- To:
- Subject: Re: [cgal-discuss] configure fails
- Date: Wed, 30 Mar 2011 12:34:18 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type; b=YfOahLCKn23yTcm9TUAuWY3B2SIPdrcRvsEb3E6Gg4kWsle/LBRCNXaPKooTBoEyxQ wrieqYOYri1u9piHPDi2XPhWA5j8ldnM+OncDmxxvaXEtrPLfjq46GiFEFE2Mv1Yjc8N AOvJZ2HSh+60nzGR5D8VxU5iiWCtQ1JysUphM=
You may try to reinstall cmake. I have met the similar problem before when I replacing CGAL 3.7 to 3.8 beta1, and finally it was solved by updating cmake from 2.8.3 to 2.8.4.
2011/3/30 Dominik Szczerba <>
Is it possible to configure CGAL 3.7 with MSVC 2010 64?I have boost 1.46.1 here and whatever I do to configure CGAL I always see:The following Boost libraries could not be found:boost_threadNo Boost libraries were found. You may need to set Boost_LIBRARYDIR todirectory containing Boost libraries or BOOST_ROOT to the location ofBoost.I set both Boost_LIBRARYDIR and BOOST_ROOT to the right values to no avail. Whatever I put as contents of the thread release/debug libraries they are always reset to NOTFOUND.I have also removed the FindBoost.cmake in CGAL to use the one bundled in cmake 2.8.4 - no avail.I will be grateful for any pointers.DominikPS. I tried hacking and hardcoded boost paths/libs but this bites me back later during compilation and linking.
- Re: [cgal-discuss] configure fails, (continued)
- Re: [cgal-discuss] configure fails, Pierre Alliez, 03/29/2011
- Re: [cgal-discuss] configure fails, Andreas Fabri, 03/29/2011
- Re: [cgal-discuss] configure fails, Dominik Szczerba, 03/30/2011
- Re: [cgal-discuss] configure fails, Andreas Fabri, 03/30/2011
- Re: [cgal-discuss] configure fails, Laurent Rineau (GeometryFactory), 03/30/2011
- Re: [cgal-discuss] configure fails, Stzpz, 03/30/2011
