- To:
- Subject: Re: [cgal-discuss] configure fails
- Date: Thu, 31 Mar 2011 16:06:04 +0200
On jeudi 31 mars 2011 15:57:37 Dominik Szczerba wrote:
> Dear Andreas,
> Unfortunately, we might both be wrong. The problem is still there, even
> with one BOOST_ROOT for debug/release when I compile a dynamic (DLL)
> version of boost (see other thread why). The thread library can not be
> found, always reset to NOTFOUND.
In which directory are the Boost .dll files? Is that directory in the list of
the PATH environment variable? If it is now, then Windows cannot retrieve the
dll files, even if they are in the same directory as the .lib files that were
used at link-time.
- Re: [cgal-discuss] configure fails, (continued)
- Re: [cgal-discuss] configure fails, Andreas Fabri, 03/29/2011
- Re: [cgal-discuss] configure fails, Dominik Szczerba, 03/30/2011
- Re: [cgal-discuss] configure fails, Andreas Fabri, 03/30/2011
- Re: [cgal-discuss] configure fails, Andreas Fabri, 03/31/2011
- Re: [cgal-discuss] configure fails, Dominik Szczerba, 03/31/2011
- Re: [cgal-discuss] configure fails, Laurent Rineau (GeometryFactory), 03/31/2011
- Re: [cgal-discuss] configure fails, Laurent Rineau (GeometryFactory), 03/30/2011
