- To:
- Subject: Re: [cgal-discuss] configure fails
- Date: Wed, 30 Mar 2011 09:06:16 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=XvJZSc1VCc/fCyFVhpq7ynMzdJNUQmHazgDnSZagPwlVSFYjQF4HyBELhN2GqaXJN2 rdPJacOI1C9hnea+iftnj6jnuRF4QUPOmu40EWseKzls3ewCexSflVUCsUK55Ff7JoQg iJkywXe3JFWo2dyDXA7EEFFO6ifGEyReEr/CQ=
I have built boost in the 64 bit VC prompt, so I assume so. I did not see a switch to chose 32/64 with bjam.
$BOOST_ROOT/lib contains files like boost_thread-vc100-mt-1_46_1.lib/dll.
Dominik
On Tue, Mar 29, 2011 at 11:00 PM, Andreas Fabri <> wrote:
Hi Dominik,
Did you build boost for 64 bits? The precompiled versions from
Boost Consulting are for 32 bit.
What are the files in your directory
$BOOST_ROOT/lib
andreas--
On 29/03/2011 21:57, Dominik Szczerba wrote:
Is it possible to configure CGAL 3.7 with MSVC 2010 64?
I have boost 1.46.1 here and whatever I do to configure CGAL I always see:
The following Boost libraries could not be found:
boost_thread
No Boost libraries were found. You may need to set Boost_LIBRARYDIR to
directory containing Boost libraries or BOOST_ROOT to the location of
Boost.
I set both Boost_LIBRARYDIR and BOOST_ROOT to the right values to no
avail. Whatever I put as contents of the thread release/debug libraries
they are always reset to NOTFOUND.
I have also removed the FindBoost.cmake in CGAL to use the one bundled
in cmake 2.8.4 - no avail.
I will be grateful for any pointers.
Dominik
PS. I tried hacking and hardcoded boost paths/libs but this bites me
back later during compilation and linking.
- [cgal-discuss] configure fails, Dominik Szczerba, 03/29/2011
- Re: [cgal-discuss] configure fails, Pierre Alliez, 03/29/2011
- Re: [cgal-discuss] configure fails, Andreas Fabri, 03/29/2011
- Re: [cgal-discuss] configure fails, Dominik Szczerba, 03/30/2011
- Re: [cgal-discuss] configure fails, Andreas Fabri, 03/30/2011
- Re: [cgal-discuss] configure fails, Andreas Fabri, 03/31/2011
- Re: [cgal-discuss] configure fails, Dominik Szczerba, 03/31/2011
- Re: [cgal-discuss] configure fails, Laurent Rineau (GeometryFactory), 03/31/2011
