cgal-discuss - Re: [cgal-discuss] configure fails
  • To:
  • Subject: Re: [cgal-discuss] configure fails
  • Date: Tue, 29 Mar 2011 23:00:17 +0200
Hi Dominik,
Did you build boost for 64 bits? The precompiled versions from
Boost Consulting are for 32 bit.
What are the files in your directory
$BOOST_ROOT/lib
andreas
On 29/03/2011 21:57, Dominik Szczerba wrote:
Is it possible to configure CGAL 3.7 with MSVC 2010 64?
I have boost 1.46.1 here and whatever I do to configure CGAL I always see:
The following Boost libraries could not be found:
boost_thread
No Boost libraries were found. You may need to set Boost_LIBRARYDIR to
directory containing Boost libraries or BOOST_ROOT to the location of
Boost.
I set both Boost_LIBRARYDIR and BOOST_ROOT to the right values to no
avail. Whatever I put as contents of the thread release/debug libraries
they are always reset to NOTFOUND.
I have also removed the FindBoost.cmake in CGAL to use the one bundled
in cmake 2.8.4 - no avail.
I will be grateful for any pointers.
Dominik
PS. I tried hacking and hardcoded boost paths/libs but this bites me
back later during compilation and linking.
