mt-gd-1_44.lib -DBoost_THREAD_LIBRARY_RELEASE:FILEPATH=P:/boost-1.44.0/x64/R
elease/lib/libboost_thread-vc100-mt-1_44.lib -DBoost_THREAD_LIBRARY_DEBUG:FILEP
ATH=P:/boost-1.44.0/x64/Debug/lib/libboost_thread-vc100-mt-gd-1_44.lib E:/pack/C
GAL-3.7
and I still get the same error, see below. I add the suggested variables in the GUI to no avail, with the frustrating effect that the variables storing the thread libs are always reset to NOTFOUND.
Any way out?
Regards,
Dominik
-- Building for: Visual Studio 10
-- Check for working C compiler using: Visual Studio 10
-- Check for working C compiler using: Visual Studio 10 -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler using: Visual Studio 10
-- Check for working CXX compiler using: Visual Studio 10 -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- CGAL_MAJOR_VERSION=3
-- CGAL_MINOR_VERSION=7
-- CGAL_BUILD_VERSION=
-- CGAL_SONAME_VERSION=6
-- CGAL_SOVERSION =6.0.0
-- CGAL_REFERENCE_CACHE_DIR=
-- Building static libraries
-- Targetting Visual Studio 10
-- Target build enviroment supports auto-linking
-- Using VC10 compiler.
-- Generator uses intermediate configuration directory: $(Configuration)
-- USING CMake version: 2.8.4
-- System: Windows
-- Build type: Release
-- USING CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR -D_CRT_SECURE_NO_
DEPRECATE -D_SCL_SECURE_NO_DEPRECATE -D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_
WARNINGS /fp:strict /fp:except- /MD /O2 /Ob2 /D NDEBUG'
-- USING LDFLAGS = ' '
-- Could NOT find GMP
-- Could NOT find MPFR
-- CGAL_Core needs GMP, cannot be configured.
CMake Error at cmake/modules/FindBoost.cmake:917 (message):
Unable to find the requested Boost libraries.
Boost version: 1.44.0
Boost include path: P:/boost-1.44.0/x64/Release/include/boost-1_44
The following Boost libraries could not be found:
boost_thread
No Boost libraries were found. You may need to set Boost_LIBRARYDIR to the
directory containing Boost libraries or BOOST_ROOT to the location of
Boost.
On Wed, Mar 30, 2011 at 1:57 PM, Andreas Fabri <> wrote:
I am since long on Windows 7, and was on XP64 before.
I huilt Boost 1_41_0 this way
bjam address-model=64 --with-thread --with-date_time --with-program_options --with-filesystem --with-system debug release stage
and I copied the libraries (they are all static) to
the directory lib.
In my CMakeCache I have
//Path to a file.
Boost_INCLUDE_DIR:PATH=c:/boost/boost_1_41_0
//Boost library directory
Boost_LIBRARY_DIRS:FILEPATH=c:/boost/boost_1_41_0/lib;c:/boost/boost_1_41_0/lib
//Boost diagnostic define
Boost_LIB_DIAGNOSTIC_DEFINITIONS:STRING=-DBOOST_LIB_DIAGNOSTIC
//The Boost THREAD library
Boost_THREAD_LIBRARY:FILEPATH=optimized;c:/boost/boost_1_41_0/lib/libboost_thread-vc90-mt-1_41.lib;debug;c:/boost/boost_1_41_0/lib/libboost_thread-vc90-mt-gd-1_41.lib
//Path to a library.
Boost_THREAD_LIBRARY_DEBUG:FILEPATH=c:/boost/boost_1_41_0/lib/libboost_thread-vc90-mt-gd-1_41.lib
Boost_THREAD_LIBRARY_RELEASE:FILEPATH=c:/boost/boost_1_41_0/lib/libboost_thread-vc90-mt-1_41.lib
In case you created dll's did you put them in the PATH
andreas
On 30/03/2011 12:35, Dominik Szczerba wrote:
Hmmm, this switch is not documented (no mention in bjam --help) so I
assume 64 bit version would be built on 64 bit command prompt.
But anyway, I compiled a version with your switch, but the problem is
still there.
Dominik
On Wed, Mar 30, 2011 at 9:16 AM, Andreas Fabri
<phone: ++33.492.954.912 <tel:%2B%2B33.492.954.912> skype:<mailto:>> wrote:
Hi Dominik,
there is a switch:
andreas
On 30/03/2011 09:06, Dominik Szczerba wrote:
I have built boost in the 64 bit VC prompt, so I assume so. I
did not
see a switch to chose 32/64 with bjam.
$BOOST_ROOT/lib contains files like
boost_thread-vc100-mt-1_46_1.lib/dll.
Dominik
On Tue, Mar 29, 2011 at 11:00 PM, Andreas Fabri
<mailto:>
<mailto:
<mailto:>>> wrote:
Hi Dominik,
Did you build boost for 64 bits? The precompiled versions from
Boost Consulting are for 32 bit.
What are the files in your directory
$BOOST_ROOT/lib
andreas
On 29/03/2011 21:57, Dominik Szczerba wrote:
Is it possible to configure CGAL 3.7 with MSVC 2010 64?
I have boost 1.46.1 here and whatever I do to configure
CGAL I
always see:
boost_thread
Boost_LIBRARYDIR to
location of
Boost.
I set both Boost_LIBRARYDIR and BOOST_ROOT to the right
values to no
avail. Whatever I put as contents of the thread
release/debug
libraries
they are always reset to NOTFOUND.
I have also removed the FindBoost.cmake in CGAL to use
the one
bundled
in cmake 2.8.4 - no avail.
I will be grateful for any pointers.
Dominik
PS. I tried hacking and hardcoded boost paths/libs but
this bites me
back later during compilation and linking.
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
andreas.fabri
Andreas Fabri, PhD
phone: ++33.492.954.912 skype: andreas.fabri
- [cgal-discuss] configure fails, Dominik Szczerba, 03/29/2011
- Re: [cgal-discuss] configure fails, Pierre Alliez, 03/29/2011
- Re: [cgal-discuss] configure fails, Andreas Fabri, 03/29/2011
- Re: [cgal-discuss] configure fails, Dominik Szczerba, 03/30/2011
- Re: [cgal-discuss] configure fails, Andreas Fabri, 03/30/2011
- Re: [cgal-discuss] configure fails, Andreas Fabri, 03/31/2011
- Re: [cgal-discuss] configure fails, Dominik Szczerba, 03/31/2011
- Re: [cgal-discuss] configure fails, Laurent Rineau (GeometryFactory), 03/31/2011
- Re: [cgal-discuss] configure fails, Laurent Rineau (GeometryFactory), 03/30/2011
