- To:
- Subject: Re: [cgal-discuss] configure fails
- Date: Wed, 30 Mar 2011 13:59:38 +0200
On mercredi 30 mars 2011 12:35:12 Dominik Szczerba wrote:
> Hmmm, this switch is not documented (no mention in bjam --help) so I assume
> 64 bit version would be built on 64 bit command prompt.
> But anyway, I compiled a version with your switch, but the problem is still
> there.
No. You need address-model. Google knows a lot of forum/glob pages about
Boost
and 64 bits on Windows.
For example, that old page from 2007 seems still up-to-date:
http://www.codefornuts.com/2007/06/compiling-boost-for-x64.html
- Re: [cgal-discuss] configure fails, (continued)
- Re: [cgal-discuss] configure fails, Andreas Fabri, 03/30/2011
- Re: [cgal-discuss] configure fails, Dominik Szczerba, 03/30/2011
- Re: [cgal-discuss] configure fails, Andreas Fabri, 03/31/2011
- Re: [cgal-discuss] configure fails, Dominik Szczerba, 03/31/2011
- Re: [cgal-discuss] configure fails, Laurent Rineau (GeometryFactory), 03/31/2011
