- To:
- Subject: Re: [cgal-discuss] configure fails
- Date: Wed, 30 Mar 2011 09:16:42 +0200
Hi Dominik,
there is a switch:
bjam address-model=64
andreas
On 30/03/2011 09:06, Dominik Szczerba wrote:
I have built boost in the 64 bit VC prompt, so I assume so. I did not
see a switch to chose 32/64 with bjam.
$BOOST_ROOT/lib contains files like boost_thread-vc100-mt-1_46_1.lib/dll.
Dominik
On Tue, Mar 29, 2011 at 11:00 PM, Andreas Fabri
<mailto:>>
wrote:
Hi Dominik,
Did you build boost for 64 bits? The precompiled versions from
Boost Consulting are for 32 bit.
What are the files in your directory
$BOOST_ROOT/lib
andreas
On 29/03/2011 21:57, Dominik Szczerba wrote:
Is it possible to configure CGAL 3.7 with MSVC 2010 64?
I have boost 1.46.1 here and whatever I do to configure CGAL I
always see:
The following Boost libraries could not be found:
boost_thread
No Boost libraries were found. You may need to set
Boost_LIBRARYDIR to
directory containing Boost libraries or BOOST_ROOT to the
location of
Boost.
I set both Boost_LIBRARYDIR and BOOST_ROOT to the right values to no
avail. Whatever I put as contents of the thread release/debug
libraries
they are always reset to NOTFOUND.
I have also removed the FindBoost.cmake in CGAL to use the one
bundled
in cmake 2.8.4 - no avail.
I will be grateful for any pointers.
Dominik
PS. I tried hacking and hardcoded boost paths/libs but this bites me
back later during compilation and linking.
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: ++33.492.954.912 skype: andreas.fabri
- [cgal-discuss] configure fails, Dominik Szczerba, 03/29/2011
- Re: [cgal-discuss] configure fails, Pierre Alliez, 03/29/2011
- Re: [cgal-discuss] configure fails, Andreas Fabri, 03/29/2011
- Re: [cgal-discuss] configure fails, Dominik Szczerba, 03/30/2011
- Re: [cgal-discuss] configure fails, Andreas Fabri, 03/30/2011
- Re: [cgal-discuss] configure fails, Andreas Fabri, 03/31/2011
- Re: [cgal-discuss] configure fails, Dominik Szczerba, 03/31/2011
- Re: [cgal-discuss] configure fails, Laurent Rineau (GeometryFactory), 03/31/2011
- Re: [cgal-discuss] configure fails, Laurent Rineau (GeometryFactory), 03/30/2011
