cgal-discuss - Re: [cgal-discuss] configure fails
  • To:
  • Subject: Re: [cgal-discuss] configure fails
  • Date: Thu, 31 Mar 2011 11:04:41 +0200
I am sorry, but you must do something wrong, and their should
be no need for magic. At least here on my machine the following
works for Windows7 64 bit
I installed the latest version of cmake.
I downloaded boost 1.46.1
I unzipped it into c:/boost/boost_1_46_1
I opened the Windows cmd shell
Start -> All Programs -> Microsoft Visual Studio 2010
-> Visual Studio Tools -> Visual Studio x64 Win64 Command Prompt (2010)
and went in the above directory
I copied bjam.exe into this directory.
I called
bjam toolset=msvc-10.0 address-model=64 --with-thread
--with-date_time --with-program_options --with-filesystem
--with-system debug release stage
I copied the files stage/lib/*vc100*.lib
to the directory c:/boost/boost_1_46_1/lib
I define the environment variable BOOST_ROOT
I go into the CGAL root directory
I create a directory VC10, and go into this directory
I call cmake-gui ..
I choose the nmake generator
I click on configure
It sets all variables automatically and correctly.
In the CMakeCache.txt file I get:
//Path to a file.
Boost_INCLUDE_DIR:PATH=c:/boost/boost_1_46_1
//Boost library directory
Boost_LIBRARY_DIRS:FILEPATH=c:/boost/boost_1_46_1/lib;c:/boost/boost_1_46_1/lib
//Boost diagnostic define
Boost_LIB_DIAGNOSTIC_DEFINITIONS:STRING=-DBOOST_LIB_DIAGNOSTIC
//The Boost THREAD library
Boost_THREAD_LIBRARY:FILEPATH=optimized;c:/boost/boost_1_46_1/lib/libboost_thread-vc100-mt-1_46_1.lib;debug;c:/boost/boost_1_46_1/lib/libboost_thread-vc100-mt-gd-1_46_1.lib
//Path to a library.
Boost_THREAD_LIBRARY_DEBUG:FILEPATH=c:/boost/boost_1_46_1/lib/libboost_thread-vc100-mt-gd-1_46_1.lib
Boost_THREAD_LIBRARY_RELEASE:FILEPATH=c:/boost/boost_1_46_1/lib/libboost_thread-vc100-mt-1_46_1.lib
andreas
On 30/03/2011 17:19, Dominik Szczerba wrote:
After endless trials and errors I have partially succeeded. The needed
magic was to specify BOOST_ROOT *AND* give Boost_LIBRARY_DIRS *TWO*
paths, as I keep release and debug builds separately,
Still, however, debug version can not be found when configured on the
command line, probably because there is no one root but two. It can only
be set via GUI, which disables automation.
Also, it still does not work with the latest boost 1.46.1.
I have still to test the newly built version.
Many thanks to everybody for the hints!
Dominik
On Wed, Mar 30, 2011 at 3:12 PM, Dominik Szczerba
<mailto:>>
wrote:
I have configured and installed boost like this:
bjam --prefix=P:\boost-1.44.0\x64\Release address-model=64
variant=release --with-thread --with-date_time
--with-program_options --with-filesystem --with-system install
bjam --prefix=P:\boost-1.44.0\x64\Debug address-model=64
variant=debug --with-thread --with-date_time --with-program_options
I configure CGAL with cmake 2.8.4 like this:
E:\build\cgal-3.7>cmake
-DBoost_INCLUDE_DIR:PATH=P:/boost-1.44.0/x64/Release/inc
lude/boost-1_44
-DBoost_LIBRARY_DIRS:FILEPATH=P:/boost-1.44.0/x64/Release/lib -D
Boost_THREAD_LIBRARY:FILEPATH=optimized;P:/boost-1.44.0/x64/Release/lib/libboost
_thread-vc100-mt-1_44.lib;debug;P:/boost-1.44.0/x64/Debug/lib/libboost_thread-vc
100-mt-gd-1_44.lib
-DBoost_THREAD_LIBRARY_RELEASE:FILEPATH=P:/boost-1.44.0/x64/R
elease/lib/libboost_thread-vc100-mt-1_44.lib
-DBoost_THREAD_LIBRARY_DEBUG:FILEP
ATH=P:/boost-1.44.0/x64/Debug/lib/libboost_thread-vc100-mt-gd-1_44.lib
E:/pack/C
GAL-3.7
and I still get the same error, see below. I add the suggested
variables in the GUI to no avail, with the frustrating effect that
the variables storing the thread libs are always reset to NOTFOUND.
Any way out?
Regards,
Dominik
-- Building for: Visual Studio 10
-- Check for working C compiler using: Visual Studio 10
-- Check for working C compiler using: Visual Studio 10 -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler using: Visual Studio 10
-- Check for working CXX compiler using: Visual Studio 10 -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- CGAL_MAJOR_VERSION=3
-- CGAL_MINOR_VERSION=7
-- CGAL_BUILD_VERSION=
-- CGAL_SONAME_VERSION=6
-- CGAL_SOVERSION =6.0.0
-- CGAL_REFERENCE_CACHE_DIR=
-- Building static libraries
-- Targetting Visual Studio 10
-- Target build enviroment supports auto-linking
-- Using VC10 compiler.
-- Generator uses intermediate configuration directory: $(Configuration)
-- USING CMake version: 2.8.4
-- System: Windows
-- Build type: Release
-- USING CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR
-D_CRT_SECURE_NO_
DEPRECATE -D_SCL_SECURE_NO_DEPRECATE -D_CRT_SECURE_NO_WARNINGS
-D_SCL_SECURE_NO_
WARNINGS /fp:strict /fp:except- /MD /O2 /Ob2 /D NDEBUG'
-- USING LDFLAGS = ' '
-- Could NOT find GMP
-- Could NOT find MPFR
-- CGAL_Core needs GMP, cannot be configured.
CMake Error at cmake/modules/FindBoost.cmake:917 (message):
Unable to find the requested Boost libraries.
Boost version: 1.44.0
Boost include path: P:/boost-1.44.0/x64/Release/include/boost-1_44
The following Boost libraries could not be found:
boost_thread
No Boost libraries were found. You may need to set
Boost_LIBRARYDIR to the
directory containing Boost libraries or BOOST_ROOT to the location of
Boost.
On Wed, Mar 30, 2011 at 1:57 PM, Andreas Fabri
<mailto:>>
wrote:
I am since long on Windows 7, and was on XP64 before.
I huilt Boost 1_41_0 this way
bjam address-model=64 --with-thread --with-date_time
--with-program_options --with-filesystem --with-system debug
release stage
and I copied the libraries (they are all static) to
the directory lib.
In my CMakeCache I have
//Path to a file.
Boost_INCLUDE_DIR:PATH=c:/boost/boost_1_41_0
Boost_LIBRARY_DIRS:FILEPATH=c:/boost/boost_1_41_0/lib;c:/boost/boost_1_41_0/lib
Boost_THREAD_LIBRARY:FILEPATH=optimized;c:/boost/boost_1_41_0/lib/libboost_thread-vc90-mt-1_41.lib;debug;c:/boost/boost_1_41_0/lib/libboost_thread-vc90-mt-gd-1_41.lib
Boost_THREAD_LIBRARY_DEBUG:FILEPATH=c:/boost/boost_1_41_0/lib/libboost_thread-vc90-mt-gd-1_41.lib
Boost_THREAD_LIBRARY_RELEASE:FILEPATH=c:/boost/boost_1_41_0/lib/libboost_thread-vc90-mt-1_41.lib
In case you created dll's did you put them in the PATH
andreas
On 30/03/2011 12:35, Dominik Szczerba wrote:
Hmmm, this switch is not documented (no mention in bjam
--help) so I
assume 64 bit version would be built on 64 bit command prompt.
But anyway, I compiled a version with your switch, but the
problem is
still there.
Dominik
On Wed, Mar 30, 2011 at 9:16 AM, Andreas Fabri
<mailto:>
<mailto:
<mailto:>>>
wrote:
Hi Dominik,
there is a switch:
andreas
On 30/03/2011 09:06, Dominik Szczerba wrote:
I have built boost in the 64 bit VC prompt, so I
assume so. I
did not
see a switch to chose 32/64 with bjam.
$BOOST_ROOT/lib contains files like
boost_thread-vc100-mt-1_46_1.lib/dll.
Dominik
On Tue, Mar 29, 2011 at 11:00 PM, Andreas Fabri
<mailto:>
<mailto:
<mailto:>>
<mailto:
<mailto:>
<mailto:
<mailto:>>>>
wrote:
Hi Dominik,
Did you build boost for 64 bits? The
precompiled versions from
Boost Consulting are for 32 bit.
What are the files in your directory
$BOOST_ROOT/lib
andreas
On 29/03/2011 21:57, Dominik Szczerba wrote:
Is it possible to configure CGAL 3.7 with
MSVC 2010 64?
I have boost 1.46.1 here and whatever I do
to configure
CGAL I
always see:
found:
boost_thread
to set
Boost_LIBRARYDIR to
BOOST_ROOT to the
location of
Boost.
I set both Boost_LIBRARYDIR and BOOST_ROOT
to the right
values to no
avail. Whatever I put as contents of the thread
release/debug
libraries
they are always reset to NOTFOUND.
I have also removed the FindBoost.cmake in
CGAL to use
the one
bundled
in cmake 2.8.4 - no avail.
I will be grateful for any pointers.
Dominik
PS. I tried hacking and hardcoded boost
paths/libs but
this bites me
back later during compilation and linking.
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: ++33.492.954.912 <tel:%2B%2B33.492.954.912>
<tel:%2B%2B33.492.954.912> skype:
andreas.fabri
Andreas Fabri, PhD
phone: ++33.492.954.912 <tel:%2B%2B33.492.954.912> skype:
andreas.fabri
Andreas Fabri, PhD
phone: ++33.492.954.912 skype: andreas.fabri
